Solution for Grimy tail light covers
Old Nov 16, 2010 | 11:22 PM
nateg's Avatar
Car: 89 Camaro Iroc-Z
Engine: 383 Stroker
Axle/Gears: 3:27
I was wondering if anyone had a really good working kind of solution to clean grimy covers for tail lights or even the plastic covers for the fog lights or anything...just a thought.
Old Nov 16, 2010 | 11:29 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Re: Solution for Grimy tail light covers
You cand sand them and polish them with some plasticpolish it works good
Old Nov 17, 2010 | 11:34 AM
onthedownlow's Avatar
Car: 1984 Camaro Berlinetta
Engine: 355
Axle/Gears: Australian 9 bolt 3.27 posi
plastx
I had the same problem with hazy and foggy tailights , so I purchased this product from meguiars called plastx. I used it as directed and boom my tail lights are like new again!! I mean they are soooo clean it's hard to believe. I also used it on the wife's 2001 Durango, headlights and tails and she actually thought I had bought new headlights!!!!!lol here's the stuff here.
http://t1.gstatic.com/images?q=tbn:A...7GUdin8EaO_C40
Here's a video showing how they recommend to use.
onthedownlow
Old Nov 17, 2010 | 11:57 AM
DIRTY JERZY's Avatar
Car: 89 formula 350 & 2001 ws6 ta
Engine: 350 tpi & ls1
Transmission: 700r4, t56
Axle/Gears: 9 bolt ? & 10 bolt 3:42
RAIN-X makes a kit it works great too.
Old Nov 17, 2010 | 12:28 PM
DeltaElite121's Avatar
Car: 1988 Camaro
Engine: 377
Transmission: TH350; Circle D 4200 converter
Axle/Gears: Ford 9"
this is the correct way of doing it if they are truly "fogged" as you say. I start with wetsanding (add some soap in the water as well) 1000, 1500, then 2000. Then use a rubbing compound, then use a polishing compound (or plastic polish, whichever I've found works nicely as I've tried both).
Before:
After:
Doesn't take terribly long, honestly. Do it this way and they'll stay looking this way for a long while.. and whenever they start to fog again (which won't be any time soon), just redo them.
Old Nov 22, 2010 | 04:53 PM
overide's Avatar
Yes this is how I have fixed lenses on my cars in the past. Using a plastic designed polish alone will make it better. But really the only way is as stated. wet sand... then a true rubbing compound then the plastic polish! You will get a wonderful result every time!
Old Nov 22, 2010 | 07:22 PM
TireSmokin''s Avatar
A quick buff on a buff jack makes them better than new.
Old Nov 29, 2010 | 11:08 AM
Engine: 355
Yeah I just used the plastx polish and my headlights and tails look good as new, no need for wet sanding here.
Old Nov 29, 2010 | 11:53 AM
whitedevilTA's Avatar
Car: 1986 Trans am
Engine: 5.3 LM7
Transmission: T56 6 speed
Axle/Gears: Dana 44 w/ 3.55's
Depending on how bad/foggy they are you may need to wetsand and buff. I do it on the side and it's not very hard. Just can take a little time. PM me if you want to send your lenses to me to buff. I had a post up on here with pics of my tail lights after the wetsanding and buffing.
Frozer!!!
Jan 19, 2024 04:55 PM
Jk_Under
Sep 2, 2015 10:59 PM
LittleFranks
Aug 20, 2015 03:55 PM
Fronzizzle
Aug 19, 2015 01:36 PM
Omega
Aug 10, 2015 12:46 PM
