Question about LED bulbs for your gauge cluster backlighting
Old Jan 3, 2011 | 09:29 PM
BlueZee28's Avatar
Engine: Cammed 6.0L LSX
I'm thinking about trying to get some LED bulbs for my gauge cluster. I did some reading on LED setups from different people here on TGO, but what I haven't found out is whether or not you can buy a style bulb that will fit into the holes/sockets of the original lights in the back of the clusters? The kind that you sping 90* and they lock into place, that's what I'm looking for.
Has anyone ever found any (and used with good success) and wants to help me out on where to find these? I don't want to rig up some contraption if they won't work the way I want them to, I'll just stick with the stock bulbs if it comes down to that.
Old Jan 3, 2011 | 09:40 PM
RubberDucky's Avatar
Car: 1989 Camaro RS
Engine: LH6
Axle/Gears: 3.42 Auburn Posi
Re: Question about LED bulbs for your gauge cluster backlighting
I've been digging about this myself, I found this. I just skimmed through it so it may or may not be what your looking for. There's this also.
Old Jan 3, 2011 | 09:57 PM
FueledSoul's Avatar
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
I plan on doing the same once i get around to the interior...Seen a few threads and web pages but it was awhile ago. . . Be interesting to see what you find and come up with
Old Jan 3, 2011 | 11:02 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
I was able to use these in the instrument panel of my 89. The bulbs were separate from the sockets, so replacement was really easy, just unplug the #194 incandescent and plug in the LED.
http://www.superbrightleds.com/cgi-b...-x5.htm#photos
IIRC, your 90-92 dash requires only 4 lights for illumination, excluding idiot lights. Those four shine into the end of a plastic extension at the bulb to work like fiber-optics, so you could get away with a narrow angle LED in each position. My 92, before I put in a digital dash had the lights and sockets soldered together as a unit. You may have the same issue, I don't know if the sockets are available from parts stores or not, but I pick them from the yards when I visit (and remember) and have a few extras.
Old Jan 4, 2011 | 12:44 AM
FireDemonSiC's Avatar
Car: 1985 Z28
Engine: 334 Stroker Superram 222/230
Transmission: Full Manual 700R4 / 3k Street Edge
Axle/Gears: 3.90 Eaton, Moser, Richmond & More
Al Hasse beat me to it.
But on that note, if anyone has done this to an 82 - 90 style dash could you please post pictures? Right now, I have replaced all the bulbs in my cluster with the standard bulbs that have been tinted red. Light distribution is far from uniform not to mention the tinting starts to fade in certain spots after awhile leaving parts of the cluster looking a little more orangy than the rest.
I want to see what this will turn out like before I invest $50 in light bulbs.
Old Jan 4, 2011 | 01:17 AM
Al Hasse's Avatar
Since you asked for it, here's my 89 done with red LEDs. There's also one behind the HVAC panel. For the radio, I removed the faceplate and painted the back sides of the buttons. Also removed the switch cover and painted the back side of the defogger switch. I also painted the back of the instrument panel bezel white instead of the powder blue it comes stock.
Old Jan 4, 2011 | 01:42 AM
Awesome-X's Avatar
Car: 87 Camaro
LOL I love the Superbrightleds.com ad at the bottom of this page
Old Jan 4, 2011 | 01:12 PM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
You can get just the sockets like Al mentions from most any parts store. However, won't you need to put some sort of pwm or dimmer inline different from the factory one to get any dimming feature out of the LEDs instead of them just turning off?
Old Jan 4, 2011 | 01:54 PM
BlueZee28's Avatar
Looks like I'm ordering some red ones, thanks for the help guys! I'm afraid I might not be able to remove the yellow tint in the cluster so if I went with blue it might not turn out very good.
Old Jan 4, 2011 | 02:39 PM
Demon355's Avatar
Interested to see how this turns out.
Old Jan 4, 2011 | 04:18 PM
Krik's Avatar
Car: 1990 IROC-Z 1LE
Engine: 5.7 TPI
Axle/Gears: G92 3.23
I found that the LEDs that I tried was more of a "spot" light rather than a "flood" light. I didn't like the way it looked. I went to O'Reillys and bought some brighter 194 bulbs and couldn't be happier. I think I kept some of the LEDs for indicator lights, but the rest are just brighter bulbs.
