hard water stains??
Old Jul 19, 2001 | 01:05 AM
Derek91z28's Avatar
hard water stains??
i just got a new paint job and my car is black. My sprinklers in the front yard are on well water and while i was on vacation they sprayed my car for a week straight and i can;t get out the hard water stains with just soap and water do you guys know any trciks?? needless to say i cleared out my garage and started putting my car in there after this incident. also i was thinking of reclearing my z 28 rims what kind of prep would i need to do to get them ready to reclearcoat. The clearcoat is peeling off and the front rims don't shine as well as the back ones any one ever done this. thanks.
Old Jul 19, 2001 | 07:22 AM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
try washing the car with hot water. If that doesn't break down the water spots, you might need to try an abrasive, like waxing the car. If neither of these work, try a professional grade clay bar. I would think that the hot water and some good car wash detergent will do the trick.
87 IROC 350 TPI with less than 10k original miles
93 Z28 Pace Car #494 of 645
86 Olds 442 (All Original)
My IROC Website
Northstar Camaro Club of Minnesota
Old Jul 19, 2001 | 07:55 AM
Chuck Everly's Avatar
Add some white vinegar to your soap water.
88 IROC convertible
-=ICON Motorsports=-
Old Jul 22, 2001 | 08:50 PM
Pete92TA's Avatar
clay bars work good for deep cleaning cleaned my bird made it perfectly smooth. First used my dri-wash"http://dri-wash.com/eti/driwash.html" stuff then the clay worked out good. You can order 8oz bottles of the dri-wash. Just tell them you want to sample it first. Or go with clay majic your choce your car. A quick fix you could try is meguires quick detail usually about 5-$7. I used to have the same problem thats why I use the dri-wash stuff, because I have well water also.
Old Jul 23, 2001 | 02:13 AM
Blue_Meanie86SC's Avatar
I tried the meguiars stuff, didn't work with a hoot, I just finished polishing with a 3M product I found at Wal Mart, can't remember the name, I'll get it to you tomorrow. Anyway, it got rid of all my hard water spots, I went over it with a flourescent light to make sure, looks better now than when it got a new paint job last winter
Old Jul 23, 2001 | 04:08 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
The water probably etched the wax on your car. Use some sort of polish (make sure its true abrasive polish) and polish the spots until theyre gone, then re-wax the spots.
1983 Firebird
TH700R4 Auto
Small Block 400
LG4 ECM, Intake, Carb, Distributor, etc.
Soon to be non-computer.
Clarion Head Unit 45X4
2 Pioneer 400W 12" Subs
Third Gen Performance
"A four cylinder is half an engine."
Old Jul 23, 2001 | 12:01 PM
the one I used is called "finish restorer" it came in a little bottle (I think 8 oz) and was more than enough to do the whole car. The flourescent light is the trick to seeing all the spots, those babys show every imperfection in a paint job.
Old Jul 24, 2001 | 01:31 PM
pred1tor83's Avatar
Hate to say it but polishing takes alot of time and stuff, but i think that if you used regular house hold viniger, bout 50/50 w/ water it would take it right out, it did on my big black truck that was niglected for 17 years. . . after you do viniger get some wax and spend the whole day waxing and polishing!
Old Jul 24, 2001 | 07:35 PM
Mo's Avatar
Mo
I had to clay bar the **** out of mine when I got water spots on it
Old May 30, 2003 | 10:30 AM
cgacfox's Avatar
I have the water spots on my windows. Will the vinigar mixture work on the windows as well? I have removed the louver that was on the back window. My husband is going to repaint it because it has faded over time. The back window is the worst because the previous owner never lifted the louver to clean the back window. Please let me know if the vinigar will work or what else I could use. It seems to be on the inside as well as the outside. Thanks.
Old May 30, 2003 | 03:20 PM
iroczrockz's Avatar
Car: 91 RS Camaro
Engine: 305 TBI
Car wax (paste) should do the job for the window too.
Old May 30, 2003 | 03:35 PM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
Mothers prewax cleaner works great on water spots. Both my IROC and S10 have black paint and this stuff always works.
Old May 30, 2003 | 04:16 PM
heavy_chevy29's Avatar
Car: 84 camaro Z28
Engine: 434sbc
Transmission: powerglide
Axle/Gears: moser 9" with 411 posi
used hand glaze. that should take it right out.
Old May 30, 2003 | 09:30 PM
82camaro's Avatar
Car: 82 camaro SC
vinegar is the easy way. It will remove them without any problem and isn't abrasive . It's the only thing that would remove 25+ years of hard water from the picture window on my house after we moved in.
69GTOby
Apr 18, 2016 02:34 PM
codeysabatini
Nov 10, 2015 04:07 PM
Dwayne614
Sep 29, 2015 11:05 PM
Breazlan
Sep 25, 2015 11:20 AM
84redta
Sep 19, 2015 09:58 AM
