what are city lights
Old Nov 14, 2007 | 06:03 AM
salfirebird92's Avatar
Car: 92 Firebird Formula
Engine: 5.0 V8
how is everybody,well my question is what are the city light and to what do I connect them. I'm putting them in my 92 FIREBIRD/here is the link http://cgi.ebay.com/ebaymotors/77-82...spagenameZWDVW
Old Nov 14, 2007 | 08:29 AM
Trustin's Avatar
Car: '84 Monte Carlo SS
Engine: BUILT original 305 H.O.
Transmission: 350
Axle/Gears: 373
Re: what are city lights
Do a search on Angel Eyes on the site and you will see several threads concerning this upgrade. From what I have read, the $25 ones on E-Bay are not something I would EVER put on my car!
Old Nov 15, 2007 | 01:57 AM
Engine: 5.0 V8
why whats wrong with them, and does anyone know what are the city lights and how to connect them
Old Nov 15, 2007 | 09:20 AM
Trustin's Avatar
Transmission: 350
Axle/Gears: 373
Ok, do a site search on city lights and you will find many threads like this one
https://www.thirdgen.org/forums/elec...-new-head.html
Old Nov 15, 2007 | 07:17 PM
Celticsfan's Avatar
Car: 1985 Trans Am
Transmission: 700-R4
i got them...stupid me $60 big waste...i cannot see **** at night its terrible, the stock were much better, come spring im definitly switching back to stock....
Old Nov 15, 2007 | 07:46 PM
ryan91rs's Avatar
Car: 1991 RS, 84 El Camino conquista RIP
Engine: 5.0 (for now)
Transmission: 4L60
Axle/Gears: 2.xx torsen limited slip & 3.42 ope
i got the silverstar ones and love them. They work great and are plenty bright on high but seem to be a little dim on the low beams but around the same as stock at least on low. they are about 75 for all four though.
Old Nov 15, 2007 | 08:11 PM
Celticsfan's Avatar
Car: 1985 Trans Am
how would those work for a firebird? Do they give off the blue tint? ( i dont want that)? or is it just bright white?
Old Nov 16, 2007 | 12:23 AM
Stephen's Avatar
Car: 87 GTA
'City' or 'halo' lights, are the colored ring AROUND the headlights, for when the lights are off. Since the headlight doors are closed on a Firebird, they'd be useless.
I got some H4s lights, that have a small 1156 bulb, for coloring the headlight bucket, for a similar effect, when the headlights are off. They had blue bulbs in them, when I bought them. I put clear ones in, just because I didn't like the blue r i c e r look of them in there. I got them used and cheap, that's the ONLY reason I got that kind. I didn't even bother hooking the tiny lights up.
Here are 'city' lights lit up...
Used for when the head lights are off, and useless for Firebirds since our headlight doors are closed when they are off.
Old Nov 16, 2007 | 08:26 AM
Celticsfan's Avatar
Car: 1985 Trans Am
i just want some brighter lights i dont care about the "city" look, i bought some cheap ebay ones and they suck
Old Nov 17, 2007 | 08:34 PM
Firebat's Avatar
Do what I'm doing. Get the aftermarket headlights on ebay, upgrade to at least 12 gauge wire harness(make a harness, with relays), put in high temp headlight socket connectors, put in brighter bulbs.
What I consider the city light is not the halo or angel eye. I will have the halo and the "blue" city light on at the same time. However, it will not be blue, but a colored LED bulb(haven't decided which color yet). I'm doing it more for show, like at night at the local hangout or at car shows. By no means would I use them to light up the road.
I have the 82-90 style headlight. I had to dremel(cut/grind) out parts of the stock-headlight-shell-thing to get the aftermarket headlights to fit.
I haven't figured out what headlight bulbs to get yet... I have heard of japanese bulbs being 150W+ but I would think that would start making things burn up.
