PEOPLE WITH 4INCH COWLS.
Old Mar 3, 2010 | 08:14 PM
budget350's Avatar
Car: 87 iroc, 91 rs
Engine: 350 worked, 305
Transmission: 5 speed zbar setup. auto
Axle/Gears: 3:73 gears. stock
Ok, so my dad days im going to get a ticket with a 4 inch cowl on my camaro. Is that true and i also want pics of your 4inch cowl from the inside of the car, like sitting down in the seat and taking a pic of whats in front of you. thanksss
Old Mar 3, 2010 | 08:26 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: PEOPLE WITH 4INCH COWLS.
depends state to state, its considered an obstruction of view, might fail inspection, not sure if you will get a ticket. I know jersey allows either 2.5 or 3". I have a 4.5, never been pulled over for it, but i dont go through standard inspection either
Old Mar 4, 2010 | 02:18 AM
Adrenaline's Avatar
Car: 92 Camaro RS
In California it's a simple test.
The cop stands in front of the passenger side head light, holds his arm down at his side, and hold up a certain amount of fingers. Then asks you how many he's holding up. If you can see his fingers than you're legal, if you can't, the hood is considered an obstuction of view and you get a fix it ticket. You must remain seated in a normal position during the test, no leaning forward or sitting up to see over the hood, etc.
Old Mar 4, 2010 | 06:32 AM
DeathStarr89's Avatar
Car: Still a 3rd Gen
Engine: 450HP 355
Transmission: TH350
Axle/Gears: 9" with 4.11's
I'll grab a pic from the inside but it is a pretty big obstruction. I don't have any problems driving it though.
*edit
Here is a pic from eye level. I'm 6' tall if that helps...
Old Mar 4, 2010 | 07:30 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
so if the cop is really short, your totally screwed right?
Old Mar 7, 2010 | 09:41 AM
89FRMLA350's Avatar
Engine: None
Transmission: None
Here is mine. It's a glasstek 4". I would consult your local state laws if you are really worried about it before spending the money.
Old Mar 7, 2010 | 09:50 AM
Engine: 450HP 355
Transmission: TH350
Can you see all the way through that scoop or does it have vents like the Harwood does?
Old Mar 7, 2010 | 10:04 AM
89FRMLA350's Avatar
Engine: None
Transmission: None
There are no vents. It is completely open but it still has a finished underside and it's the bolt on style.
Old Mar 7, 2010 | 10:10 AM
Engine: 450HP 355
Transmission: TH350
Nice.
I'm not really fond of the Harwood vents, i might end up cutting them out some day.
Old Mar 7, 2010 | 10:23 AM
89FRMLA350's Avatar
Engine: None
Transmission: None
I just dont see a point of having vents on a cowl hood? It doesn't make sense and defeats the purpose of having a cowl hood. I understand to possibly keep things from getting sucked in but isnt that what an air filter is for? Just saying.
Old Mar 7, 2010 | 10:38 AM
Engine: 450HP 355
Transmission: TH350
exactly...
i guess it would keep people from reaching in and messing with things as well...
Old Mar 7, 2010 | 11:00 AM
4playta's Avatar
Car: 1984 Trans Am
Engine: Built chevy 350
Transmission: TCI Built 700r4
Axle/Gears: 3.73 posi 10 bolt
If you would get a ticket for a 4" cowl hood how do some people get away with driving around with a 6-71 blower and bug catcher scoop on top of that sticking way up in the air?
Or do cops just appreciate bad *** and look the other way http://www.youtube.com/watch?v=L5DAEkWObw8&NR=1
Old Mar 7, 2010 | 11:06 AM
89FRMLA350's Avatar
Engine: None
Transmission: None
Being a police officer myself all I can say is officer discretion and your local laws.
Old Mar 7, 2010 | 12:02 PM
kens86's Avatar
Car: 1986 Camaro
Engine: 436" SBC
Transmission: TH350, 8" Converter
Axle/Gears: S60 with 4:11 and Locker
My harwood doesn't have any vents. I wish i knew how to post pictures.
Old Mar 7, 2010 | 04:47 PM
Engine: 450HP 355
Transmission: TH350
here is mine..