Heres a free tip, replace the dome light with a appropriate size LED bank. It looks really cool, its brighter.....and its not hot! No more yellowing of the dome light cover. Buy a new cover and it looks good as stock!
Old Jan 4, 2011 | 05:44 PM
BlueZee28's Avatar
No dome light in convertibles, just the two small ones in the rear view mirror
Old Jan 4, 2011 | 10:07 PM
Krik's Avatar
Engine: 5.7 TPI
<smacks head> I didn't realize you had a convertible.
Old Jan 4, 2011 | 10:19 PM
BlueZee28's Avatar
Hence why there is no roof on it in my signature
Old Jan 4, 2011 | 10:44 PM
Krik's Avatar
Engine: 5.7 TPI
Thought it was a typo? <Shrug>
Old Jan 4, 2011 | 11:04 PM
PhillyTurboSix's Avatar
Car: 1989 Turbo Trans AM
Engine: 3.8L turbo!
Transmission: 200r4
I did a lot of research on this for both of my GN's. I had led's in my one GN for some time and found they go bad or burn out when you use the cheap ones. I was using the style posted above. I went with surface mount leds for my 86 and they came out much better and cover a lot better.
I wound up using these guys.. http://www.v-leds.com/194-168-158-LED/c122170-1-2/ they sell different colors. While it was hard to take a picture of the dash it's much brighter then the pics below but you get the feeling of the difference by the pictures with before with 195 lamps and then the 194 LEDS. v-leds was good to work with as well. I had 2 with a dead surface mount on them and they swapped them right out.
GN dash before with 194 lamps...
And after with the 194 LEDS.
It was pretty much like the pics show. You could hardly even see the dash at night! Now it's nice and brite.
Old Jan 5, 2011 | 01:27 AM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
I sometimes wonder if it'd look good to replace those with LEDs but I kind of like how "warm" the color of incandescent bulbs are.
Old Jan 5, 2011 | 01:43 AM
Al Hasse's Avatar
Super-Bright LEDs claim that their LEDs will dim with your dimmer circuit, however, the ones I bought from them do not - they turn off when the voltage lowers just so far.
Also available in warm white
http://www.v-leds.com/Exterior-LED/C...-p8829506.html
As are the rest of the styles.
Old Jan 5, 2011 | 01:57 AM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
Is there anyway to dim an LED without a PWM?
Now that's cool.
Old Jan 5, 2011 | 02:39 AM
Krik's Avatar
Engine: 5.7 TPI
If you want a picture of how it looks I can see about taking one.
Old Jan 5, 2011 | 07:37 PM
BlueZee28's Avatar
I ended up buying (1) red LED and (1) blue LED from that superbrightleds.com site. I'm going to try both and see what looks better, maybe I'll try my luck at removing the yellow tint to the numbers and hash marks and see if I can get blue to look good without turning green. I'll post up my findings and my progress. I'm really excited to do this, I think it will really give the inside of the car a totally different attitude.
Old Jan 5, 2011 | 07:39 PM
BlueZee28's Avatar
SHOOT!!! I just realized after I submitted my order that their store is like 5 miles from my house Maybe I can save myself $8 in shipping once I order all the rest of them.
Old Jan 7, 2011 | 08:35 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Dont have one for the Hvac, but here's what i got.
Old Feb 5, 2011 | 11:06 PM
BlueZee28's Avatar
I went ahead and just put red LED's in my stock '91 cluster. It actually turned out better than I thought it would. It doesn't look great in the pictures because I was using the camera on my phone. It's actually very evenly lit throughout unlike how it looks in the photo. There are no dark areas on it, overall I'm very satisfied for the time being.
It kinda reminds me of the cluster in my '06 Grand Prix. The camera on my phone makes the red lighting look pink and distorted on both the clusters...
Old Feb 6, 2011 | 02:30 PM
avilla20's Avatar
Car: 1990 rs/1986 iroc-z
Engine: Lho 3.1 v6/Lb9 5.0 v8
awesome ive been wanting to do this on my 90 rs.
