Inner Fender Trim
Old Jun 26, 2011 | 09:37 AM
shawn18jgr's Avatar
Inner Fender Trim
Does anyone know anyone that sells this new? I guess I might have to repaint, and repair my cuurent ones. I have them out, and thought this would be an easy replacement part, but no one has them, JC, Summit, Ebay, on down the line. What is the technical name for this stuff? I just need the two front. Any help would greatly be apprciated! Shawn
Old Jun 26, 2011 | 08:07 PM
shawn18jgr's Avatar
Re: Inner Fender Trim
Guess everyone is clueless the same haha! Am I calling it the correct term, the front plastic up in the wheel wells. Splash Guard, or Inner Fender Wells, can't find them. I guess I will just try to make the originals the best I can vs just replacing with brand new ones.
Old Jun 26, 2011 | 08:27 PM
KonArtist's Avatar
Car: 1992 Camaro z28
Engine: 350 HSR
Axle/Gears: 3.42's
I took mine out and coated them in rubber undercoating and a nice coat of black paint. Then I went to Lowes and got some new fasteners, looks good as new now.
Old Jun 26, 2011 | 10:55 PM
shawn18jgr's Avatar
Thanks! Do you know what size? Did you use plastic rivets, or metal to install back? Thanks fo rthe good idea! CAr looks awesome! Shawn
Old Jul 2, 2011 | 12:13 AM
KonArtist's Avatar
Engine: 350 HSR
Axle/Gears: 3.42's
Sorry alittle late on the reply..
Dont remember what size but they were the push in type.
Like these :
Thanks Ive always been a fan of your car!
Old Jul 2, 2011 | 08:19 AM
onthedownlow's Avatar
Car: 1984 Camaro Berlinetta
Engine: 355
Axle/Gears: Australian 9 bolt 3.27 posi
Right on, mine are looking a little older, so I think I will pull mine out and paint them up nice. Would "trim black" be okay to use? Or should I use some black rubberized undercoating?
Old Jul 2, 2011 | 05:28 PM
KonArtist's Avatar
Engine: 350 HSR
Axle/Gears: 3.42's
Im sure it would work fine, I just did my rear wheel wells with the rubber undercoating so I had plenty left to do the fronts too. While the rubber undercoating was tacky I spayed some cheap walmart black paint over it to give it a nice black coat....rubber stuff was a brownish black.
Those little black things are only like 5$ for enough for both fronts.
Its amazing what nice black wheelwells do for a car......and its only a 10$ total.
Old Jul 11, 2011 | 05:37 PM
TPI TERR's Avatar
On Probation
Car: 87 IROC-Z
Engine: LsX
Transmission: MN12 6speed
Axle/Gears: 3:42
I've been looking for new front inner wheel wells
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
jovibuilt
Exterior Parts Wanted
Oct 18, 2015 08:12 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
