eliminating the air dam on my t/a?
Old Mar 20, 2011 | 06:38 PM
itsMikey's Avatar
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
okay..first off
1. its ugly af
2. it scrapes EVERYTHING
3. my car could be lower if i didnt have it
SO! i was thinking maybe something like the Poly Motorsports T/A has for there i/c but for my radiator.
http://www.theblogofrecord.com/wp-co...t-trans-am.gif
maybe like the vette?
http://farm1.static.flickr.com/33/60...6ef543.jpg?v=0
like this?
http://rides.superstreetonline.com/r.../photos/1.html
Old Mar 20, 2011 | 06:42 PM
AmorgetRS's Avatar
Re: eliminating the air dam on my t/a?
IMHO, the air dam looks 1000 times better then a hole in the front of the car. Leave the air dam.
Old Mar 20, 2011 | 06:57 PM
quickkris2006's Avatar
Car: 1991 camaro vert
Engine: ls1 soon
Transmission: t56 soon
Axle/Gears: moser 12bolt 4.10 soon!
the first option doesnt look bad ive seen that black ta before but i wouldnt do it just leave the air dam
Old Mar 20, 2011 | 07:05 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
if its too low, you could trim it a little first.
dont cut a hole in the front of the car, besides the steel impact bar is behind the bumper and air wont flow through it.
Old Mar 21, 2011 | 12:59 AM
the solitaire's Avatar
Car: '89 RS camaro 305 TBI
Engine: LO3
Axle/Gears: yep, has those too (stock)
I had some clearance issues and solved it by building my own airdam which is only 4" high and slightly angled towards the front of the car.
Nearly invisible at first glance.
The fan is on more often as with a stock airdam however, but temperatures are low nonetheless.
I would definately advise against cutting up a good T/A. That last car is ugly as sin IMHO.
Old Mar 21, 2011 | 01:47 AM
itsMikey's Avatar
Engine: 5.7 350 TPI
hmm...may just get a new one and trim it..current one is kinda done
Old Mar 21, 2011 | 08:52 AM
NufNuffZ28's Avatar
Car: 1987 Iroc
Engine: 357 Single plane and a Ysi vortech
Axle/Gears: 3.50 9"
Yes, trim it or let it trim itself. My car was slammed so much I was eating fenderwell, well just the plastic part(oh the young days ), but I always kept my air dam on.
Old Mar 21, 2011 | 09:22 AM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
If it is really visible, the car is too high!
It is just plastic. Let it rub & clearance itself & slow down for dips & bumps..
You could go with a Cowl Induction hood with an open back, to let hot air out. That alone most likely won't allow a car to eliminate the air dam, but it can help eliminate underhood heat.
Old Mar 21, 2011 | 10:09 AM
NufNuffZ28's Avatar
Car: 1987 Iroc
Axle/Gears: 3.50 9"
Found a picture! I know I'm showing my age, but I still think it would look pretty current in it's form here.. Around 1998...
Old Mar 21, 2011 | 10:30 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
You really need the air dam - it's a critical part - without it you'll run too hot on the highway. All those pics you showed have an air dam of some kind under the car, you just don't see it in those pics.
Attack driveways and speed bumps at an angle, helps reduce the scraping - I never hit anything like that head on, always at an angle.
Old Mar 21, 2011 | 10:49 AM
Engine: LO3
Looks about the same ride height as mine.
Since I really have a clearance issue getting my car into my garage, and the car came without an airdam I spent $10 at a DIY and about 30 minutes at home and made a 4" high airdam.
The image is a bit dark. Didn't take my time adjusting the camera settings for that shot.
Don't mind the rust. I replaced most of the rusted parts and cleaned the others by now. Shot was taken shortly after I got the car. The shot was taken almost a year ago. Clearance under the airdam is about the height of a pack of smokes. I'd say somewhere around 5". Maybe 6.
Old Mar 21, 2011 | 11:02 AM
Firebat's Avatar
I ran without one for years on my 92 v6 Firebird. Never had overheating problems until I installed a 85-90 t/a front bumper on it and it was then I had to get an air dam. Keep in mind the 92 firebird front bumper is smaller, v6 engine takes up less space. One issue was the hood lifted up about an inch near the windshield at highway speeds. So I guess one thing that might help is getting a bumper without gfx?
Old Mar 21, 2011 | 11:05 AM
Firebat's Avatar
Is it made out of steel?
Old Mar 21, 2011 | 11:42 AM
Engine: LO3
Nothing quite as fancy as steel.
The 75 degree angle was previously a 90 degree angle.
The airdam itself is made of high density industrial foam.
It holds temperatures up to 160 degree F and resists corrosion caused by most fluids and even some acids.
The construction so far holds up fine. Fitted it nearly a year ago and been travelling about 3000 miles with the airdam and even though it looks flimsy (3mm thick) it's quite strong and held up against some impacts (rocks etc) as well as speeds up to 100mph (haven't travelled a lot faster then that up to now because I need new shocks and springs first))
Hotrodboba400
Dec 10, 2019 07:07 PM
db057
Apr 28, 2019 07:45 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
scotrans am
Sep 5, 2015 04:26 AM
Ian Irvine
Sep 4, 2015 08:08 AM
