Engine bay paint?
Old Nov 12, 2008 | 11:54 PM
BrOdBaNd's Avatar
Car: 92 Camaro
Engine: El Tee Juan
Transmission: Tee five six
Axle/Gears: 10 Bolt 4:10's
Engine bay paint?
Ok, so within this next month, I am going to be putting my new motor in. While the motor is out I was thinking of painting the engine bay. I dont have a garage to work in, and I was wondering the best way to do this and to still have it look good. My plans are to do it flat black.
Old Nov 13, 2008 | 10:59 PM
FueledSoul's Avatar
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
Re: Engine bay paint?
Something cheap and fast? degrease the bay using what ever you thinks going to work best I.E degreaser, carb cleaner, soup water or a combination of all of them, then blow out what watter or cleaner you can and whip the bay down. Your going to want to scuff up the bay so use about 220 grit sand paper after you scuff everything up blow out what you just sanded and use a paint prep to remove any left over grease or particles, then primmer, sometimes youll be left with some over spray so use a tack cloth and go over the bay lighty, then paint - this should give you a decent looking bay and its defiantly on the cheap and fast side
Old Nov 13, 2008 | 11:09 PM
FueledSoul's Avatar
Sorry i meant 220 to 400 grit sand paper
Old Nov 14, 2008 | 09:20 AM
tavert91's Avatar
Car: 91 Trans Am Convertible
Engine: LB9 5.0 TPI
Transmission: 5 SPD
Axle/Gears: Posi Rear
What color is the car and the current engine bay and what type engine are you installing (rebuilt original, crate, racing, etc.)? Flat black might be good, but I think color works well unless your plans are for the track. Anyway, prep of the existing paint is the key after all those years. Take some extra time getting the old oil and grease off (especially in tight spaces), prep sand like "FueledSoul" suggests, and you will end up with something that will last and not be very expensive.
Old Nov 14, 2008 | 11:53 AM
BrOdBaNd's Avatar
Car: 92 Camaro
Engine: El Tee Juan
Its a medium quasar blue 92 RS. Im installing a built lt1 t56
Old Nov 14, 2008 | 11:55 AM
BrOdBaNd's Avatar
Car: 92 Camaro
Engine: El Tee Juan
This was my engine bay, the day I got my car ahaha.
Old Nov 14, 2008 | 01:25 PM
87_GTA_5.7's Avatar
Car: 1987 Pontiac GTA Trans Am
Engine: Basic Stroked SBC..383
Transmission: PerformaBuilt 700R4 3000 Stall
Axle/Gears: Moser 9in. 3:70s
I went to bare metal..Then etching primer, then primer..then sealer adn finally I went with single stage black with 50-60% flatner
Old Nov 14, 2008 | 06:10 PM
FueledSoul's Avatar
Heres a few before and after shots of my bay i really took my time to do it right
(before)
(After)
Old Nov 15, 2008 | 01:27 AM
BrOdBaNd's Avatar
Car: 92 Camaro
Engine: El Tee Juan
Damn those both look frickin good. How did you do yours fueled?
Old Nov 15, 2008 | 01:33 AM
FueledSoul's Avatar
Heres a link, theres some info there too
https://www.thirdgen.org/forums/cama...art-finsh.html
Old Nov 15, 2008 | 09:28 AM
BrOdBaNd's Avatar
Car: 92 Camaro
Engine: El Tee Juan
Man I dont even know how to paint with a paint gun. I wouldnt know where to start.
Old Nov 15, 2008 | 11:10 AM
FueledSoul's Avatar
Can you lay down smooth and even coats with a can of spray paint? you can practice feathering to a degree with a rattle can if you can do that the only real hard part to a paint gun is setting it up and even thats pretty simple.
you also have to realize its just a engine bay its not like its the exterior. If you stick with your organelle plan i think thats more what you where looking for anyway? i think you'll still be happy with the end results
Old Nov 25, 2008 | 02:16 AM
allenfre's Avatar
(before)
(After)
That paint job was very clean! I can never attain this paint job quality all by myself. I use to have my uncle by my side doing the this thing.
Old Nov 25, 2008 | 03:17 AM
88iroc52387's Avatar
I'm a fan of por-15 no need for spray althoguht it would turn out nicer and no worries about rust. Fueled souls is straight beautiful but like u said i don't have that ablitiy. I'm also not sure what color i want the outside to be so i'm doing black so it won't matter. Every inch of my car that thats not going to be the final color is getting painted with por 15. But i'm rust paranoid (ohio snow belt and the prevoius owner stored it outside for the past 2 years). If your not worried about rust, just prep the hell out of it, smooth, etching primer, and flat black of your choice.
Old Nov 25, 2008 | 05:34 PM
allenfre's Avatar
Yeah, it works best for seasoned metal surfaces. Keep us posted dude
Old Nov 25, 2008 | 06:12 PM
89RS_82Z's Avatar
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
you can get flat black or simi gloss black engine paint at advance auto and do a good job with it.......i can make that stuff look like it was spayed with a gun, put a good primer on also
Reddeath210
Oct 6, 2015 08:20 AM
Polo Z03
Sep 10, 2015 06:43 PM
AkDrifted
Aug 17, 2015 07:45 PM
jahblah
Aug 12, 2015 05:54 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
