Need opinions on how my car looks
Old May 7, 2008 | 06:32 PM
dpmalibu's Avatar
I just put some Weld Draglites on my car. I have 15x8's all around for now. I plan on going skinnier in the front later. I couldn't find any 15x5's or 15x6's used when I bought these. I may just go to 15x3.5's so I can get the look I want. Any do you guys think I should leave my car lowered 2" the way it is now or raise it back up to stock? I have 275/60's in the rear and 225/60's up front. Let me know.Thanks
Old May 7, 2008 | 06:41 PM
white91formula's Avatar
Car: 91 formula
Transmission: t5
Re: Need opinions on how my car looks
leave it lowered, it looks good the way it is
Old May 7, 2008 | 08:36 PM
IROCJoyce's Avatar
Car: 1987 IROC
Engine: 350 Gm H.O
Transmission: 700r4 built
Axle/Gears: 3.42 Locker
Wow those are some fat tires. I like it!! Leave it the way it is. You got a perfect runner.
Old May 7, 2008 | 08:50 PM
sailtexas186548's Avatar
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
dude that looks good. looks simple but fassssst
Old May 7, 2008 | 09:45 PM
BADNBLK's Avatar
COTM Editor
She looks real good, but you need to see ROLL BAR down bars in that back window to complete the look!
Really it looks ready for battle.... Is it?
Old May 7, 2008 | 09:46 PM
avro206's Avatar
Car: 89 Formula
Transmission: TH 700R4
is the car mostly for drag racing?
Old May 7, 2008 | 09:48 PM
campin1983's Avatar
Car: 1984 Camaro 'Vert
Good look, definitly looks ready for battle. Don't raise it back up, the skinnier front tires would leave too much empty space exposed. Looks great where it is.
Old May 7, 2008 | 10:28 PM
84z350crate's Avatar
Car: 84 Z28
I like
Old May 7, 2008 | 11:52 PM
Xoferif's Avatar
Car: '91 Camaro RS
Engine: 3.1L
The rear looks too low to me...but other then that, looks great!
Old May 8, 2008 | 01:24 AM
karl's-92'-z28's Avatar
Car: Too many cars
Looks good I would leave those front rims, easier to turn if its a DD. I would change the taillights though, put a bowtie grill & some fog lights for that nasty look.
Old May 8, 2008 | 06:41 AM
dpmalibu's Avatar
Thanks to everyone who replied. Its a street/strip car. It currently has a ZZ4 in it backed by a T-5 and a 7.5" rear with Moser axles and 3.73's, subframe connectors and Spohn suspension parts(Still have to install most of this stuff.) It fast enough for now until I can get some more $$ together for a stronger rear and probably a cam and possibly a head swap but that's much later down the road. I am hoping for low 13's maybe a high 12( on a perfect night) if it hooks up. Here's a pic of the motor:
Old May 8, 2008 | 07:24 AM
avro206's Avatar
Car: 89 Formula
yeah don't like the rims. Typical drag race fare I guess. Nice colour though
Old May 8, 2008 | 07:52 AM
luvofjah's Avatar
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
Looks mean and ready for business...
Raf
Old May 8, 2008 | 11:13 AM
18inchboyds's Avatar
Car: 1985 Trans Am
Engine: vee eight
Transmission: auto
Axle/Gears: 4.10 gears
get an ac delete box and get a new rad overflow canister or get an aluminum replacement , i forget who makes a direct fit stock looking aluminum one . but the outside looks good . im sureprised your tires dont rub the lip .
Old May 8, 2008 | 12:12 PM
8T9 BANDIT's Avatar
Car: 1989 T/A
Engine: PROCHARGED LB9
Transmission: FB BUILT 700r4 2200 stall
Axle/Gears: 10 BOLT EATON 3:73 POSI
http://www.tpis.com/index.php?module...ing+Components is that it?
sorry,, hit "next page" about 3-5 times and youll see it.
Old May 8, 2008 | 12:18 PM
GoodlookinRS's Avatar
Car: 1986 corvette Z51
Transmission: doug nash 4+3 speed
Axle/Gears: 3:42 posi
I think it looks very good but if it was me i would raise the back end of the car up like 1-2 inches so it not right on the wheel.
Old May 8, 2008 | 01:43 PM
Oscar's Avatar
This is the first 3dgen I've seen with 15" wheels that I really like. I like the 2" drop, I would leave it. I also like that the rear is more tucked then the front (asymetrical). The car looks very stout. The photographs themselves are bad and don't do the car justice.
dpmalibu's Avatar
I went with Draglites because that's the look I am going for. More of a drag race musclecar look. It did have 17" late model Camaro SS 5 spoke wheels but I sold them. The car actually had an A/C delete plate but I took it off because I want the heat for the late fall early winter due to I will still drive it when its cold.Finally I plan on raising the rear just a hair (as long as it not more than about 1/2"-3/4")with some rubber coil spring spacers just to get the tires away from the wheel well lip. They don't rub but they are close probaly about 3/4"-1" space. I am going to roll the lip for added clearance.Thanks for all the comments.
Old May 8, 2008 | 01:53 PM
Ya if you do that put some more pics up i think it would look better to me atleast.
kevin
Old May 8, 2008 | 04:13 PM
motorheadmike's Avatar
Car: Cars
Engine: Slow stuff...
That thing needs skinnies w/165R15s in the front BAD! Other than that it looks fine.
onefreakz
May 14, 2018 12:15 PM
Reddeath210
Oct 6, 2015 08:20 AM
camaro71633
Sep 1, 2015 10:24 AM
Linson
Aug 21, 2015 02:12 PM
1992 Trans Am
Aug 9, 2015 04:32 PM
