help me get my ac box fully out im suck
Old Sep 4, 2007 | 04:52 PM
18inchboyds's Avatar
Car: 1985 Trans Am
Engine: vee eight
Transmission: auto
Axle/Gears: 4.10 gears
i have an 85 305 tpi trans am , im taking the ac out and got most of the box out , some pieces are still in there and i cant figure out how to get them out ? i have a few pics but i need some help .
Attached Thumbnails help me get my ac box fully out im suck-071.jpg   help me get my ac box fully out im suck-072.jpg   help me get my ac box fully out im suck-073.jpg
Old Sep 4, 2007 | 05:40 PM
BuiltZ28's Avatar
Re: help me get my ac box fully out im suck
If my memory serves correctly those are all studs running into the interior with a wing nut type of deal attached, search hard, there all under the dash, some behind the carpet/padding.
It looks like your not afraid to cut things, If you dont want to go through the hassle just cut the remaining pieces off, I dont think it will do any harm.
Old Sep 4, 2007 | 05:43 PM
noahTHEpurdy's Avatar
Car: 1992 Pontiac Firebird
Engine: 3.1
Axle/Gears: 3.42 Auburn Posi
Wow... takin' the hammer to it, eh?
The rest of the screws are on the passenger side of the firewall on the interior. You need to pull back the carpet and the insulation padding to get to them. Not really hard to find.
Old Sep 4, 2007 | 05:48 PM
online170's Avatar
Car: 1987 Firebird
Engine: 355
Theres i beleive 3 screws, as mentioned above. Ill take some pix when i get home and post them. Pull back the carpet on the passenger side, they are the only bolts that size, unbolt all,and it'll come free.
Old Sep 4, 2007 | 09:17 PM
Car: 1985 Trans Am
Engine: vee eight
Transmission: auto
no hammer just pulled on the pos old box and it came apart.
Old Sep 5, 2007 | 01:26 AM
rv1890's Avatar
Car: 87 Iroc-Z
Engine: 5.7 350 TPI
Transmission: stage2 700r4
Axle/Gears: 2.73 for now
oh wow!
Old Sep 5, 2007 | 08:27 AM
Car: 1985 Trans Am
Engine: vee eight
Transmission: auto
thanks for the info , i was hoping they wern't on the inside but i guess they are so ill be pulling some carpet today or tomorrow to get to them .
Old Sep 5, 2007 | 09:36 AM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
^ Remember, there are four bolts that hold the underside of the A/C box from inside of the car (when you install the non-A/C heater box, you'll only be re-using three of them). Just pull the carpet up a tad on the passenger side, and you'll see that they immediately become prevalent. Use a 10mm socket w/extension....
Old Sep 5, 2007 | 09:46 AM
Car: 1985 Trans Am
Engine: vee eight
Transmission: auto
thanks street lethal .
Old Sep 5, 2007 | 12:24 PM
Mikz86TA's Avatar
Car: '86 Trans Am and '03 S-10
Engine: 355ci and 4.3l
Transmission: 700R4 and NV3500
Axle/Gears: 7.625/3.42 Auburn and 8.5/3.08 Gov-
X2. Pull the carpet and sound deadener back. They are 10mm I believe.
Old Sep 5, 2007 | 02:45 PM
AmorgetRS's Avatar
The ones inside are actually loads easier to get to then the ones outside. Like other said, 10mm, and they are silver w/ rather large washers, iirc. They stand out pretty well when you pull the carpet back.
Old Sep 5, 2007 | 03:26 PM
OneManArmy's Avatar
Car: 1988 GTA
Axle/Gears: 3.70
or just cut them off like I did. though I always prefered the direct approach.
Non-A/C box went in just fine without them.
Old Sep 7, 2007 | 04:22 PM
carzar252's Avatar
Car: 88 camaro
Transmission: 5 spd
Axle/Gears: 10 bolt, 2.23
i just took the sawzall to mine and fabed up a sheet metal duct to make the heater work. (cut the fibre glass around the studs and pushed em through)
Old Sep 7, 2007 | 04:59 PM
rwdtech's Avatar
Car: 1991 Z28 (sold)
isnt that kind of stupid they way they made that
Old Sep 7, 2007 | 05:01 PM
Engine: 3.1
Not really. It's stupid that people are destroying these boxes because they're too lazy to figure out how to take it out.
Old Sep 7, 2007 | 05:45 PM
Car: 1985 Trans Am
Engine: vee eight
Transmission: auto
well guys i got it all done and it looks good , really good. I got my fiberglass ac delete box out that someone on here made for me a while ago . I reused my ac blower and blades. I cut the blades down so they would fit and did it all up , cut the old plugs off and hid the wires . You would never know their was ac except for the condensor which ill take out when i put a new engine in.
6speedIROC
16
Mar 15, 2023 08:33 PM
PurelyPMD
May 5, 2016 04:57 PM
tyeo098
Nov 30, 2015 06:27 PM
83 Crossfire TA
Sep 18, 2015 12:01 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
