$1200 Paint & Body....
Car: 1986 IROC-Z28
Engine: TPI 305 Bone Stock
Axle/Gears: Posi-Trac
The shop owner told me he would paint & do all the body work, as well as paint the moldings & trim.
One thing that concerned me was that he would not be stripping the car all the way down. Just lvling the paint. When I asked him why not he said he did not really matter its going to look good either way...
What are some key things I should ask him tomorrow before I drop the car off? Keep in mind that its going to be my daily driver, so I am not looking for show quality paint. But I do not want a job thats going to start peeling away in months.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: $1200 Paint & Body....
if the paint is not totally gone, you can do that. If you wanted him to strip the car, it would cost many thousands more.
it would be best is all the bumpers and ground effects were loose, so he can paint in between them, not just over them
what about door jambs?
Car: 1992 Camaro z28
Engine: 350 HSR
Axle/Gears: 3.42's
1. Find out if there gonna remove the gfx and rear spoiler, and also loosen the front and rear bumpers. if not your gonna probably have paint caked and stuck in these areas. After some flexing will lead to cracks and chips. I see this happen alot with the gfx part on the doors.
Car: 1986 IROC-Z28
Should I really concern myself with door jambs? Car will be same color(BLK). Also thanks for the heads up on the loosening of the GFX,bumpers & spoiler.
More importanly how long should I expect it to last before it starts peeling?
Car: 1991 Z-28
Engine: 383 TPI
The car does not need to be stripped down to bare metal as long as there are no issues with the underlying surface. As long as they scuff it good I don't think you'd have to worry about it peeling for many many years (in collision work they do not strip the panels to bare metal unless there is some underlying reason to do so (defective primer, paint, crazing, etc....) As long as your car is in decent shape now I think u r ok....just my .02, but I am not a body man.
Car: 1984 Z28 H.O
Engine: 305 H.O./so0n 350
Transmission: 700r
Axle/Gears: 3.73 pegleg
if you sticking with black theywill most likely not spray them dependng on the shape. as long as they prep the car properly your paint should last 5 years easy being a daily driver and how well you take care of it.
Car: 1986 Berlinetta, 1988 Iroc-Z
Engine: 305 carb, 305 TPI
Transmission: 700r4, 700r4
Axle/Gears: stock
Im sure he knows his stuff as long as its not a maaco or other franchise. my only real advice is to make sure you dont wax the paint right away after cause if im correct (someone correct me if im wrong) paint doesnt ever fully dry cause of the layers and i have read on tgo that you should wait a couple of months before you wax it
Car: '88 Firebird Z20
Engine: 305 TBI w/TBI mods
Axle/Gears: Stock
Sounds pretty cheap for body and paint work. Materials would be half of that. If you've got no peeling or paint checking or paint chips, you don't really need to strip, and for that price def. don't expect it. Would be a good idea to at least loosen bumpers so paint can get around the edges (as said above). Later.
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
