4th gen. look
Old Dec 1, 2009 | 11:48 PM
91_GTA305's Avatar
Car: 1991 Trans Am
Engine: sb chevy's.
4th gen. look
I'm having thoughts about this mod. I'd like for it to set the look off with a 4th gen wing to have that "newer" look, but then i'd kinda want it stock and clean. Hope this aint too tacky or anything. Give me yalls opinions on what yall think about this one?
Old Dec 1, 2009 | 11:56 PM
Stephen's Avatar
Car: 87 GTA
Re: 4th gen. look
I think you'll get shot, if you cut up a set of 91/92, 2-piece tail lights to mod like that!
Old Dec 2, 2009 | 12:20 AM
BigBadGTA's Avatar
Car: 1988 Trans Am GTA
Engine: 350TPI
Axle/Gears: 3:27
Re: 4th gen. look
don't really like 4th gens, so you already know my opinion.. keep it the way it is.
Old Dec 2, 2009 | 01:51 AM
Transmetal's Avatar
Car: 89 Trans Am GTA
Engine: 5.7 350 TPI L98
Axle/Gears: Borg-Warner 3.27
Re: 4th gen. look
I've always liked the 91-92 cars. I might be the only one but I actually like the smaller aero wing on those cars. I'd leave the tails stock, if u want a newer look get a ram air 1 or 2 as those hoods fit the 91-92 cars look better than on an 82-90 Bird.
Old Dec 2, 2009 | 10:14 AM
greatpumpkin_68's Avatar
Car: 1987 IROC & 1968 Nova
Engine: 5.0 TPI & 350
Transmission: 700R4 & powerglide
Re: 4th gen. look
i am usually a purist... but for some reason i like this.
Old Dec 2, 2009 | 05:13 PM
FYRCHKN's Avatar
Car: 1988 SC Convertible
Engine: LT-1
Axle/Gears: 3.23 posi w/PBR's
Re: 4th gen. look
Personally, I wouldn't hack up those lights to do it. But, if you haven't see this already here is what I did to blend the 4th gen look to the rear of my car. Plus the addition of the sequential turn signals really adds a coolness factor.
Old Dec 2, 2009 | 09:09 PM
91_GTA305's Avatar
Car: 1991 Trans Am
Engine: sb chevy's.
Re: 4th gen. look
I see what you mean. does in fact look good and different. I have another set of 91-92 tail lights thats why i can care less if i cut into these to try the mod. I always have the back ups in case if I get the "what the hell did i do" response in the end of the mod. how did you get your lights to look like that FYRCHKN?
Old Dec 2, 2009 | 09:32 PM
Stephen's Avatar
Car: 87 GTA
Re: 4th gen. look
Originally Posted by 91_GTA305
I see what you mean. does in fact look good and different. I have another set of 91-92 tail lights thats why i can care less if i cut into these to try the mod.......
Nothing like cutting up lights that could easily get you $250+ per set.....
I'd rather have the $, than custom lights.
Old Dec 3, 2009 | 12:01 PM
Red87SC's Avatar
Car: 87 Trans am
Transmission: built 700R4
Axle/Gears: BW 9 bolt posi w/ disc
Re: 4th gen. look
i agree, i would rather have the cash than the modded lights.
I'm not a purist by any means but i think that the stock 91-92 lights look best on your car.
Old Dec 3, 2009 | 09:52 PM
91_GTA305's Avatar
Car: 1991 Trans Am
Engine: sb chevy's.
Re: 4th gen. look
alright thanks. I guess thats another idea out the window.
Old Dec 3, 2009 | 10:41 PM
Stephen's Avatar
Car: 87 GTA
Re: 4th gen. look
It's up to YOU to do with YOUR car. We don't have to like it.
Personally, I'd just rather leave them stock, or get older ones & mod those.
Old Dec 3, 2009 | 11:14 PM
STRIKER911's Avatar
Car: 89 RS
Engine: 305 TBI (lo3)
Axle/Gears: Whatever is stock.
