aftermarket bumper/marker lights...
Old Nov 1, 2011 | 02:13 PM
skip91's Avatar
Car: '91 RS, '64 C10 Stepside
Engine: 305 TBI, '00 5.3
Transmission: Manual, Automatic
Axle/Gears: 4th Gen with 3.42, 4.10
As with any 20 year old car, somethings just aren't aging very well. I'm looking to replace my original bumper lights as well as my side marker lights with the clear ones commonly found on ebay (http://www.ebay.com/itm/85-92-CHEVY-...48062380709432). I've done some looking around and there are a couple of examples, but I would like some opinions and more so, some pictures of them installed, especially head on shots with them turned off and on.
Old Nov 4, 2011 | 08:06 PM
Dustytrix's Avatar
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
Axle/Gears: 373 zexel torsen
Re: aftermarket bumper/marker lights...
Looks like a good deal to me, I ordered the clear side marker lights for mine last nite. I have seen these installed and they look great.
Old Nov 5, 2011 | 12:32 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
main thing to remember when switching to the clear side markers is you have to change the bulb to an amber bulb instead of the stock clear one.
Old Nov 6, 2011 | 08:21 AM
skip91's Avatar
From the couple of pictures I've seen with the clear bumper lights, you need to change those to amber as well, correct?
Old Nov 6, 2011 | 08:58 AM
travis401's Avatar
Car: 91 Camaro RS
the front turn signals should be amber bulbs from the factory.
Old Nov 6, 2011 | 09:26 AM
skip91's Avatar
Thanks for the info travis401. I've been fortunate when it comes to bulbs on mine. The only bulb I've ever had to replace was one of the side marker lights. She was born on 17 AUG '90 and I bought her on 12 DEC '90. First car I ever owned and still have her. As far as I'm concerned, I'll have here for the rest of my life.
Old Nov 8, 2011 | 01:56 PM
maroman88's Avatar
Car: 88 Camaro Coupe - 99 Corvette
Engine: 305TPI - LS1
Transmission: A4 - A4
Axle/Gears: 3:73 - 3:15
heres mine on my 88... with a white LED bulb
Old Nov 8, 2011 | 02:01 PM
skip91's Avatar
Does it light amber though?
Old Nov 8, 2011 | 02:04 PM
travis401's Avatar
Car: 91 Camaro RS
white bulb in a white housing isnt street legal for front turn or marker lights.
Old Nov 8, 2011 | 02:27 PM
maroman88's Avatar
guess your not in Jersey
NJ title 39:3-50. Color of lights, permits; cancellation or revocation of permits; fee.
39:3-50. All lamps and reflectors, which display a light visible from directly in front of a vehicle as authorized by this subtitle, shall exhibit lights substantially white, yellow or amber in color.
(a) The color of light emitted or reflected by exterior lamps or reflectors on a vehicle shall be as follows, except as otherwise provided in paragraphs (b), (c) and (d) of this section:
White when the lamp is a headlamp, or spot lamp, or illuminates a license plate or a destination sign; or is located on the outside limit of a side car or other attachment on a motor cycle;
Substantially white or amber when the lamp is a side-cowl or fender lamp, running-board or other courtesy lamp, front parking lamp, back-up lamp, auxiliary driving lamp; or a turn signal on or facing the front;
Substantially red or amber when the lamp is a turn signal or a stop lamp on or facing the rear;
Red when any other lamp or any reflector is on the rear or on either side at or near the rear, except as otherwise provided in paragraph (f) of section 39:3-61 for a combination marker lamp;
Old Nov 8, 2011 | 02:36 PM
travis401's Avatar
Car: 91 Camaro RS
usually its amber only for front turns.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
