New wheels, cleaned the car a little.
Car: 1991 Firebird
Engine: 3.1L V6
Finally got the wheels/tires on the car and got it cleaned up. Still have a lot of detailing to do because the car sat for over a year collecting dirt and spider webs.
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Re: New wheels, cleaned the car a little.
I hate that hood with a passion but you have the perfect storm of elements to pull it off and make it look decent. Beautiful car, sir.
Car: 1991 Firebird
Engine: 3.1L V6
Thank you everyone, it has taken me 8 years just to get to this point. Still needs so much more, like upgraded brakes all the way around.
SD, yes, not the best pictures because I took them with my phone, scenery isn't spectacular either but I will have some professional photographs taken hopefully soon.
Infernal, I have considered selling the hood because i'm not happy with it's fitment. I love how it looks though. Thank you for the compliment.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
more wheel shots! curious to see how the rear fit, since my new wheels are a similar fitment. what kind of rear metal work for those wheels?
Car: 1991 Firebird
Engine: 3.1L V6
//<86ta>\\, They fit awesome. I felt around inside the inner fender wells on the rear and it is very close, can't get my fingers in there. I haven't driven it yet and before I do I plan on massaging the inner fender a little with a BFH. Wouldn't need much.
Car: 86 Trans Am
thats good to know, my wheels have 27mm offset, i believe yours were 20?
looks good! What rear tire size? 295/35? same tire (bfg) im planning to use too
Car: 1991 Firebird
Engine: 3.1L V6
COTM Editor
Car: 89 325is, 91 z28
Engine: 2.5l 6, l98
Transmission: t56
Axle/Gears: 3:42
Are those 9.5 or 10 in the rear also what spacers did you use? O have xxr 521 in 18x10 and 18x8.5 with close to your offsets. I came up with 3/4 fronts and 1/4 rear curious what yours are. And the car wheel combo is dead on.
Car: 1991 Firebird
Engine: 3.1L V6
I bought one 295 on ebay new for $75 which was mounted on a replica mustang billet wheel. I unmounted it and mounted it on my XXR, then I sold the replica wheel on ebay for $75. The tire was free basically. I then bought the other 295 from discount tire direct for $256. If you wait to a certain time a year I have seen the 295's down to $236ea. Fronts I ended up paying $207.50ea.
resop, 9" fronts and 10.5" rears. I used 1.25" spacers in the front, the rears fit perfectly(minus some inner fender massaging.)
Car: 91 Z28
Axle/Gears: Stock
I agree with the sentiments regarding the hood. Other than that, it looks good.
**Edit** The experience I have with the XXR's shows that the front hub hole is too small. Did you open it up? What did you do for a cap? Can't tell by the pics. Thanks.
Car: 1991 Firebird
Engine: 3.1L V6
No, I did not open it. Because I went with a 1.25" spacer, it pushed the wheels out enough that the hub wasn't an issue. The dust cap I massaged in slightly so the center caps would go on.
Car: 85 z28,01 sonoma,05 envoy
Engine: 305 tpi
Transmission: 700 r4
Axle/Gears: stock
your car is the only car i have seen sucessfully pull that ram air hood off. Looks perfect
Car: 1991 Firebird
Engine: 3.1L V6
Car: 86 Trans Am
Car: 1991 Firebird
Engine: 3.1L V6
Car: 1989 Camaro RS--
Engine: MPFI
I love that hood! Makes it look like it breathing! My favorite look on these cars!!
You car is one sweet ride! Great job
Car: 1991 Firebird
Engine: 3.1L V6
I have a set of GM emblems that I as thinking of painting black...either all black or black with red GM and underline to it. When I do my brake upgrade the calipers will be red also.
I was thinking of putting them just behind the front wheel on the rocker ground effects. Thoughts? I've also seen them at the beginning of the door guard strips.
Car: 86 Trans Am
personally i HATE that gm emblem/plaque on anything. Thats just me.
Car: 1991 Firebird
Engine: 3.1L V6
I will probably apply it with painters tape and see how it looks. That area of the car just looks empty to me. Then again i'm afraid of overwhelming the car with too many black accents. That's one reason I undid the blacked out taillights.
Car: 1991 Formula
Transmission: 5-speed
Hi Charcoalbird, Very nice car. Really like the color. I have a question. Are you running the 18x10.5 on a stock third gen rear end? I couldn't find it in your posts and was just curious? Thanks.
Car: 1986 IROC-Z
Axle/Gears: 4:10
XXR makes some of my favorite wheels on the market. I wish the restrictive work network would let me view the images. I'll have to check it out when I get home!
Car: 1991 Firebird
Engine: 3.1L V6
Yes miaojo, it is the stock 3rd gen rear end. And thank you for the compliments.
Car: 1989 Formula WS6
Engine: L03 305 TBI
Axle/Gears: 10 Bolt; 3.42 Posi
Bringing this thread back to life ....
Those wheels look great!
I'm pretty sure you said you didn't run spacers on the rear.
Aren't those 5 x 120? If so, how did you get them to fit?
Car: 1991 Firebird
Engine: 3.1L V6
Thank you, Sean.
No wheel spacers on the rear. I used wobble nuts to help correct the .65MM difference in bolt pattern.
Since those pictures I have tinted the Windows and lowered it some.
kah992
Aug 19, 2015 02:55 PM
db057
Aug 11, 2015 10:11 PM