Re: 4th gen. look
K I dont have a bird but I like it. Its all good. Go for it.
Old Dec 4, 2009 | 12:06 AM
DeathMetalTony's Avatar
Car: 2002 GS300 Sport Design
Engine: 3.0L 2JZGE
Transmission: 5-Speed Shiftable Automatic
Re: 4th gen. look
I dont got a bird but thats a sick a.s.s. mod! I'll would go for it just my openion.
Tony.
Old Dec 4, 2009 | 06:45 PM
FYRCHKN's Avatar
Engine: LT-1
Re: 4th gen. look
Here's how I modded my lenses:
https://www.thirdgen.org/forums/body...il-lights.html
Old Dec 4, 2009 | 09:44 PM
91_GTA305's Avatar
Car: 1991 Trans Am
Engine: sb chevy's.
Re: 4th gen. look
i'll just go to the junk yard and pick up a cheap pair of tail lights and try my mod with FYRCHKN's mod. Wanna see how good it comes out and how it looks in person.
Old Dec 4, 2009 | 09:48 PM
carfreak614's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
Axle/Gears: Open 2.73
Re: 4th gen. look
I say go for it, the lights actually look kickass. Would be somethin to set ur car apart from other birds. To tell you the truth I kinda like them better than the stock ones.
Old Dec 11, 2009 | 03:04 AM
omnipotentgoku's Avatar
Car: 1987 IROC Z
Engine: 350 TPI L98 block
Re: 4th gen. look
Perhaps if the lights were almost square like 3rd gen camaro lights, they would be a little more.. congruent.
Old Dec 11, 2009 | 11:14 AM
Firebat's Avatar
Re: 4th gen. look
Don't use the walmart fogs that I used when I attempted to build a custom taillight a while back. They are an ugly light blue.
The thing that makes this so difficult to do is the fact the taillights are curved or not flat. Not only cutting the curve for the sleeve or pvc pipe for the fog to go into, but even making sure you have both sides the exact same and both fogs angled the same. One may look like its slightly pointed down and the other might have the sleeve in there crooked a little bit. That little bit of error can make a huge difference.
I've tried something like this and have decided I'm just going to make my own custom one piece taillight setup from scratch or do what FYRCHKN did.
Old Dec 11, 2009 | 07:20 PM
BlueZee28's Avatar
Engine: Cammed 6.0L LSX
Re: 4th gen. look
I used to be a purist until I tossed out my completely stock and unmolested drivetrain for an LSX swap...I think you should do this. The photochop you made looks incredible. If you can somehow pull it off to make it look THAT GOOD, then by all means do it. But if you're going to do it, do it right, and don't make it look in a way which would let others get the impression you did it yourself, you want it to look professional, like something they can go purchase on the aftermarket.
If you do this, your next mod should be a 4th gen wing.
Old Dec 11, 2009 | 07:49 PM
gotabekidding's Avatar
Car: 91 & 88 GTA, 89 Formy, 89 bird
Engine: 3 - 350 TPI, 305 TBI
Transmission: All 700R4's
Axle/Gears: unknown
Re: 4th gen. look
I like the taillights the way you tied the 3rd & 4th gen look.
The 91/92 taillights are a rarity.
Try the same mod on a 85-90 set?
As far as the Wing from a 4th gen - too much for the 3rd gen body to carry over - in my opinion.
It is your car and you should do what you think is best.
If we did what everyone else agreed on - we would all have the same car!
Old Dec 12, 2009 | 08:51 AM
Engine: 3.0L 2JZGE
Re: 4th gen. look
Once again I say go for it! It looks killer I like the look of it, unique.
Tony.
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
dbrochard
Exterior Parts for Sale
Oct 10, 2015 01:03 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
Agent507943
Firebirds Wanted
Oct 2, 2015 07:18 AM
Dragonsys
Sep 25, 2015 03:51 PM