Old Mar 7, 2010 | 05:40 PM
89FRMLA350's Avatar
Engine: None
Transmission: None
You need to cut that out because then what is really the point of getting that hood if you only have two small vents for an opening in a COWL HOOD!!
Old Mar 7, 2010 | 06:23 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
http://www.youtube.com/user/orr89roc...12/UCjJ3MhZyVY
Alittle lower than eye level but you get the idea what its like to drive with it on. No tickets here and i have turbos sticking out of the hood
Old Mar 7, 2010 | 06:24 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
__________________
I wouldnt beable to read his fingers on my stock 99 trans am and its not a WS6 hood either... That test sucks
Old Mar 9, 2010 | 04:46 AM
Adrenaline's Avatar
Car: 92 Camaro RS
The blowers/bug catchers you see, are mounted in the center of the engine compartment, or at least close to it. Therefor when in the driver seat, you can see behind it giving you full view of the right corner of the car, and doesn't obstruct your view.
Old Mar 12, 2010 | 05:22 PM
KYLE87's Avatar
Car: 1987 Camaro
Engine: 5.7
Personally I think 4 is a bit high for a street car. I have Goodmarks version and it is supposed to be a 2 inch cowl, but it measures more like 3 and it took a week to get used to and now it doesnt bother me, but it is harder to see things when parking on the passenger side as expected.
Old Apr 18, 2010 | 10:49 AM
Stephen's Avatar
Car: 87 GTA
That is a very subjective & unfair test.
A short inspectors hand would be lower than a taller inspectors hand. So it isn't even a standardized, comparable test, from inspector to inspector.
I'm 6' 5".....I have a stock hood.....And I can't even see that corner of the hood, because of how low Firebird noses droop, in comparison to Camaro noses.
If I was failed on that, I would contest it with the state department that is over the inspection stations.
Old Apr 18, 2010 | 12:36 PM
Pairof91rss's Avatar
Car: 1991 B4C-1991 RS
Engine: L98 5.7 TPI-LB9 5.0 TB
[quote=Stephen;4514134]That is a very subjective & unfair test.
Sorry to go off topic...Im 6'10...do you have to bolt the seat back to drive comfortably? I have tried to find some type of extensions for the seat tracks but have no luck.
Regarding the testing you are talking about...pretty sure I would be screwed as well, I have to have the seat reclined so far to fit in the car!
Old Apr 18, 2010 | 01:08 PM
Stephen's Avatar
Car: 87 GTA
[QUOTE=Pairof91rss;4514249]
I have 4th gen seats, so they do sit a little lower than 3rd gen seats. Helps with headroom.
Seats are bolted in to the stock location on the stock 4th gen seat tracks, but are slid all the way back.
Leg length (inseam) plays a big part in how far back the seat has to go too. I have a 36" inseam.
Old Apr 18, 2010 | 02:53 PM
[quote=Stephen;4514278]
Compared to stock 3rd gen seats all the way back, do the 4th gens provide a little more legroom?
Old Apr 18, 2010 | 03:01 PM
Stephen's Avatar
Car: 87 GTA
[QUOTE=Pairof91rss;4514345]
It has been almost a decade since I sat on stock seats, so I really don't remember. I know on both my wife's (she was 5' 10") 90 & my 92, I did a 4th gen seat swap in to both.
Next stock seated 3rd gen I'm near, I'll check & report back for you.
Old Apr 18, 2010 | 06:15 PM
CaliChevyLover's Avatar
Car: 1986 IROC-Z28
im 5"4 and cant even see halfway down the louvers of my irocz...thats with a power driver seat. id be running people over in parking lots if i had a cowl hood
i learned how to drive when i was 15/16 in my brothers manual seat 90 formula with the stock "cowl" hood. i couldnt and still cant see past the edge of the scoop...unless the headlights are up, then i can see the top of the headlights
Old Apr 18, 2010 | 06:29 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
this is my old hood and I think it was about 3" at it's highest,
I coun't see the pass side headlight when it was popped up.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
Pac J
May 17, 2020 10:44 AM
LC2 TECH
Oct 13, 2015 11:53 PM
MadOTC
Oct 13, 2015 04:46 PM
