are these rims beyond help?
Old Aug 8, 2011 | 04:56 PM
marballfire's Avatar
Car: 88 Camaro SC
Axle/Gears: 3.42 POSI
Hey guys. I recently got a full set of C5 rims for free, but the insides of the rims got some nasty stuff goin on that i can't get rid of. Its looking to me like the only answer is resurfacing the rims, but I thought i'd check here and see if anyone has any thoughts.
this is what i'm lookin at.
Attached Thumbnails are these rims beyond help?-dscn0440.jpg   are these rims beyond help?-dscn0441.jpg
Old Aug 8, 2011 | 06:00 PM
cavazos31's Avatar
Car: 1988 camaro sports coupe
Engine: Fast Burn 385
Axle/Gears: 9 bolt w/ 3.27 gears
Re: are these rims beyond help?
Refinish them. If those are aluminum, which they appear to be in the pic, you can do so fairly easy. Attack it with some heavy grit sandpaper, maybe 80 or 120 to remove the pitting. From there use finer and finer papers to smooth out the surface. A handheld orbital sander or cornercat (triangular shaped handheld sander) saves you a LOT of time.
Old Aug 8, 2011 | 06:23 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
the clear has failed and you have some pretty heavy oxidation starting. You will have to sand them down to get rid of all the oxidation and markings, then re-polish.
Old Aug 8, 2011 | 07:05 PM
Car: 88 Camaro SC
alright cool..I'm glad to know its something i can do myself. What do i need to do to re coat them once i sand it down so that this doesn't happen again?
Old Aug 19, 2011 | 03:04 PM
88TransAmGuy's Avatar
Car: 88' White-Black Trans Am
Engine: Trying to find a motor
On my stock crosslace rims,the same thing is happening. The clear failed and they oxidized on the ring of each rim. I sanded it and it didnt help much. Im considering just having them dipped
Old Aug 20, 2011 | 12:33 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
It will just take patience - you can always save aluminum as long as there aren't huge deep gouges through it.... material missing (think curb rash), that sort of thing. Just a matter of removing the damaged surface and then smoothing out the underlying surface - ie polishing.
Old Aug 21, 2011 | 10:05 AM
Blackdog36's Avatar
Car: 92 Z28
Engine: LS3
Transmission: TR6060
Axle/Gears: Strange S60 3.73
There are two ways to maintain rims after you polish them. First is to spray on a clear coat. However clear coat will slightly dull your shiny finish that you just spent all that time polishing. Second option is to put a coat of wax on them. This requires regular upkeep but will keep rims looking the best.
Old Aug 26, 2011 | 12:43 PM
Car: 88 Camaro SC
Just thought i'd post a pic or two of the turnout. I haven't had a whole lot of time, so I just finished the first rim today. Pretty significant improvement I'd say! The finished product and a side-by-side comparison to one of the 3 other equally oxidised rims.
Attached Thumbnails are these rims beyond help?-dscn0446.jpg   are these rims beyond help?-dscn0448.jpg
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
kitt23
Exterior Parts for Sale
Nov 28, 2015 06:26 PM
dbrochard
Oct 10, 2015 01:03 PM
dbrochard
Oct 10, 2015 01:02 PM
