Help removing pinstipe adhesive....
Car: 92RS
Engine: LQ4
Transmission: 4L80E
Hey, i need some help as to how to remove the adhesive left behind from the pinstripe i removed from my car...heres a pic....
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Car: 1988 IROC
Transmission: TH-700r4
Re: Help removing pinstipe adhesive....
head down to your local paint/autobody supplier and get a 3M rubber pinstripe adhesive remover wheel. Its like a big rubber eraser thats hooks up to your drill and does not harm the paint. its like 15 bucks will last for years and years. It works so well the money is well well well well worth the price.
Car: 1990 IROC-Z
Transmission: 5 Speed
I've found wd40 to work well on removing adhesive, goo gone works good too, i'd try one of those and then use a claybar to clean up what's left, and finally finish it up with some wax
Car: '88 IROC-Z / '91 Z28 / '91 GTA
Engine: LT4 Hot Cam 305 / L98 355 / MR 383
Transmission: 5-spd / 700R4 / 700R4
Axle/Gears: 3:45 / 3:23 / 3:23
plastic razor blade won't damage the paint, a real razor obviously will.
3M General Purpose Adhesive Remover or Goo Gone will work magic. worst case senario a little bit of gasoline on a rag will work, but be careful because it will strip off any wax and will soften the paint.
After using any of the above mentioned products, a good wash and wax is absolutly nessessary.
Car: 2012 Corvette
Engine: LS3
Transmission: TR6060
Goo Gone works wonders, I use that on all the cars I detail and remove those stupid dealer stickers from.
IT would suprise you how well some waxes remove adhesives with elbow greace. I would take the plastic razer blade (or a long Fingernail) to it frist to get the bulk of it off and then start waxing. Some waxes work better then others so I wouldn't recomend going out and buying a bunch of new stuff just try the stuff you allready have first. This is an old New car auto detailer trick used to remove glue beads left by the plastic new cars are shiped with. it's definatly worth a try with all the poish and wax products that you all ready own depending the condition of your paint and how much time your are willing to put towards the project. The products that are good removing adheasives where just about as quick as solvents for removing glue beads.
Another tip. Never Use a Plasic razar Blade with a Medal razer Blade holder.
you will badly scratch and scrape off the paint if you use a real razor blade. you can subsitute just about anything that is plastic and has a flat straight edge for the plastic razor blade. for example a plastic knife would work if you scraped off the teeth on it
Goo Gone and let it set a minute, then go over w/a plastic blade. You can get Goo Gone anywhere, the other products work well also but are hard to find sometimes.
Car: 92RS
Engine: LQ4
Transmission: 4L80E
Heres some before and after pics....tell me what you think looks better
Before...
After...
Before...
After...
you know the citrus based remover.
