91-92 Camaro without gfx
Old Mar 21, 2009 | 07:00 PM
RU1NER's Avatar
Hey guys, I looked on here and on google for pictures of a 91-92 camaro without gfx because i was contemplating removing mine cause their a little beaten up. Does anybody have pictures with their's removed? Thanks
Old Mar 21, 2009 | 09:57 PM
Jonboy2312's Avatar
Car: 1986 SC based 82-84 Z28 replica
Engine: 2.8 V6 MPFI
Transmission: TH-700R4
Re: 91-92 Camaro without gfx
You could get away with it if you also installed a Sport Coupe front end with no airdam whatsoever. The 91-92 front airdam is way too low and protruding for a car with no gfx and will look seriously out of place. Sort of like a bulldozer or a snow plough.
I don't have any photos of 91-92's with no gfx, but here's some of an 82-84 Z28 front end on a non-gfx car:
Keep in mind though that the 82-84 skirts were far, far slimmer and more subtle, including the air dam. Those early cars can get away with the 'chins' on and no gfx, but anything 85 onwards... no. Just look at that photo and imagine the air dam being twice as big. It would really look like a snow plough...
Hopefully my gfx will be installed right after the car is repainted in two weeks - if only you lived somewhere close I'd gladly buy your rocker panels with the gfx mounts on. I have to fabricate mine
Old Mar 21, 2009 | 10:14 PM
Brennan's Avatar
Car: 1984 Z28 HT,2006 2500HD
Engine: 5.7L, 6.6Llbz dmax
Transmission: 700R4, 6 speed allison
Axle/Gears: worn out 3.73 posi
i got an 84 but this may help a little
Old Mar 21, 2009 | 10:23 PM
JMR's Avatar
JMR
Car: 91 RS vert/ 89 iroc vert
Engine: 305 TBI/305 TPI
Transmission: 700r4Xtwo
Axle/Gears: 10 bolt non-pos. B/W 9 bolt pos
You might get more results by asking '85+ camaros w/out gfx; The '85-92 are virtually similar.
keep in mind, if removed you are going to have fastening holes.
Old Mar 22, 2009 | 05:16 PM
Q's 91z28's Avatar
Car: 91 Z28
Transmission: Automatic
Gives you an idea how bad our cars look with out the GFXs
Old Mar 22, 2009 | 06:06 PM
RU1NER's Avatar
ahh! alright i figured the front would look bad without thanks for the pictures
Old Mar 25, 2009 | 03:21 AM
Louis_84's Avatar
Car: 1984 Camaro SC
Engine: 305 V8, LG4. For now...
Transmission: 700R4, for now...
Axle/Gears: ???
Cant you just fix them, or paint them...instead of removing em? Or even get new ones...
Old Mar 25, 2009 | 03:45 AM
Nub383's Avatar
Car: 94 Silverado
Engine: 383 Vortec TBI
Transmission: 4L60
How bad are the old ones? They make some urethane repair liquid that's 2 part mix and when it dries it is similar to the flexibility of the gfx. Or you could glass them. Or if you don't paint I could step by step you on it.
Old Mar 25, 2009 | 05:38 AM
RU1NER's Avatar
Ya I'll fix/get new ones i just didn't know how it would look
Old Mar 25, 2009 | 09:53 AM
1Aauto's Avatar
Former Sponsor
I'd fix it too,man that's a lot of holes.
Old Mar 25, 2009 | 10:44 AM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
I like a look like this. (Realize I am not 100% sure I will do this, i am going to see what it looks like first before having the holes filled and such)
91-92 front lip
No side skirts smoothed holes of course
No rear bumper skirts also smoothed holes
Something like this but on my camaro, I am not adding a front lip to the already 91-92 lip I want, I am going to replace my 89 lip with the 91-92 longer lip then remove the side skirts and rear bumper skirts
Old Mar 25, 2009 | 11:05 AM
RU1NER's Avatar
I'm thinking about just removing the rear and the piece behind the rearwheel (rocker I think) cause that's what's messed up and I'd leave the front and sides on.
Old Mar 28, 2009 | 02:20 AM
Brainderailment's Avatar
Car: 1991 Camaro RS
Engine: 3.1L V6
I'm painting mine soon so I'm borrowing a plastic welder. If you can you should try to fix them up. It'll look better with spots on it than no gfx at all.
Old Mar 28, 2009 | 11:42 AM
1986z28's Avatar
Car: 86 z28, 87 IROC, 88 sc, 93 z28
Engine: LG4, LB9, LO3, LT1
Transmission: 700r4, T5, 700r4, 4L60
Axle/Gears: 3.73, 3.45, 2.73, 3.42
Just remember that that you would have to get a bumper cover from base camaro without ground effects (like this pic)since the ground effects are part of your bumper cover.
Frozer!!!
Jan 19, 2024 04:55 PM
mitch_04
Members Camaros
20
Sep 20, 2021 02:24 PM
LilHot
Exterior Parts for Sale
20
Apr 1, 2016 04:45 PM
LittleFranks
Aug 20, 2015 03:55 PM
LilHot
Aug 19, 2015 10:02 AM