Old Feb 6, 2011 | 04:34 PM
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
I have a question about these as well, I plan to eventually do the swap myself, but what I am wondering is if the MCD listed here:
http://www.youtube.com/watch?v=CSAWrswE3Yo
Is per each bulb in a unite, ie. the ultra-violet(the color I would like to get) one with 6 bulbs has a total of 6000 mcd, or just 1000? I'm pretty deadset on wanting that color, but I want them to be bright enough as well, and know that I need at least 3000 mcd for a bright enough color...Also which of their bulbs available has the best spread? I would guess the 5 bulb one over the 6 bulb one, but on the flip side the 6 bulb is brighter..
Old Jun 18, 2011 | 11:53 PM
BlueZee28's Avatar
Here's a few better pictures from tonight, they're kind of blurry because I was driving. I wasn't going 80 like my dash said though, I just swapped in a new rear with 4.10 gears so the speedo is off a bit
Old Apr 3, 2012 | 04:52 PM
majobis's Avatar
Car: 1987 IROC Z w/T-Tops
Transmission: Automatic
Axle/Gears: G92
Now that I have my dash and gauge cluster out, I'm looking to change over to LED bulbs. I've searched many threads, but most people who have done it seem to be 91-92 owners.
I own an 87 Iroc and looking at the rear of my cluster, I have a mix of bulbs: (9) 194 bulbs and (7) 161 bulbs.
Most people have mentioned just going with 194's, but will that affect the role of the 161's?
Also, I've seen a lot of links to various bulbs and although most agree that a wider dispersement is better, I'd like to know which visual style was chosen most successfully as my goal is uniformity all around the gauges (ie: no dead spots).
Have more of you gone with an original stock look like this?
Or, something with more encased bulbs, like this?
I know that I want 'Cool White' lighting with even dispersement but I want to make sure I have all my facts before ordering. Thanks in advance!
Old Apr 3, 2012 | 07:32 PM
CAMAR0kid93's Avatar
Car: 1987 Chevrolet Camaro Iroc-z
Engine: 305 CID Tuned Port Injection
Axle/Gears: 3.23:1
http://www.superbrightleds.com/cgi-b...%2FWLED-x5.htm
Thats what you want. They have one LED on top and four on the sides pointing out, so they have a nice spread of light.
and only difference between 194 and 161 is wattage, so when doing LEDs that doesnt matter at all.
Old Apr 3, 2012 | 07:37 PM
Krik's Avatar
Engine: 5.7 TPI
keep in mind some bulbs you want spread on. Others you do not.
Old Apr 3, 2012 | 08:48 PM
fiream's Avatar
Car: 1983 Pontiac Firebird
Engine: 400HP 350
heres my dash with those leds in it...
Old Apr 3, 2012 | 09:44 PM
robg91z's Avatar
Car: 1991 Camaro Z28
Engine: 350ci TPI
Transmission: built 700r4
Axle/Gears: 4th gen rear end
So which blubs can i use for my 91? I want them red where can i buy them and are they easy to install? Which ones did bluezee28 use?
Old Apr 3, 2012 | 11:22 PM
majobis's Avatar
Axle/Gears: G92
That makes sense. Maybe the spread one for gauges and then narrow spacing for the idiot lights?
Has anyone done this type of mixed spread angles?
Old Apr 4, 2012 | 12:17 PM
BlueZee28's Avatar
I got them from superbrightleds.com, they're easy to install; they simply pop into the socket where the old bulb was.
Old Apr 4, 2012 | 12:39 PM
Krik's Avatar
Engine: 5.7 TPI
turn signals, ses, bright, those types of lights need a narrow beam of lights. The ones that are intended to light up the gauge pod need to be a spread.
think of it like this... Its spot lights vs flood lights.
Old Apr 4, 2012 | 08:46 PM
robg91z's Avatar
Engine: 350ci TPI
Thanks.. Do u remember which ones they were alot of them come out i just dnt really know the difference between them
Old Apr 4, 2012 | 08:51 PM
Dakota W.'s Avatar
Car: 1991 Christine Z28
Engine: RV Cam and Intake 350 SBC
Transmission: 5speed
Axle/Gears: 3.08 ls Posi
194 wedge I think.
Old Apr 4, 2012 | 08:59 PM
3318RS's Avatar
Car: 1990 RS
Transmission: Built-700R4
This is exaclty the one's I used on my cluster. I installed it 3 days ago.....wow what a diff!
