CFI black crinkle finish...
Old Feb 28, 2010 | 10:30 PM
chazman's Avatar
Transmission: World Class T-5
Axle/Gears: BW 3.45
Anyone ever touch up their black crinkle CFI air cleaner cover? I've got afew spots where the paint has worn through, mostly where the hood seal touches it.
I've seen some spray can black crinkle paint. Anyone ever use it? Any tips?
Old Mar 1, 2010 | 03:40 AM
Twin_Turbo's Avatar
Re: CFI black crinkle finish...
I've used the wrinkle paint quite a bit and the texture is rougher than on the CFI cover.
This interior was completely done w/ wrinkle paint so you can have an idea of how rough the texture will be. Also, if you spray it on thick the texture will be a lot rougher than sprayed on thin stick it in the oven and the texture will be a lot rougher too.
[img]https://i31.tinypic.com/2dkj0us.jpg[img]
Old Mar 1, 2010 | 09:42 AM
chazman's Avatar
Axle/Gears: BW 3.45
Sounds like I'd want to spray it on very thin.
How many coats did it take for you to get that effect?
Old Mar 1, 2010 | 02:27 PM
Twin_Turbo's Avatar
One coat, you spray it on once, not several coats. Lay it on thick for that effect. If you spray it too thin it will not wrinkle or it will cover very uneven. You have to spray in a criss cross pattern, first you make passes in one direction, then perpendicular in the other making sure you have an even coating. It'll take some time for it to start wrinkling and it can take quite a bit of time to cure. I used several different types, I liked the Harley Davidson stuff the best (get it at a HD dealer), Eastwood sells it too, VHT brand but I had issues with clogged nozzles on new cans and crappy spray patterns.
Old Mar 1, 2010 | 02:35 PM
flrtin1's Avatar
Car: Z/28..39 Plymouth truck in progress
Engine: S/B
Transmission: Manual
I would recommend you get it powder coated........There are at least 20 differnt black powder wrinkels/textures from light to heavy and I am sure one would be a very close if not exact match plus it will handle the wear factor much much better than paint......if you are interested I can get you in touch with a couple of guys in your area.
Old Mar 1, 2010 | 03:21 PM
Twin_Turbo's Avatar
I agree, if there is a coater that does it in your vicinity go there, much better!
Old Mar 10, 2010 | 05:07 PM
chazman's Avatar
Axle/Gears: BW 3.45
Who's good in the western suburbs?
Old Mar 10, 2010 | 05:26 PM
flrtin1's Avatar
Engine: S/B
PM'd ya the info. if that doesnt work got another one for ya also.
Old Apr 11, 2010 | 02:09 PM
82Camaroguy's Avatar
Car: 1982 Z28
Transmission: 4l60
I had mine powder coated in a crinkle finish and it looks 100% original, I feel good knowing the powder coat is pretty durable as well!
gta892000
Aug 11, 2019 11:16 AM
Saxondale
Sep 15, 2015 06:42 PM
m00n420
Sep 11, 2015 02:39 PM
Ironhead38
Sep 7, 2015 02:26 PM
Out-Cast
Canadian Region
Sep 4, 2015 10:13 AM