Old Nov 18, 2007 | 12:03 AM
punkdude908's Avatar
Car: 1983 Pontiac Firebird
Engine: LG4 305ci 4bbl
Axle/Gears: 10-bolt open diff.
really? i put the hella vision plus conversions in my bird and didn't have to cut anything- it was a little but of a tighter fit but i was still able to get the retaining ring on and tightened up with no problems. what lenses did you use?
Old Nov 18, 2007 | 01:13 AM
subliminal's Avatar
What are you guys adding solenoids for? I upgraded to H4 bulbs and non sealed beam housings and I didnt have to touch the wiring. And the wiring stays cool to the touch.
Old Nov 18, 2007 | 09:19 AM
Celticsfan's Avatar
Car: 1985 Trans Am
pics? i already cut up the metal that holds the bulb housing, need to get a new one of those...
Old Nov 18, 2007 | 10:12 AM
83camaroMN's Avatar
Car: 1998 Mustang
Engine: 3.8L V6
Transmission: Automatic with overdrive
Axle/Gears: 2.73:1 axle ratio
I also got silverstars.
On low beam from a distance they do look blue, but up close they look like a bright white.
Old Nov 18, 2007 | 10:59 AM
Celticsfan's Avatar
Car: 1985 Trans Am
do they make a sealed beam i could use in the TA?
Old Nov 18, 2007 | 12:05 PM
Firebat's Avatar
I used the headlights off of ebay with the halo's.
The upgrading of wiring and adding relays is too get more power to the bulbs, and more light output. For an extreme example, you wouldn't use a 26 gauge wire to power a car amp.
I have heard of people using about 85 watt bulbs and melting the headlight socket connector.
Old Nov 18, 2007 | 12:54 PM
Celticsfan's Avatar
Car: 1985 Trans Am
is that what i need?
http://www.amazon.com/Sylvania-H6054...5411913&sr=1-2
i dunno if it comes with the actual bulb tho...
Old Nov 18, 2007 | 01:42 PM
Stephen's Avatar
Car: 87 GTA
The Sylvania Silverstars are the ones everybody is talking about. I'd say, 90% of my local club has converted over to Silverstars. Their good lights.
http://www.amazon.com/s/ref=sr_nr_p_...a%20SilverStar
Old Nov 18, 2007 | 03:29 PM
the sylvania silverstars are ok.....
i just upgraded to Osram silverstars (the European parent company of sylvania) and they're a LOT better!! clear glass bulbs with a UV filter coating and xenon gas inside. its really an awesome bulb- and WAAAY brighter than the sylvania version. and the best part is they're not amber- they're bright bright white- and they supposedly don't dim over time like normal bulbs (that's what i heard anyway). i'd recommend these bulbs 100%.
http://www.osram.com/osram_com/Consu...TAR/index.html
http://www.care4car.com/productdispl...non_Bulbs.html
http://casporttouring.com/thestore/prods/17184.html
Old Nov 18, 2007 | 03:47 PM
Celticsfan's Avatar
Car: 1985 Trans Am
ok will this fit the metal piece for the headlight w/o modification? i had to cut mine up for my crappy ebay ones.... and that comes w/ housing and bulb?
Old Nov 18, 2007 | 03:52 PM
Firebat's Avatar
I got Silverstars in my 92 and they fit with no problems, I would imagine 82-90 would be the same.
Old Nov 18, 2007 | 06:09 PM
Celticsfan's Avatar
Car: 1985 Trans Am
ok cool, ill be getting them then
Old Nov 18, 2007 | 06:25 PM
Stephen's Avatar
Car: 87 GTA
Bolted right into my 87 GTA, zero mods needed.
91/92 have different sized headlights, but I'm sure Silverstars are made for them too.
Old Nov 18, 2007 | 06:31 PM
Celticsfan's Avatar
Car: 1985 Trans Am
ok, ya i had to modify the black metal where the housing goes too...probably cuz they were crappy ebay lights, do you have any pics of your lights?
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
383cam
Sep 9, 2015 06:01 AM
TBRays98
Sep 6, 2015 05:05 PM
Jetmeck
Sep 4, 2015 12:29 AM
luvofjah
Sep 3, 2015 07:08 PM
