Had a productive weekend
Old Feb 4, 2007 | 10:24 PM
charlie31603's Avatar
Car: 1987 Chevrolet Camaro Z28 IROCZ
Engine: L98 350, mini ramed and camed
Transmission: T56 6 speed manual
Axle/Gears: 10 bolt 3:73 limited slip
I had a very productive weekend. I got the rims mounted on the car. Plus I had a chance to fix the crack in the 82 Z28 fiberglass hood and got it mounted also. I think it gives the car a total diffrent look. Adam :-)
Old Feb 4, 2007 | 11:24 PM
Brisk's Avatar
Car: '88 IROC-Z / '91 Z28 / '91 GTA
Engine: LT4 Hot Cam 305 / L98 355 / MR 383
Transmission: 5-spd / 700R4 / 700R4
Axle/Gears: 3:45 / 3:23 / 3:23
nice RS.. now wax that thing already..
Old Feb 5, 2007 | 12:41 AM
noahTHEpurdy's Avatar
Car: 1992 Pontiac Firebird
Engine: 3.1
Axle/Gears: 3.42 Auburn Posi
!!!! Wheel weights on the outside of the rims !!!!
Go take it and get it statically balanced with the weights on the inside, don't screw up your rims!
Old Feb 5, 2007 | 07:37 AM
It's way beond waxing. It needs a whole new paint job.
There is no wheel weights on the outside of the wheel .I know better then that. It must be the pictures. Adam :-)
Old Feb 5, 2007 | 02:17 PM
Poject '86's Avatar
Car: 1986 Firebird
Engine: V6
Transmission: Automatic
It looks good. I love verts. Now just throw some tire gel on there. Also try using a rotary polisher with Mcguiers show car glaze. I did that to my friends g/f's mustang that had paint that was dull like yours and it actually made it shine. Hit it a couple times with it and you'll notice a difference. That way it'll look alrite til you get it repainted.
Just a temporary fix, it's by no means a permanent one.
Old Feb 5, 2007 | 03:04 PM
Brisk's Avatar
Its hard to tell from just images, but I'm going to have to disagree. The paint itself looks decent; no big nicks, gouges, spidering, peeling, flaking, etc. From here is just appears to be very dull and oxidized.
I'd try give it a good abrasive cut polish followed by a good paint restorer/oxidation removed. Then give it a good coat with a quality wax to protect it like meguiars gold class, or mothers, etc.
It may be a honda in the attachment, but just look at how paint can be restored.
Old Feb 5, 2007 | 03:13 PM
Poject '86's Avatar
Car: 1986 Firebird
Engine: V6
Brisks advice sounds better.
That's pretty much what the mustang looked like before and after. Except the the end result wasn't as good as what Brisk posted.
If you try it out, post pics of what it looks like afterwards.
Old Feb 5, 2007 | 03:43 PM
Sickness91Z28's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
are those 18" Torque Thrust II"s???
Old Feb 5, 2007 | 04:22 PM
jcisthechamp05's Avatar
Car: 1987 IROC-Z
Man that looks awesome, and it looks almost identical to mine paint/body wise, with the exception on th eaftermarket hood on mine. But if your paint is anything like mine, then yes, you are right, it is way beyond waxing.
Old Feb 5, 2007 | 04:37 PM
1986Z28OWNER's Avatar
Car: 1979 Malibu
Engine: Blown LSx
Transmission: T56 Magnum
Axle/Gears: 9"/wavetrac/35's/3.70
those look like the wheels im going to be running
17" x 8" vision 141s,
Old Feb 5, 2007 | 04:42 PM
Stevo's Avatar
Car: Pair of 92 Z28s
Looks good, its hard to tell with the paint looks like the clear has either pealed off or just looks very very oxidized. None the less get a high quality buffer on there and give it a whirl! Good luck.
Old Feb 5, 2007 | 07:05 PM
rwdtech's Avatar
Car: 1991 Z28 (sold)
what size are the wheels? they look great. they will look stunning when the paint is fixed
Old Feb 5, 2007 | 08:31 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
i could buff that out and make it shiny based off those pics, when I bought my camaro I thought it was charcoal colored, after buffing it, the car was black with silver metallic flake....boy was I shocked.
Old Feb 7, 2007 | 04:32 PM
CharcoalBird's Avatar
Car: 1991 Firebird
Engine: 3.1L V6
Charlie, what's goin on man? Havn't talked to you in a while. What happened to the black camaro?? Trade it for the red vert??
Old Mar 2, 2007 | 11:32 PM
Thanks guys! The paint is shot. The clear is all gone. If you look at the passenger side. The door and finder are still shiny. But it is peeling. I plan on getting it redone in a blue matalic of some sort. The rims are 18x10 TT2's. They are off of a 4th gen with 2' spacers. Adam :-)
Old Mar 3, 2007 | 10:48 AM
manchesterbeast's Avatar
Car: 1985 pontiac trans am
Engine: 350 with carb and headers
Transmission: borg warner 5speed
red seems to be a bad color for fading. red fades faster than any other color - so if your thinking of repainting it, changing colors would be a good idea. personally i like light colors because theyre low maintenance. (white, grey, ect) but a nice dark color would compliment the rims nicely.
Overall nice car.
Old Mar 3, 2007 | 11:44 AM
Stephen's Avatar
Car: 87 GTA
That depends on if you want PERFECTION, or just real good. Static cannot obtain perfection, real close, but not perfect.
Ask any tire balancer, and they'll tell you the same thing. Sure, static is fine for most cars, mine are static balanced, and always will be.
Old Mar 3, 2007 | 12:10 PM
rwdtech's Avatar
you can use tape weights on both sides...
Old Mar 3, 2007 | 04:45 PM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Nice lean car and love the rims. New paint and good as new. Is it lowered?
Old Mar 3, 2007 | 05:01 PM
Overall nice car.
The owner before me said it had a cheap paint job done to it. And that's why it's like that.
There static balanced. They do vibrate a little. But so do the 2 12's in the trunk. lol. So it kind of equals out. lol.
Thanks. I'm think about getting it lowered an inch. The rear looks lowered do to a full tank of gas and the 100 pound sub box.
Adam :-)
Linson
Oct 24, 2025 02:00 PM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
no green
Jan 9, 2016 09:22 PM
Thornburg
Aftermarket Product Review
Oct 6, 2015 12:04 PM
paul_huryk
Oct 1, 2015 04:27 PM