Also, I used the 74X bulbs for the mini-bulbs in the dash. I bought 10 of the WLED-X5 bulbs, & 5 of the 74X. YES, I bought extra.
Old Apr 4, 2012 | 09:44 PM
majobis's Avatar
Axle/Gears: G92
Thanks for the tip. Out of the amount you mentioned, how many did you end up using and what locations did you choose for each?
Old Apr 4, 2012 | 10:06 PM
3318RS's Avatar
Car: 1990 RS
I happen to have my old cluster handy, so this should help...
I used 8 total bulbs of the WLED-X5, I had 2 left over that I did NOT use. If you count the number of locations, I'm pretty sure there is room for 15 of the larger bulbs (one location is of to the rt & you cannot see it in my pic). Of course, if I'm not mistaken, some of the car options dictate wether you need a light or not. My car is a pretty basic car, so it not have a bulb in each of the larger bulb locations.
I used the 74X (smaller LED bulb) on the 3 smaller bulbs you see right in the center.
The only other thing you will need is patience, as the small bulbs are a real PITA to remove from the base. Good luck & I hope the pic helps!
Old Apr 5, 2012 | 12:18 AM
BlueZee28's Avatar
I may be ditching this idea after all... Picked up a free 4th gen dash today
Old Apr 8, 2012 | 07:13 PM
  #42
Awesome-X's Avatar
Car: 87 Camaro
Doesn't mean you can't put LEDs in it lol
Old Apr 8, 2012 | 11:21 PM
  #43
BlueZee28's Avatar
This is true. I may actually go with blue this time around, since the LS1 style dashes don't have a funky yellow tint to the numbers, plus my Aeroforce Interceptor is blue, and I can change the color of my AEM wideband to blue (has like 8 colors you can change it from). So why not have everything the same color?!
Old Apr 9, 2012 | 12:52 AM
  #44
robg91z's Avatar
Engine: 350ci TPI
Whats the difference between all the bulbs in the superbrightleds website? I wouldnt know which ones to order cuz their all the same bulb but they all look different? Does anyone know which ones to actually get or which ones not to get? Are the 360* degree ones the best to get?
Old Apr 9, 2012 | 06:52 PM
  #45
91 Droptop's Avatar
Engine: 355 Super Charged
Transmission: B&M Streetfighter
Axle/Gears: 4th gen 342
I really want to see the blue
Old Apr 9, 2012 | 07:47 PM
  #46
lolvtec's Avatar
Car: 1991 camaro RS convertible
Engine: EFI 383 150shot nitrous.
Axle/Gears: 2:73...
i know this is an older post but im trying white im not using normal leds i tried that its more of a spot light not a flood light im using 5 smd leds there very bright
http://www.ebay.com/itm/2x-194-168-T...f39bd0&vxp=mtr
Old Apr 9, 2012 | 08:44 PM
  #47
Dakota W.'s Avatar
Yes, go with the widest angle possible.
Old May 7, 2012 | 07:42 PM
  #48
TVIROCZ's Avatar
Car: 1987 Chevy Camaro Iroc Z
Transmission: Automatic (700R4)
Whaf bulbs will give the widest angle? Also what bulbs should be used in the cluster 161 or 194? I have Pilot 194 leds from pep boys in my clutch console and ac/heater console. There kinda a dark blue
Old Oct 24, 2012 | 10:55 AM
  #49
GMan 3MT's Avatar
Car: 1986 Z28
Transmission: T5 WC
Axle/Gears: 3.42 T2R
After reading many threads on this, I'm still confused. I get that everyone points to that superbrightleds website, but the pictures there don't show the socket/base. I bought some cheap 194 LEDs on ebay to try out before I realized the '92 bulbs were one piece. Can you swap in the older style bases with new LEDs into the '92 cluster?
Old Oct 24, 2012 | 12:21 PM
  #50
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
You can buy empty 194 bases from the parts store if need be. I think they come in 5/8" and 1/2" sizes. Cluster is, I believe, 1/2" ?
Jeremys87
Jul 14, 2022 09:08 PM
Fronzizzle
Aug 17, 2015 02:52 PM
fonzie85
Aug 13, 2015 11:50 AM
ChevyZ71
Aug 13, 2015 07:30 AM
