Post pics of your Street/strip third gen!
Car: '82 Z28
Re: Post pics of your Street/strip third gen!
Fronts, ARP 100-7708
Rears I don't remember but switched to a 1/2 inch stud.
Car: '89 IROC-Z
Engine: 355
Transmission: 700r4 edge 3000 stall
Axle/Gears: 9-bolt 3.73
12x1.5 is the stock length IIRC? Do you use the mag shank lug nuts?
Car: '82 Z28
For the Weld wheels yeah, needed to use the shank style. Stock wheels use the regular ones, just open ended in my case because of the long studs.
Car: gm/ford/on here 92 25th RS
Engine: 6.0 LS2-stolen
Transmission: 4L8oe-stolen
Axle/Gears: gm 12- 373/eaton-stolen
she is no rocket. our local track sucks for weekly test and tune. and to rent the track it costs more than entering the world street nationals, so i entered in heavy street. i ran a 28x10.5 slicks against all these big tire cars and i qualified 33 ofa 32 car field 9.51 and the bump was 9.50 something.
this years i should have ran the street finals nad entered my car, ther was only 28 cars in heavy street. it would have been a guaranteed 1st round
your car is bad ***
Car: 85z28
Engine: sbc
Transmission: th400
Axle/Gears: 3.80 gear 35 spline axles
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
Engine: 360 HSR
right now i'm in the middle of painting it. the engine bay is done. next up is the door jambs and rest of the under carriage. the entire car will be black with gun metal grey stripes and ground effects. drivetrain i want is a 6.0L engine and trans from a escalade/avalanche and put a magnusson supercharger on it. going for around 600 rwhp.
Car: 85z28
Engine: sbc
Transmission: th400
Car: '89 IROC-Z
Engine: 355
primered camaro + rally wheels and RWL tires = bad ***
Car: One of 5
Engine: LB9
Back from the dead. I didn't want to post pics till I was at the strip
1st burnout, car hadn't been driven except onto trailer before getting to the track.
Well guys i have been doing ALOT of thinking, about redoing my 92.
Or just looking for another shell and starting over. The problem is that the car has alot of sentimental value, and i don't ever plan on selling it!
So I'm not worried about resell and recouping my money. But i will have to dig up the pics of it, and let you see just how bad it is. Maybe you can help with my decision on what to do..
soo.... What ya think ?
Car: Had 2 iroc-z's . An '87 & '88.
Engine: HAD 5.0 & 5.7 tpi
Axle/Gears: stock
What happened to it? Maybe you can buy a donor car and swap the drivetrain and body parts to it.
I had it at my buds shop/ yard it was indoors, while i was working out of state.
During this time he was going thru a divorce.
And while he wasn't there, it was stripped the ls2 drive train i had was also taken the motor you see there is a 400sb mover motor. I use to move the car to his place. I had BMR track PAC suspension on the back with a 12 bolt with disc brakes, that was stolen! As you can see basically they cut everything out the car! Its still solid underneath, and only have surface rust in a few spots. Truth be told i get 4 stories every time i ask about it.
I feel it was an inside job and some knows WAY more then they lead on about, but with no proof I'm kinda s,o,l! So i said the hell with it i have to start over! I have had this car since i was 17 I'm 28 now. I have had alot of fun with her, but it hurts to see it like this .. And i got to do something fast.
Car: 1989 Camaro RS
Engine: LH6
Axle/Gears: 3.42 Auburn Posi
Axle/Gears: stock
good luck with wat u decide
Yeah this car mean a lot to me. So I just wanted to see if I was being crazy.
Truth be told, it's the car I had when I met my fiance. She loved that car and was more into building it then i was at the time. We named her Jezza, and often said she was my mistress, (Hence the name lol). She made me promise. No matter what happens! We would fix her, I would never get rid of her, like I had done with almost all the cars before it!
I laughed, but she was serious. So I agreed and behind her back i bought her a 89 GTA, white t-tops TPI 350 tan leather, that I was going to give to her on our Anny.
Then she passed away unexpectedly. in a accident. I couldn't look at the GTA with out crying and fallin apart! So I got rid of it but I could never bring myself to get rid of the camaro cause i made a promise.
