Best Double Bladed Wiper Blades
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
I know this topic has been talked about alot. But what are the best and what the worst? Do they still make Rallye Double Bladed wipers? Do the Rain-X Latitudes/Trico Neoform style wiper blades work? I am looking for some double bladed wipers. Is Rallye still in business?
Car: '91 TA vert
Engine: turboLSx
Re: Best Double Bladed Wiper Blades
I'd reccomend anything but those "double blade" wipers. Hell, even a plastic bag over the bar arm would probably last longer than those things. Bosch Icons won't attach to our pin style wiper arms. Which means you can either swap wiper arms or go with another manufacturer like Trico that makes a blade called the Neoform that is similar. I haven't tried it but it's built the same, not saying anything for quality.
Car: 2012 Corvette
Engine: LS3
Transmission: TR6060
Those things are junk and look dumb too in my opinion. If you want the best wiper blade, go buy the AC/Delco blades from the dealer. Those are the best blades I've found that work with the pin style. I really like the Bosch Icons, but as iansane said, they only work with the newer hook arms.
silblade a silcone wiper blade
https://secure.eventurestudio.com/ww...ucts/index.cfm
Rally
http://www.oemsurplus911.com/automotive/wipersrally.htm
Rally
Car: '91 TA vert
Engine: turboLSx
By no means a bolt on mod, but subtle and simple.
Car: 90 Camaro RS
Engine: V6 3.1 MFI
Transmission: 4 Speed Auto 700R4
I was think about this today, as the rainy season is coming up. I have never used AC/Delco blades but I've used many AC/Delco parts so I well probably try those out but nothing grabs my attention more then an upgrading swap.
So I'd like to know more about a wiper arm swap if anyone has done it!
-edit-
I was to slow to post
Would 4thgen wiper work. Would they have the new pin style and the shape?
-edit-
ppl i bought my car from put those dumbass doubled bladed wipers on. stretched the springs out so i had to replace the wiper arms when i put latitudes on
Car: 90 Camaro RS
Engine: V6 3.1 MFI
I just checked and it seems that the 1998-on Camaro is able to use ICON Front wiper blades. But not the 1993-1997.
Car: '91 TA vert
Engine: turboLSx
The 93-97 fbodies use a weird blade. It's a hook style, but reversed. The 98-02 have the standard hook style but they're LONG.
If you just wanted to swap the whole arms I have no idea what you'd grab them off of. I pulled mine off of an early 90's cutlass or bonneville or something, not sure.
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Classic has Havoline Silicone wiper blades, but they are unversal fit.From 14-22 inch lengths, 10-$12.I remember buying these several years ago, but not from them.I forget who from, but they are still working very well.Except one leaves a streak across the windshield.They are about 5-6 years old though.
Car: 1991 Camaro RS Convertible
Engine: 305 V8 TBI
Axle/Gears: 4.1
I realize this does little good for those south of the border, but I run Motomaster (Canadian Tire Brand) Reflex wiper blades on all three of my current vehicles, as well as past vehicles. They're blades that don't have the usual metal hinge mechanism..they're very flexible, and don't ice up in the winter. They also hug the window, and are a lower profile than most of the usual design wiper blades, reducing chatter at speed.
I think Armor-all and RainX both make blades of a similar design, though, so shopping around might be your best bet. I've had nothing but luck.
Car: '91 TA vert
Engine: turboLSx
Car: 88 IROC-Z
Transmission: TH350
Axle/Gears: 3.45
I have the Trico Neoforms on my Firebird and they work well. After selling almost every brand of blade from my shop I think the best are the originals from the dealer. They last the longest.
Car: '91 TA vert
Engine: turboLSx
9 out of 10 wipers I sell are A/C Delco blades, not the original (which are typically made by trico). The AC blades, SUCK.
Car: 1983 Pontiac Firebird
Engine: LG4 305ci 4bbl
Axle/Gears: 10-bolt open diff.
i swear by the rain-x latitudes. i've had them on my '83 for over a year and a half and they still wipe like they're brand new. i have a replacement set but i still don't need them. they're a little pricey but it's worth it.
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
I have the Rain X Latitudes. Great wipers, no mods.
Do you guys have photos of the rainx latitudes on your car
thank you
but does stay on tight like the standard wiper or does it wobble like crazy
nope they're perfect. i've gotten stuck in quite a few storms where i've been glad i had the latitudes. in my opinion, they make all the difference.
Did you ever drive your car in the snow?
hah yea all the time in the winter. its snowing here right now. they're just as good in the snow. WAAAY better than conventional blades in every aspect.
Awesome and it is snowing here in Boston too!!!
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: A/T
By far the best blades I've used of late are the PIAA ones. they have lasted the longest and had the most chatter free operation over the years. I've tried silicone treated blades, factory original (second best option for me), and just about every other combination. My PIAA's have been excellent and lasted a long time (nearly 2 years now). Not sure they are great snow blades for those with that concern, but for the little bit of snow we get here they have been fine.
Silblade is supposed to be the better than PIAA and lasted two years as well. I found a review for Silblade
http://www.4x4wire.com/reviews/silblade/
http://www.4x4wire.com/forums/showfl...71&Main=632965
Car: 92 Z28
Axle/Gears: 3.73 10 bolt
The first gen Trico's with the single piece assembly (I believe it was called innovision) sucked major. They lasted about a month and then the rubber blade separated from the assembly.
The newer Neoform ones are very good though. I've had them on my car about a year and a half and they are still working very well. Definitely worth the money. I have the Icon's on my other vehicle and can tell a very slight difference (the icons are a touch smoother, but they are also on a better engineered arm) but it is definitely not worth swapping the arm out for.
Car: 1991 Formula Firebird
Engine: Pontiac 355 stroker (305 TBI 4Sale)
Transmission: Pending Manual , 700r4 for sale...
Axle/Gears: Stock... for now
Don't have to worry about snow here in Florida, But there's a Helluva lotta rain! I use the PIAA blades on my Truck, (Combined with the Rain-X Spray on stuff) and sometimes, I forget it's raining.
Double bladed wipers are dorky and Don't do much more than kill wiper arms, and waste your money... Just use that money on the NeoForms or PIAA's. Junior Member
Car: 1986 Camaro IROC-Z
i recently installed RainX Latitudes and they work beautifully. i just forgot to buy one for the rear window.
wigmobile
Feb 26, 2025 02:56 PM
skinny z
Oct 5, 2015 06:23 PM
