how to get taillights to stay that glossy wet look
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
i have a set of 82-84 trans am louver taillights.
they look great when i clean them up with windex especially in the black areas.
but as soon as it drys their back to dull faded.
would those headlight kits help or some kind of compound any ideas?
something that will last alil bit?
Car: 1991 Camaro Z28
Engine: 305 LB9 5.0L
Axle/Gears: POSI 2.73
Re: how to get taillights to stay that glossy wet look
I've used Meguiar's PlastX polish on my tailights and they look pretty good. I did mine by hand, I'm sure you can get alot better results if you use a buffer with light pressure and a bit of patience...do a quick search, i'm pretty sure I've seen a few threads that covered this, step by step
Car: '89 RS camaro 305 TBI
Engine: LO3
Axle/Gears: yep, has those too (stock)
A good wax enhanced polish does the trick
Car: 1991 Z-28/ '94 Impala SS
Engine: 355 TPI/ 350 LT-1
Transmission: T-56 in both
Axle/Gears: 3.73 / 4.56
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Yep wetsand and use some clear on them, mine look nice like that for a good 7 years before I had to do it again and it just lost the wet look, still was nice. [cheap 99cent walmart clear] went from badly milky look to better then new.
Before
After
Before
After
Car: 1991 Camaro RS
Engine: 305 TBI
If you don't want to clear them, hit them with some 1000 grit wet, 1200 grit wet, 1500 grit wet, and then 2000 grit wet. You will then need to polish them. There are several brands of plastic polish out there, but Mothers is probably the best. I've run my orbital buffer over them with a wool pad and the plastic polish with quite good results. I've also cleared them before after 1200 grit wet-sanding with good results. It just depends on what you prefer.
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
I've got an 83 T/A so I am interested in seeing your results! Post up when you get em' polished.
Engine: gone
Transmission: gone
Axle/Gears: gone
Car: 91 firebird
Axle/Gears: 323
Mothers cleaner will work the best! It's for plastic and dash boards! Looks new all the time after use. Look for the spray bottle of mothers cleaner!!
Car: 1988 Camaro
Engine: 377
Transmission: TH350; Circle D 4200 converter
Axle/Gears: Ford 9"
Car: 88 IROC-Z
Transmission: TH350
Axle/Gears: 3.45
1000 grit wet sanding, 1200 grit wet and then use Flitz polish (Ace carrys it) on a cotton rag with some elbow grease.
Thats about halfway done. The right side is how I got it, the left side is after one round with the Flitz. For some reason I cant find the final pics but it came out glass smooth and glossy. In my experience clear coat can yellow and its just hiding imperfections by filling in rough spots that can be smoothed out with a little more work. You can also finish the process by buffing the lights with plastic buffing compound on a soft flannel buffing wheel, just do it at low speed as it can easily overheat and warp the plastic.
P.S. Flitz polish works on all types of materials, I have used it to finish buffed aluminum parts with great results. Works great on dull paint too!
I recently bought a really nice set of 91-92 TA taillights. Before installing them I'd like to wet-sand and clear them. My reason for clear coat is for UV protection and not having to re-polish later on. Any recommendations on clear coat?
Car: 91 firebird
Axle/Gears: 323
I just use mother's car car spray. It soaks into plastic, stays shinny for days. And is easy to apply.
grngryoutmyway
May 22, 2004 10:12 PM
