Is this a good buy 1986 IROC-Z
Old Jan 30, 2011 | 03:43 AM
codyscamaroz28's Avatar
Car: 1982 Z28, 1991 RS
Engine: 350 Carbed, 305 TBI
Transmission: 700r4, t5
Axle/Gears: 3.23s posi Limited Slip, 3.08 posi
Should i buy this car? 5.7l 350 100,000 original miles, all stock except steering wheel.
The guy is asking 2800 with that dent in the bumper, and cut in the spoiler..??? I'm thinking on the lines of 1500?
Old Jan 30, 2011 | 05:45 AM
Re: Is this a good buy 1986 IROC-Z
Whats a car like this worth? it needs a paint job and body work, so i think 1500$ sound about right? GM only made 49,585 of these IROC-Zs in 86.
Old Jan 30, 2011 | 06:53 AM
GeeJenn91RSV8's Avatar
Car: 1991 Camaro RS
Transmission: 700 R4
Is this car an 86? 5.7 liter 350? I don't think it was an option in 86.
Old Jan 30, 2011 | 06:56 AM
Yes it was, just look it up on here.
Old Jan 30, 2011 | 07:28 AM
Car: 1991 Camaro RS
What you have there is a 305. There was a supposed 50 cars in 86 that had the 350 tpi in it but that is just a rumor and there is no hard evidence to back that up. Others will chime in on this.
Old Jan 30, 2011 | 07:34 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
This from our site:
It's rumored that records also show that 50 1986 350 (5.7) IROC's were built. These cars were built primarily for testing and were the ones we saw tested by the automotive press late in 1986. At the last minute it was decided that the 1986 350 IROC would not be available. Originally it had been planned to release them without T-Tops and air conditioning. Fortunately, they decided to wait for the 1987 model year to start production of the 350 IROC with both being optional.
JamesC
Old Jan 30, 2011 | 07:43 AM
donnis618's Avatar
Car: 1984 camaro Z28
Engine: 355
Check the VIN for an F or 8...Should be a 305. I always assume it's a 305. There are so many people who make the 350 claim it's ridiculous.
Old Jan 30, 2011 | 07:47 AM
JamesC's Avatar
The following link has a ton of useful info on IROC's and what they were equipped with. Check on 1986:
https://www.thirdgen.org/forums/hist...-car-iroc.html
JamesC
donnis618's Avatar
Engine: 355
I also thought they stamped either 5.0 or 5.7 on the back of the block on the later model engines. I know i had a 305 in my '84 Z and it had that stamp. I think it was on the drivers side in the back. Hard to see without mirror and flashlight. Anyway, it looks solid 1500-2200 depending on what engine and how it runs.
Old Jan 30, 2011 | 08:02 AM
CamaroIROC88350's Avatar
Yeah, it's a 305, not a 350 which makes it less worthy in my opinion (as far as buying it for $2,800). But if it's a good running car with not much rust and the body/mechanics are solid enough, I'd say go for it even it you want the 305 still. If you want a 350 look at the 1987 to 1992 Camaro IROC's/Z28's. You could find one that's running solid and looking solid for about $4,000.
Old Jan 30, 2011 | 12:11 PM
PaPaROC's Avatar
Car: 86 IROC
Engine: 305 carb
Transmission: 5 speed
$2800 sounds to high. I"ve got the same car,color ttops even the same clear coat peal. paid $2000 last march
Old Jan 30, 2011 | 12:40 PM
james94's Avatar
Car: 1990 IROC
Engine: Tree Fiddy
I would check out the shock towers a little more just to make sure its just surface rust there. Take a look at them from inside the wheel well too. Like the other on here, Id say in the 1500-2000 range
Old Jan 30, 2011 | 01:39 PM
jchaussee's Avatar
Car: 85 Z28
Engine: 327
Yeah I saw those shock towere also. It looks like there may be more rust lurking somewhere. Also crawl underneath and look at the body. Alpt of people have jacked them up in the wrong spots and it can get costly to fix, if you feel like fixing.
Old Jan 30, 2011 | 03:42 PM
I'm not buying this IROC, the guy pressing hard on 2800$ in cash he claims it's a 350 and i would have to drive 90miles just to look at it. I will just wait for somthing better to pop up. Thanks guys for the help.
Old Jan 30, 2011 | 04:03 PM
'87IROCZOWNER69's Avatar
Car: 1987 IROC-Z and 1988 Iroc-Z
Engine: 5.7 350 V8 and 5.0 305 V8
Transmission: 700R4 Automatic Transmission
Axle/Gears: 3.27 Posi
Good idea. I bought my 87 Iroc with the 350, t-tops, maroon paint (little bit of peel), and there was no body damage. The only really bad thing with it is that when I bought it radio, locks, trunk switch, horn, etc didnt work (just a fuse, guess the dealership thought it was a serious problem) it was listed for $3500 and I got them down to $2250. So I think the fact that one has bad paint and body damage those things even out. Since it's a 305 (more than likely) no more than $1200-$1500 max.
Old Jan 30, 2011 | 05:05 PM
jeff_blake's Avatar
Car: 86 Iroc + 83 Firebird
Engine: Iroc 305 TPI, Firebird 305 4bbl
Transmission: 700r4 in both.
Axle/Gears: Iroc 3.27 Firebird 3.23
Yeah, 86 came stock with the 305 as the biggest for the Irocs, i have one myself. they did make a few of 350's for them.. i believe around 50 or so for track purposes(im pretty sure). All in All 2800 isnt bad,well down here its not. id try to go little lower though.
Old Jan 30, 2011 | 05:31 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
every 3rd gen with a v8 has a 350, do you know that
its a 305, the guy is misinformed, or was told something from whoever he bought it from ect ect.
not worth 2800 at all, its pretty rough
Old Jan 30, 2011 | 06:55 PM
heres the vin number. 1G1FP87FXGL189837 http://www.decodethis.com/Default.as...FP87FXGL189837
Yup 5.0l.
The seller is trying to say that's not a legit website lol that it's a true 5.7 350.
Old Jan 30, 2011 | 07:27 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Yup 5.0l.
you tell him he is full of **** because the 8th vin has to be an 8 to be a 350, no exceptions.
what do you think he would do if you showed up at his house with a took kit and wanted to pull a head?
Steven 86IROC-Z
May 24, 2026 04:52 AM
demontransam89
Wheels and Tires
Dec 28, 2015 06:58 AM
StevenB L98/LS1
Aug 22, 2015 09:03 AM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
