Painting front control arms
Old Jan 20, 2010 | 05:04 PM
lonesomeloser's Avatar
Car: 1983 Z28
Thinking of using a product similar to POR 15. The problem is I don't want to use black if I don't have to. The website and the literature say that it is UV sensitive. My question is: Has any one used a color other than black and how is it holding up? I can see how some reflection from the road would hit them but wondering if it would really discolor them.
Old Jan 21, 2010 | 08:42 AM
G-reg's Avatar
Car: 90 Camaro
Engine: 350 tpi
Transmission: t56
Axle/Gears: 4.10
Re: Painting front control arms
Why not just paint over the top of whatever you're using? Then you wouldn't have to worry about fading and you'd have the color you want.
Old Jan 21, 2010 | 09:32 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Another option is Eastwood Rust Encapsulator. It comes in a couple colors, and seems to be good stuff. My father brushed it on to his rusty plow frame, which obviously sees a LOT of salt, and so far it's holding up nicely.
Old Jan 21, 2010 | 05:26 PM
stealtht/a's Avatar
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
por 15 is UV sensetive, but it wont fade under your car. to keep it stable, use the topcoats they offer that bond to POR 15. the topcoats are available in many colors. POr15's website is very detailed, check it out. Por 15 is great stuff, but if you read all the threads here you wil see that the key is following the instructions ABSOLUTELY!!!
Old Jan 21, 2010 | 05:54 PM
howy03's Avatar
Car: 1985 Pontiac Trans Am
check out SEM Rustshield available in colors I like it better than por 15.Also has an optional hardner/gloss enhancer that will protect it from fluids and uv fading.
Old Jan 21, 2010 | 07:52 PM
Car: 1983 Z28
Ok, I am going to use KBS Rust seal, galvanized steel color.
Old Jan 23, 2010 | 02:54 PM
Car: 1983 Z28
http://
Finished with them. I used KBS Rust seal, silver color after having them sandblasted. Talked to the company, they said the color has moderate UV stability and would be fine.
Old Jan 23, 2010 | 09:14 PM
stealtht/a's Avatar
looks nice! I suspect KBS is actually the same thing as POR 15. Ive used POR 15 for a long time, always interested to hear the results with all the new similar products.
1992rs/ss
Jan 31, 2025 05:10 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
