Problem w/ headlights
Old Jan 6, 2009 | 06:49 PM
MikeSmith0890's Avatar
Car: 1983 Camaro Sport Coupe
Engine: 2.8L, hopefully upgrading..
Transmission: BorgWarner T5, Made here in Muncie
Axle/Gears: stock
Okay, when I bought this car almost a year ago the guy told me he just replaced all 4 headlights but that there was still a problem with the brights. Whenever the brights are on for 5 minutes or more they start to flicker and then shut off altogether. After doing this twice it has started to affect my low beams as well. After driving for about half an hour so my low beams start to flicker. Any idea what could be causing this? I can't figure it out.
Old Jan 6, 2009 | 06:58 PM
hot92RS's Avatar
Car: 92 Z-28
Transmission: THM700R4
Re: Problem w/ headlights
I don't believe you are posting in the right thread, did you do a search on the tech/general engine or electronics forums? I have heard of this problem before. Don't know the answer but try searching if you have not already.
Search under Tech/General engine-"flickering headlights". I see you are new to this site, hope that helps.
Old Oct 20, 2009 | 01:26 PM
'84 Z/28's Avatar
Car: 1984 Z/28
Engine: 350 V8
Did you ever figure this out? Because it sounds like you have the exact same problem as I am trying to deal with right now. ...Not safe at all...
Old Oct 20, 2009 | 07:09 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Sounds like the old wiring isn't capable of handling the load of the lights. I'd get a relay, connect the lights wire into the relay, and make new headlight wiring harness with larger (smaller guage) wires from the relay to the lights - that way the lights are getting juice straight from the battery when the relay is activated by the switch, and getting juice through more capable wiring.
Old Oct 20, 2009 | 08:19 PM
Sinister Z's Avatar
Car: 1985 IROC-Z / Z-28
Engine: 383 C.I. Stroked 6.3 Litre
Transmission: 700R-4
Axle/Gears: 3:73 Posi
I think that you might need this... http://www.summitracing.com/parts/GR...3/?image=large
Old Dec 12, 2009 | 04:19 AM
Axle/Gears: stock
No I still haven't figured this out. I'm going to look more into the harness from Summit, looks promising. I finally got the car back on the road again after 3 months so now I need to get back to work on those lights.
Old Dec 12, 2009 | 12:14 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Your car by any chance doesnt have those shitty H4 conversions, does it.They can cause this too.
Regardless the circuits are being overloaded & causing the lights to flicker.So as mentioned check your wireing & upgrade if necessary.
1992CamaroGirl
Dec 25, 2017 08:45 PM
tyeo098
Nov 30, 2015 06:27 PM
sylentnite
Sep 9, 2015 02:55 PM
andy74
Sep 3, 2015 08:41 AM
Fronzizzle
Aug 17, 2015 02:52 PM
