Does anyone keep this on their car?
Old Jan 2, 2012 | 02:29 PM
sonofshin's Avatar
Car: 91 Formula Firebird
Engine: 5.7 TPI
All I can't really figure out why this is on here, it doesnt really protect anything. Is it a big deal if I take this off? I want to lower my car with the Eibach Sportlines, and all this will do is hit every parking curb or rub when I enter parking lots.
Old Jan 2, 2012 | 02:30 PM
jaben2's Avatar
Re: Does anyone keep this on their car?
I believe you have to keep it. Not sure why, but I remember hearing of car overheating without it.
Old Jan 2, 2012 | 02:39 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
A part of the air damn. You can't remove it or you'll car will over heat
Manic Z's Avatar
Car: 1985 Camaro IROC-Z
Transmission: GForce T-5
Axle/Gears: 10 bolt 3.73 posi
It's true. The car will overheat. It directs air up to the radiator.
Old Jan 2, 2012 | 02:43 PM
sonofshin's Avatar
Engine: 5.7 TPI
Damn =/ Thanks everyone!
Old Jan 2, 2012 | 05:05 PM
'87IROCZOWNER69's Avatar
Car: 1987 IROC-Z and 1988 Iroc-Z
Engine: 5.7 350 V8 and 5.0 305 V8
Transmission: 700R4 Automatic Transmission
Axle/Gears: 3.27 Posi
Well you could remove it but you would have to fabricate a new way to get air directed into your engine bay.
Old Jan 2, 2012 | 05:13 PM
91specialk's Avatar
Car: '91 Formula
Engine: 305 TBI
Transmission: Newly rebuilt 700R4
and... if you removed it... what else would you scrape when you..... well.... drive anywhere?
Old Jan 2, 2012 | 05:25 PM
sonofshin's Avatar
Engine: 5.7 TPI
well now that i know it actually serves a purpose, im going to leave it on
Old Jan 2, 2012 | 10:21 PM
itsMikey's Avatar
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
i always scrape that damn thing..i scrape the exhaust sometimes too on the harsher dips and stuff..
reference pic
Old Jan 2, 2012 | 10:43 PM
QUICKCHICKEN's Avatar
Car: 89 Firebird
Engine: 6.0 LS
Axle/Gears: 3.70
i took my orig dam off of my 89 and put a 82-84 dam on my car because its deeper than my FORMULA dam. works so well i have found dead things between the condinser and the rad support lip.
i seen an air dam on another car when i first got my 83 and thought it looked pretty kool, found out that was a needed item. they can be found on ebay and if you decide on the 82-84 version i'll show ya what i did to mount neat and clean it being the mounts are a bit differnt.
Old Jan 2, 2012 | 10:44 PM
camarosrock1989's Avatar
Car: 1989 Camaro RS--
Engine: MPFI
Very important part, I didn't have mine on when i bought it. Was over heating and changing and flushing rad. Then started reading post and got a airdam, no more over heating! I think it looks good on. You have a really sweet looking car, very clean!
Old Jan 2, 2012 | 11:31 PM
Andrew James's Avatar
Car: 1990 Formula Firebird
Engine: 350 (5.7) TPI
Transmission: WC T5
Axle/Gears: 3.42 POSI
I have no air dam, my car does not overheat?
I remember on my Bronco forum everyone joked about Chevys needing these...
Old Jan 3, 2012 | 06:19 AM
plasmeh's Avatar
Car: 1986 IROC-Z
Engine: 360cu @ 10.5:1
Transmission: T56 - Pro 5.0
Axle/Gears: 4.10 - Zexel Torsen - Moser Axles
^ Don't follow this guys advice. You NEED the air dam. It throws air from your moving car up through the rad to cool the coolant at speed. Without it, your heavy-working engine will gradually rise in temperature because there is no air cooling the coolant, and you'll overheat.
Old Jan 3, 2012 | 07:09 AM
freaky's Avatar
Car: 88 camaro irocz
Engine: l98 tpi
Axle/Gears: 2.77
leave it on
Old Jan 3, 2012 | 07:30 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
We dont have giant open front breathing radiators like Broncos do. Our cars are, literally, bottom feeders. They suck cool air in from the bottom, like pretty much any C4+ Corvette.
Old Jan 4, 2012 | 12:18 AM
sonofshin's Avatar
Engine: 5.7 TPI
Ya I don't really have a problem with the way it looks, I just scrape it some times coming into parking lots... even when I come at it sideways (that's what she said) Anyways, enough of the jokes.
I get it, creates a vacuum for air, SMART. lol.
And thank you, the car was garaged for about 16 years, really nice condition still.
And also, Thank You everyone else! It's staying on.
Old Jan 4, 2012 | 12:52 AM
jahblah's Avatar
Car: 87' Firebird Formula
Wish i had read this months ago...and with my first bird too lo i removed it for better looks. Didnt know it served purpose but i dont overheat soo yea, Wouldnt mind running cooler either though. Oh well :-)
Old Jan 4, 2012 | 01:01 AM
mjdavis68's Avatar
Car: 88 IROC Z/28-under re-construction
Engine: 5.7 Tuned Port
Transmission: It's in there....
Axle/Gears: 9 bolt Borg-Warner
NO! Air Damn
Old Jan 4, 2012 | 09:26 AM
Transmission: WC T5
It wasn't advice, it was a question. Hence the question mark.
Are there better air dams available than the stock piece?
Old Jan 4, 2012 | 09:54 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
If you don't drive the car it stands to reason it will not overheat....
Old Jan 4, 2012 | 01:48 PM
Transmission: WC T5
I drive my Firebird daily, to work and etc...
Old Jan 4, 2012 | 10:37 PM
4FishLimit's Avatar
Car: 1986 Trans Am
Engine: LB9
Transmission: TH700R4
Axle/Gears: 2.73 & LSD
Why not just trim it?
I don't think there's anything stating it has to be a certain height/length, however I bet it's relationship to the ground is the deciding factor on how effective it is.
Old Jan 5, 2012 | 02:37 AM
3318RS's Avatar
Car: 1990 RS
Transmission: Built-700R4
Hey I have the sportlines on my car & it will be fine. YES, it does scrape, but you get used to it & YES like many have said, you need it.
I have the same issue with my vette, I lowered it & my air damn scrapes everywhere.....Hey at least it's the damn air damn & not the actual bottom of the front bumper...LOL
Old Jan 9, 2012 | 02:00 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
I've found, in my own experience, that you can get away with taking the lowest, wrap-around part, off, and leave the rest. And it does tend to get pretty hot here sometimes (hit about 100* out last summer, for instance).
But, then, you have a different style than I do. You can take the outer lower corner pieces off and then shave the middle if you want...
Old Jan 10, 2012 | 07:21 PM
82tarecaro's Avatar
I have never had it on and the car never overheated. Mine is an 82 TA, and I do have the grilles on it, so it is possible that is why I never had any issues. I plan on putting one on after I have it painted .
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
