Cleaning stock lace wheels
Old Mar 20, 2008 | 12:32 PM
devilish1's Avatar
Car: 88 T/A, 03 cobra
Man I hate cleaning wheels, and these stock lace wheels on the 88 t/a are the worse. Being a white wheel isn't any better lol. What is the best way to clean them? I know that these spray on wheel cleaners can be harsh on the finishes but is there a good cleaner out there that won't take the paint off of the wheel?
Old Mar 22, 2008 | 06:09 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Re: Cleaning stock lace wheels
Simple green and a toothbrush Seriously, that's the best method I've found. You could probably use a larger plastic-bristled brush to get it done faster.
Old Mar 22, 2008 | 07:45 AM
devilish1's Avatar
LOL That's really not what I was wanting to hear. Did you get the part about Hate cleaning wheels. I may try the simple green but I'm not doing the tooth brush thing
Old Mar 22, 2008 | 11:01 AM
88blkiroc's Avatar
Car: 88 IROC-Z
Transmission: TH350
Axle/Gears: 3.45
I havent tried simple green on wheels but it works good on other stuff. The best wheel cleaner I have found is Meguiers Hot Rims. It works great on my wheels. I dont know if I would use it on bare aluminum as it is an acid but if your wheels still have the original clear coat and paint it should be just fine. Gets rid of brake dust and other road crap without having to scrub unless you wheels are really really dirty.
Old Mar 23, 2008 | 07:37 PM
scribbles's Avatar
Car: 88 gta
Engine: 350 tpi
I use the hot rims stuff on my gold lace rims, and a babby botle brush, they look great.
Old Mar 23, 2008 | 08:19 PM
FueledSoul's Avatar
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
Have you tried clear coating them once there clean? sometimes that helps at least the dirt and road grim wont stick as back and it would be some what more easy to clean if they did
Old Mar 24, 2008 | 09:47 PM
FYRCHKN's Avatar
Car: 1988 SC Convertible
Engine: LT-1
Axle/Gears: 3.23 posi w/PBR's
Plain ol Bleeche-White....makes your letters on your tires white, cleans the tires, and cleans up the wheels nicely too. Just spray it on, let it sit for 20-30 seconds, and hit it with the pressure washer. It leaves everything clean.
It's dirty cheap if you get it at the dollar store.
Old Mar 28, 2008 | 07:24 AM
devilish1's Avatar
Thanks guys. I'll try them out.
Jeremys87
Jul 14, 2022 09:08 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
kah992
Aug 19, 2015 02:55 PM
mustangman65_79
Aug 9, 2015 03:00 AM
