1992 Firebird, Project Satan, need FEEDBACK!
Car: 1992 Pontiac Firebird Base
Engine: 305 TBI
Transmission: 700r4, B&M shifter & shift kit inst
Axle/Gears: 3:23....10 bolt
ok, so i got a 92 firebird v8 305 and i plan to restore it with some nice modifications...that are listed below, i want feedback from anyone who has a different opinion than me or has a better idea..
-461 Pontiac Stroker
-Adding limited slip rear differential
-Manual or Automatic trans???????????????????
-Fiberglass hood with hole in middle for air cleaner
-Exhaust? sidepipes? pipes coming out of my hood? NEED HELP!
-5 point seats
-if automatic, B&M shifter or Hurst?
-tires?
-rims????????????
-should i customize my gauges? i kinda screwed up my odometer
i cant think of anything else, but HELP is appreciated. thanks guys!
-5 point seats
-tires?
-rims????????????
Re: 1992 Firebird, Project Satan, need FEEDBACK!
461 Pontiac will need a new rear end if you expect to drive the car.
I prefer a manual transmission over an AT.
Get a cowl hood, don't cut a hole in a hood.
Engine: 305 TBI
the only problem with that is i hate cowl hoods. i want the air cleaner to show but im in the plan stage right now so idk yet
Car: 1987 GTA Trans Am
Axle/Gears: Borg Warner 9-Bolt 3.27
Car: 1987 IROC-Z and 1988 Iroc-Z
Engine: 5.7 350 V8 and 5.0 305 V8
Transmission: 700R4 Automatic Transmission
Axle/Gears: 3.27 Posi
-5 point seats
-tires?
-rims????????????
-5 point seats
-tires?
-rims????????????
Engine: 305 TBI
Engine: 305 TBI
[QUOTE='87IROCZOWNER69;4663654]Nice choice in upgrading the engine but please use the manual trans! Automatics in sportscars just dont feel right, besides they are more fun to drive too! If it is project Satan I think the exhaust pipes out the hood would totaly look BA. But if not that then do sidepipes. I agree on the GTA wheels they are sweet
The only reason i question manuals, are because of the nonstop shifting...it seems like it would get old after a while, and i dont know how i could pull off the pipes coming out of the hood (2 pipes, or one for each cylinder) but i also wanted to incorporate exhaust cutouts so i wouldnt have to deal with the cops when its loud. i have so many ideas, but little time and the inability to choose just one idea.
Car: 89 Formula 350
Engine: 355 long block TPI
Transmission: auto
Axle/Gears: Richmond 4:10 Eaton Posi
Engine: 305 TBI
If this is going to be a street car I would be pretty hesitant to put the pipes through the hood. If you go through with the 461 you should probably put in SFC's to help the car handle the power
. As for having to shift alot with a manual, Its usually only a problem if you see alot of stop-and-go traffic. Good luck with the build
and keep us posted
and keep us posted
Car: 91 RS vert/ 89 iroc vert
Engine: 305 TBI/305 TPI
Transmission: 700r4Xtwo
Axle/Gears: 10 bolt non-pos. B/W 9 bolt pos
-5 point seats
-tires?
-rims????????????
Car: 1985 z28
Axle/Gears: 7.5 with 3.23
May I ask why a pontiac motor? First thing you need to do is find a budget. Then it will be much easier to build a nice street car. In addition these cars cannot handle much power without beefing up the drive train.
Car: 83 camaro z28, 92 xj
Engine: 305 Crossfire (lu5)
Axle/Gears: richmond gear 3.73:1
im assuming that you dont already have the 461... so, for now, i would upgrade the 305, and that way you would have more time to contemplate/finish your 461, which will need alot of other parts to make the car drivable, and if your like most of us you dont have the money to buy it all at once... so again, for now, i would build the 305 or just run it with the 305 as is, and slowly piece together your dream... having a set budget is a good idea too. i like the idea of the shaker!
and as far as the manual trans or auto... its up to you when it come down to it.. and also what you want to do... if you know you are going to be doing alot of city driving, i would go auto, or if you would like to send it down the strip, i know people who swear by their trans brake.. but i also know people who wouldnt drive an auto to save their life... its personal preference as far as im concerned
Engine: 305 TBI
I think it takes more than just dropping a 461 with a full exhaust, a suspension to back up that displacement is a must. Whether it being AT or MT a built suspension is also a must. Not to rain on you parade but these plans are not going to get you far. the best advice is to do some intensive research before you spend a single dime, you will end up saving money.
ok, i will look into it more
Engine: 305 TBI
i really like pontiac and besides who has a 461 stroker in their bird? its a one of a kind engine for a one of a kind car...and i am researching stuff so i will keep everyone posted.
Engine: 305 TBI
Engine: 305 TBI
and keep us posted
and keep us posted
im going to do the manual, but im not sure if i should do a 4-5-6 speed...im going to put digital gauges in, put cragar v5 rims, bfgoodrich tires, idk what tranny, glass ttops, shaker hood, 8k hid headlights, maybe nos, but thats all i can think of right now...im still working on it...i need a job
Car: IROC-Z
Engine: LSx
Axle/Gears: Fabbed 9"
why build such a big engine? In your situation, Id go with a carbed LSx based 6.0. You could easily reach 450rwhp, keep it tamed on the street and a beast on the track. Obviously, Id use a t56... 4 and 5 speeds dont even come close to what the t56 can take.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
but i agree with the lsx, i dont see why you need to go throguh all the expence of a large ponitac build that will gain you nothing but headaches and being "different". the lsx will make just as much if not more power, have better fuel economy and be more streetable. plus there are conversion parts available, unlike the pontiac swaps. that will save tons of money on custom fab parts
Engine: 305 TBI
i guess i could go with a lsx but i really had a mindset on the stroker, idk bout tranny still all i do know is its gonna have a f@ckin good clutch.
Car: 1992 Camaro RS, 66 Mustang, 78 t/a
Engine: 5.0 TBI, 289, 400
Transmission: 700R4, C4, th350
daydreams at 18...
you need to realize that none of this can happen if it's your only car. not only that, but you better be prepared to spend thousands of $. I would also recommend that you be very knowledgeable before starting something so big as this.
Car: IROC-Z
Engine: LSx
Stroked LSx kits are mainly available, from 408 to 454+ cubic inches... the real question is how deep are your pockets. Clutch should be the last of your worry, theres a clutch for every application. Id suggest you to ride in a +/- 300 rwhp car before thinking of going with strokers and big cubic inches motors. I think you will be more then surprised of what 300rwhp is when its fully put on the ground.
Engine: 305 TBI
Engine: 305 TBI
its not my only car, ik what its gonna cost, and i am knowledgable otherwise i wouldnt be saying what im saying
You are looking at spending in the 25k+ range to get that engine, a transmission that will live, a driveshaft that will live and a rear end that will live.
If you don't own a house, buy a house before you even think of starting this project.
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
1)Engine = A stroked Lsx
2)Rear end = Eaton posi. In either a 9”or a 12 bolt.with 3.73 gears and a LPW Ultimate Support cover
3)Transmission = Manual
- Hood cowl
- Pipes = side
- Wheels = Weld Pro Stars
Engine: TBI,5.0
Yes I just cought that. Tried to beat the next post becouse I new that was comming. And sure enough there it is.
Car: IROC-Z
Engine: LSx
Forget the side pipes, our cars arent design for them to look good. If you would cut the floor, tuck them in, and have them exit in front of the rear wheels, similar to Vipers, it would be awesome too. But without extensive floor modification, forget it.