But with all that has happened with it since I thought I was being naive.
Thanks for your help. . .
Car: 1986 Camaro SC
Engine: None
Transmission: None
Axle/Gears: Moser 9" W/ spool 3.50 gears
Car: 1992 Camaro RS
Engine: 305 TBI
Axle/Gears: limited slip
Car: One of 5
Engine: LB9
Car: 1989 Camaro RS
Engine: V6 - LS Swap Incoming
Transmission: 700R4 - T56 Mag F Incoming
This was my street car years ago.
Actually it was my first car me, my father, uncle and grandfather painted it one summer with ghost racing stripes. Here's the pics.
It's an 89 Camaro RS V6 Auto.
Car before sanding. Me at age 16.
Prep Work and Sanding:
The End result:
Another angle can't see the stripes now can you? I loved those ghost stripes.
And lastly a clear shot of the front before the headlights were put back on.
The End result:
Heres mine: MY bolt on STOCK TURBOED Syclone runs 7.70 at 88MPH ( IT EVEN PASSES GA EMISIONS!!!), 1.6 60fts (I KNOW ITS NOT A THIRD GEN BUT ITS BLOOD RELATED!!)1/8th and the 86 Iroc runs 10.6 in the 1/8th
( STOCK 305 quadrajet engine with 3.73 gears!)
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Ill post mine in a bit. She isn't all that mean lookin though.
Car: 91' bird(WS6>>305TBI), 82'Regal
My work in progress > 305TBI > Engine runs great! Trani >> not so much!
Not going to the track anytime soon. 305TBI
> Trani slippin when cold into 2nd gear.
>> I hope that sense it only slips when cold that I can just throw in a new TV Cable and be O.K. Any thoughts on that last statement? Thanks!
>> I hope that sense it only slips when cold that I can just throw in a new TV Cable and be O.K. Any thoughts on that last statement? Thanks! Member
Car: '91 RS, '72 Pro/Street Z28
Engine: 305 TBI, Blown 468ci w/NOS
Transmission: 5 Spd, 2 Spd Powerglide
Axle/Gears: 3.08, 4.88
Come on guys, let's see some more of those "Street/Strip" cars. (This thread's been dead for a while)
Here's a couple badass 3rd Gens that I found online. (Plus a few of my '72 Pro/Street)
And here's a few of mine.......................
Car: 1987 Z28 Camaro
Engine: 5.7L TPI
whoa! man that's one badass pro street! i love that stance.what kind of times at the track? i bet you get all the attention when you drive it on the street
It runs low to mid 10's on the motor, and low 9's on the nitrous.
Engine: 5.7L TPI
your sig says that the engine started out as a 305! is that right? i didn't know that you could make that kind of horsepower using a 305 block
I don't have any dyno numbers on that motor. I'm guessing it was probably around 700 HP,......somewhere in the 950 HP range on the nitrous. (325 HP Wet System) I should have some exact numbers this June when the new motor is done. I actually just pulled it out a couple weeks ago to rebuild it and make some well needed upgrades. (ie. new solid roller cam & lifters, (.758 lift, .321 duration) new crank, ported & polished heads, etc..etc...) It should easily make 800 on the motor when I'm done. I won't be running the nitrous on it anymore since I've now retired the car from full-time drag racing. It's now going to be an 90/10 street car. (90% Street, 10% Track) I'm sure I'll probably take it out and run it once every other month. There's no way I can just quit cold turkey.
Engine: 5.7L TPI
oh,ok now i see. guess i need to pay closer attention to what i'm reading. hey maybe you can answer a question i asked over in the "engine performance help" thread. would you check it out and respond please?
Engine: 5.7L TPI
hey Zachkuby87 i love those wheels man! what are they called? want some of those on my 87
Car: 1985 iroc z
Engine: 350 .30 over
Transmission: t-5
Axle/Gears: told aftermarket moser 3.73 posi?
theyre kmc stealths theyre a disconinued rim though so good luck i searched for a set for a while i found mine at a pawn shop for 200 bucks with tires 275/35/18
Linson
Aug 21, 2015 02:12 PM
Ummm, ok? Here's a couple with the hood on the car.
