hard water spots!!
Old Apr 1, 2010 | 05:01 AM
third_genbowtie's Avatar
Car: 1991 camaro RS
Engine: 305-LT1 swap
Transmission: 700
hard water spots!!
I learned my lesson not to park my car next to the sprinklers. Its been some time now that i have been trying to remove some water spots that have gotten almost impossible to remove, i should say imposable because the area that i was able to clean up is not %100 gone! what should i use? i dont want to start experimenting with all sorts of stuff so if any one has had this problem pleas, im all ears.
Old Apr 1, 2010 | 05:36 AM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Re: hard water spots!!
I have spots too. I'm going to try the Mr.Clean system, comes with a water softener.
IDK if a clay bar would remove them. So far I use a carnuba wax- seems to help somewhat.
Tuned in to hear of any good tips also!!
Old Apr 1, 2010 | 01:42 PM
Car: 1991 camaro RS
Transmission: 700
the clay bar is my next steep
Old Apr 1, 2010 | 02:07 PM
92RSMoneypit's Avatar
Car: 92 camaro B4C
Transmission: t5
They make a pumice cleaner for glass that takes that stuff off it works great but its probably to coarse for paint.
Old Apr 1, 2010 | 02:15 PM
wildjyoung's Avatar
Car: 1991 Trans Am GTA, 2003 Grand Am GT
Engine: 350 Tune Port
I am sorry to break it to you but having non treated water on your paint in the sun will cause micro etching. You only recourse is a buff job with rubbing compound to take off the tiny layer of clear coat that is etched.
Old Apr 1, 2010 | 03:39 PM
Sickness91Z28's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
make friends with a buffer
I had to buff several corvettes at the dealer I worked for because of hard water spots...
Old Apr 2, 2010 | 07:26 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Haven't tried it, but you might research the following product: Meguiar's M4716 Hard Water Spot Remover.
JamesC
Old Apr 2, 2010 | 11:46 PM
iroc stangs's Avatar
Car: 87 iroc-z camaro
Engine: 305TPI
Axle/Gears: G92 3.23 posi
first i would try a clay bar. then if you arnt happy use scratch remover like meguirs scratchx 2.0. i used that on my durango that the paint looked good but not entirely smooth but after using the scratch remover it looks MUCH smoother and helped take atleast 90 percent of the scratches and of the old water spots and such out. also your going need a buffer. even a cheap one will be fine. i got a 10in craftsmen buffer and helps ALOT! wish i had another smaller one for the tight spots. good luck
Old Apr 3, 2010 | 01:52 AM
Car: 1991 camaro RS
Transmission: 700
ill be sure to try the Meguiar's M4716 Hard Water Spot Remover.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
tommy z-28
Oct 6, 2015 10:58 PM
Breazlan
Sep 25, 2015 11:20 AM
TBRays98
Sep 6, 2015 05:05 PM
