iroc wheels for 4th gen rear
Old May 23, 2007 | 07:23 PM
KintaroOe's Avatar
Car: '91 bird '87 Z28 '86 T/A
Engine: LO3 LG4(ls1 in works) 350
Transmission: 700R in all
Axle/Gears: wimpy 10 bolts
This has probly been asked before, but did not see anything in the threads i searched. Is there someone who sells iroc wheels that will fit a 4th gen rear properly? All i see around the internet is the 0mm offset ones which won't do.
My wife really wants these wheels
Old May 23, 2007 | 11:47 PM
ZZ4 86 Z28's Avatar
Car: 1986 Z28 Camaro Gunmetal Gray with
Engine: GM Crate ZZZ HO 350, Edelbrock head
Transmission: Rebuilt 700r4 all TransGo and Beast
Axle/Gears: 10 bolt with 3.73 gears
Re: iroc wheels for 4th gen rear
theyll fit anyways, and wont pop out past the lip. itll be kinda close though. somebody put pics up not too long ago of that.
Old May 25, 2007 | 12:31 AM
92RS(real slow)'s Avatar
Car: 92 RS(sold) 1989 IROC-Z
Axle/Gears: ones that turn
I was always wondering if they would fit that was one of the few things keepin me away form the 4th gen rear, I waanna see some pics hopefully somebody will post some up
Old May 25, 2007 | 06:48 PM
IROCZ28KevinZ's Avatar
Car: 1991 Z28 convertible
Transmission: TH-700R4
Axle/Gears: 3.73 posi 4th gen 10-bolt
i think if u use the factory rear rims they should be a 16mm offset if i remember correctly and they will stick out just to the lip but not past it. looks good IMO.
Old May 25, 2007 | 09:01 PM
2kflhr's Avatar
Car: '68 396 SS/RS, '02 SS
We just put a 4th gen rear in my boys '92 and it looks good. I think it looks better. He's running chrome 17' replica IROC wheels.
Old May 25, 2007 | 09:53 PM
KintaroOe's Avatar
2kflhr... have any pics of the setup by chance? Thkx for the info guys..
Old May 26, 2007 | 06:09 AM
crrllmich's Avatar
Car: 91 Camaro RS, 99 Camaro Z28
Engine: L03, LS1
Transmission: 700R4, T56
Axle/Gears: bunch of 10 bolts how scary is that
With all these goobers posting I will give you some real feedback.
I put on a 96 LT1 rear in my 91 RS. I was running the factory 16" wheels.
Everytime I hit a hard bump my tire would hit the fender well.
It complete ruins the factory appearence and gives it that wonderful ******* look we all love.
As for finding some not sure what to tell you but I can about garrentee it would be cheaper to find yourself another third gen rear that has everything you like.
Old May 26, 2007 | 07:24 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Here are a couple of pics with rear offset GTA's on an LS1 rear.
Old May 26, 2007 | 09:19 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Irocz front wheels are 0 mm offset. rears are a positive 16 mm offset i do believe
this means the front wheel on the rear will stick out 16mm or .6 inches. so 0 mm offset is NOT what you want. you need about 40-50mm offset like a 4th gen wheel to fit like stock thirdgen wheels.
I'm not aware of wheels like that out there on the market.
I can get a pic of this to double check that the rear wheels are indeed 16mm positive offset and that the front wheels will stick out even farther.
but here is my 4th gen rear swap and pics of the tires. it does stick out to even with fender lip. looks kinda good but the fronts are tucked in like stock so it sucks. the fronts need to come out some to match it but oh well.
if your suspension is new and fairly stiff, you wont hit the fender. my car has lowering springs on it and dropped the rear about an inch but it still sits somewhat higher than i wanted it. i hit bumps all the time and no problem so far with tires hiting the fender lip.
Old May 26, 2007 | 07:20 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
Why not just go back to a 3rd gen rear?????????
Old May 26, 2007 | 07:25 PM
KintaroOe's Avatar
I've seriously been considering going back to the 3rd gen rear. My only reason to upgrade was the fact it had a posi and everything for next to nothing, and i figured i needed something a little better for the ls1 im dropping in the next week or so.
Old May 26, 2007 | 07:35 PM
krisb410's Avatar
Seems to me it would be cheaper to find a 3rd gen rear that has the gears and posi already in it than to find/buy rims that dont exist, or to have the rims sticking way out.
Just an idea.
Old May 26, 2007 | 08:53 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
ls1 rear brakes tho are bigger which is nice to have. just a nice feature thats all
Old May 26, 2007 | 11:36 PM
krisb410's Avatar
Start looking for a 3rd gen posi/disk rear in the gear of your choice. And move the LS1 brakes on it. The backing plates will bolt right up to it. All you have to do is remove the axles then transplant the LS1 setup. It's real easy.
Old Jun 11, 2007 | 04:19 AM
noroxus's Avatar
Car: 1984 Z28
Engine: 360ci SBC
Transmission: WC T5
Axle/Gears: 9 bolt 3.27 Posi
how would Z06 56mm off rims fit on a 4th or 3rd gen rear? such as these...
http://cgi.ebay.com/ebaymotors/17-Ch...QQcmdZViewItem
Old Jun 11, 2007 | 04:59 AM
VenomX-87's Avatar
Car: 1984 Trans-Am WS6
Engine: WAS: 5.0HO, SOON: ZZ383-425HP.
Transmission: 700R4 with shift kit
wouldent a LS1 break a 3rd gen rear (diff)?
Old Jun 11, 2007 | 09:10 AM
krisb410's Avatar
I have +56mm ZR1s 17 x 9.5 and I use 2in spacer/adapters and they fit great. With the 4th gen rear you can drop the spacer/adapters and bolt them right up.
Old Jun 11, 2007 | 07:20 PM
85maroz28's Avatar
Car: 1985 Camaro Z28/1989 Pontiac Trans Am GTA
Engine: 305 tpi/350tpi
Any pictures?
1992rs/ss
Jan 31, 2025 05:10 PM
BlueIroc-Z
Jun 9, 2019 03:22 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
kah992
Aug 19, 2015 02:55 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
