Save the carpet!
Old Jul 25, 2012 | 07:32 PM
fyrebird68's Avatar
Save the carpet!
Pulled the carpet out of the TA and it was terminally nasty. I decided to try some out-of-the-box thinking.
I soaked it in a whole canister of oxiclean. Needed a tub big enough to hold it, so..........
Check out the brown water. I'll let you know how it comes out
Old Jul 25, 2012 | 11:45 PM
Blue1990camaro's Avatar
Re: Save the carpet!
EEEEEWWWWW! good idea tho mines rough but not THAT bad lol, a guy on here sugested shaving cream but hey it worked on his so im gona try it too lol
if not then ur solution is what ill do
Old Jul 26, 2012 | 07:36 AM
haps's Avatar
Car: 91 Z28
Axle/Gears: Stock
Well now. Good thinking.
Old Jul 26, 2012 | 09:46 AM
BADNBLK's Avatar
COTM Editor
Shaving cream as a spot treatment. It sounded crazy untill I saw how well it worked.
Old Jul 26, 2012 | 01:57 PM
yea my carpet is worn out just has dirty spots and stuff of that nature in the foot wells, i had to replace my irocs carpet because some idiot spray painted it black....
Old Jul 26, 2012 | 02:27 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
thinking "outside the box" , ya gotta love it . will put your idea in the memory bank "bag of tricks" . hope it turns out well for you . good luck .
Old Jul 26, 2012 | 08:31 PM
Caveman305's Avatar
Car: '89 RS, '89 Iroc
Engine: L03, LB9
Transmission: 700r4, T5
Axle/Gears: 2.73, 3.08
i can attest shaving cream works great for spot treatments, my dad showed that trick to me when i was about 14 and ive been using it ever since(car typically smells great afterwards too), Oxiclean or any other cleaner of that sort is amazing if you can soak and scrub in a big enough tub, lol, great thinking!
tips for the shaving cream though, use a tooth brush(or larger if you need) and keep a wet rag handy,
squirt a little shaving cream, scrub with brush, wipe with rag, repeat as necessary until spot is gone
Old Jul 27, 2012 | 07:51 AM
fyrebird68's Avatar
Took the carpet out of the soak (MAN that water was nasty) and power-washed it at the car wash. I shot it for 5 minutes, until the water ran off clean.
Came out nice. I'd say it was 75% oxiclean and 25% quarter-car-wash that did the trick.
Only drawback is now I can see the differences in color where the parts not covered by the console and the seats have faded. But at least it's nice and clean. As soon as it dries out I'll post a pic. It may take a while to dry. That carpet must have weighed 100# when it was wet!
Old Jul 29, 2012 | 03:14 PM
fyrebird68's Avatar
Pic of the clean,dry carpet:
[IMG]
Only thing that did not come out was the rust stains from the seat track bolts.
Wish I had taken a pic of the dirty one, because this is a MAJOR achievement!
I still have the back half to do. It's not as bad as this one was but I'll be sure to get a "before" and an "after" shot.
Old Jul 29, 2012 | 09:03 PM
Scorpner's Avatar
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
You may need something specific to remove the rust stains. CLR comes to mind but I don't know if it would damage the carpet and/or backing. I would leave it as is since it isn't visible anyways.
That's a pretty cool idea. I ran a household rug shampooer on one of mine and got quite a bit out (nasty water too), but I couldn't get to the contours very well.
Old Jul 30, 2012 | 11:43 AM
Pro-mo's Avatar
Car: 1988 IROC Z
Great idea !!
Old Jul 30, 2012 | 12:02 PM
BADNBLK's Avatar
COTM Editor
[IMG]
Man that fading is serious. I think I would look at finding another set.
Old Jul 30, 2012 | 12:07 PM
fyrebird68's Avatar
This'll do until I can afford new. At least it smells nice and doesn't have any food in it!
Old Jul 30, 2012 | 12:46 PM
BADNBLK's Avatar
COTM Editor
I hear ya. Old clean carpet is better than dirty old carpet... gigity
Just a job I wouldn't want to do twice
Old Jul 30, 2012 | 02:07 PM
lonestar7's Avatar
Car: 1988 Firbird formula 350
Engine: 5.7L TPI
Axle/Gears: 3.27 Nine Bolt
[IMG]
Get some CLR, spray the rust spot until soaked good and work it in with a clean cloth or brush. Let it dry, vacuum spot, then wet good it with fresh water and a clean cloth. Either wet vac or blot up water/CLR residue thin clean cloths, let dry, repeat if needed. It may not completely remove heavy rust stains, but it helps a lot.
92projectcamaro
Dec 8, 2015 12:25 AM
SRKLEGIN
Sep 30, 2015 07:19 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
indygene
Sep 26, 2015 11:21 AM
