View Poll Results: October Car Of The Month
BADNBLK
33
20.00%
Orr89RocZ
6.06%
Leedavidalan
4.24%
Project89
9.09%
1bad406
3.03%
SinsterZ
6.06%
1meanZ
20
12.12%
xpndbl3
29
17.58%
BOTTLEDZ28
4.85%
TPITERROR
28
16.97%
Voters: 165. You may not vote on this poll
October COTM **Voting**
Old Sep 17, 2012 | 09:47 AM
BADNBLK's Avatar
COTM Editor
Ok here we go! Let put it to a vote and see who has the nicest Camaro this month.
BADNBLK
Orr89RocZ
Leedavidalan
Project89
1bad406
SinisterZ
1meanZ
xpndbl3
BOTTLEDZ28
TPI TERROR
What an amazing group of cars we have to pick from this month!!! Super proud to be in this group. Let's VOTE!!
Old Sep 17, 2012 | 12:45 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: October COTM **Voting**
So glad to have been nominated....here's a little bio of the car, and some specs on it.
gen 3 motor swap, super victor intake, custom EPS cam, quick fuel carb on top
th400 with 8" ptc converter and trans brake
moser 9" with aluminum center and spool, 35 spline axles, 5/8" studs
full chro moly double rod ended rear suspension
6 point roll bar I installed
wolfe mini tub and spring adjusters in rear, racecraft coilover setup up front
founders performance caster/camber plates
ls1 front brake swap
billet specialties street lites, 15x10 6.5" bs, 17x7 front, 295/55 m/t drag radials, 215/55R17 front radials
4th gen dash, autometer gauges mounted behind the clear plastic stock gauge cluster
kirkey seats
Thanks in advance for your support! Thousands and thousands of hours into this car. Probably a thousand drag strip passes too
Old Sep 17, 2012 | 01:12 PM
91CamaroRS305's Avatar
Car: Only a daily driver, but comin home
Engine: I have one that runs ;)
Transmission: Caged hamster that runs really fast
Axle/Gears: They are round, I know that much
I don't always post, but when I do post it is because I voted for Xpndbl3!
To everyone else, very fine looking cars there!
Old Sep 17, 2012 | 01:25 PM
BADNBLK's Avatar
COTM Editor
Here are some more pics/info of my 91 Z28.
Engine:
305
TPI, Coated Hedman Shorty headers, QTP cutout, gutted cat, Hooker Aerochamber cat back, MSD Pro billet distributor, MSD 6AL, MSD coil, MSD wires, AFPR, airfoil, K&Ns, plenum P&P, underdrive pulleys, 1.6 roller rockers, Cloyes double roller TC, free mods,
Trans/Rearend:
1996 T56. SPEC stage 2.5 clutch, Alum. flywheel, Hurst shifter, MBA polished shift ****, 3.73 gears, stud girdle cover,
Suspension:
Eibach Sportline springs, polished Hotchkis STB, polished aluminum factory driveshaft, Spohn adj wonder bar, Spohn sway bars, Spohn adj panhard, Spohn adj lca, Spohn SFC, Spohn LCRB's, full poly bushings, powder coated front control arms, Hotchkis solid tie rod sleeves,
Brakes & Wheel/tire:
Baer track plus brake kit with 2pc rotors, and polished calipers, 18x9 & 18x10" ROH Drift R's with polished lips and center caps, BFG Gforce 275/35r18 front, and 295/35r18 rear tires.
Interior:
Full custom leather interior from Mr.Mikes including door panels, Z28 embroidered in seat backs, Pioneer Premier 4x6 plate component & Premier 6x9 4way powered from 400watt JBL amp. JL audio 12 subs in matching carpeted box, powered by 750 watt JBL amp. All wiring and amps hidden. Shutt tuning steering wheel on a momo adapter, Mcewan silver face Gauge overlays, Autometer procomp 5" tach/shiftlight under vents, MBA Billet 3rd gen pedal set, ACC embroidered Z28 floor mats, full Dynamat treatment under "new" ACC carpet. Polished billet dash emblem.
Body:
Custom Heritage stripes in 96 Corvette teal metallic, teal paint in the "vents" on GFX, custom polished billet emblems, shaved nose emblem, smoothed and painted air filter box, REAL carbon fiber Z28 grill, customer shorty antenna, custom polished billet hood hinges. Painted and detailed underbody.
Ran a best of 15.01 - 92 MPH on street tires before T56 @ 5800ft elevation
Old Sep 17, 2012 | 06:23 PM
project89's Avatar
1989 rs camaro this car gets daily driven everywere from the grocery store to couple hundred mile round trips without issues
originally a 2.8L v6 car i swaped in a built 3.1L v6
std bore 3.1
keith black hyper pistons with coated skirts,plasma moly rings
arp main studs and arp rod bolts
custom speced delta camshaft
massivley ported heads/intake
one off custom 321 stanless turbo headers
garrett/fullrace t3/60-1 turbo
megasquirt 1 v2.2 running msn extra code
tci super street fighter converter restalled to 4,500 rpms
fully built 7004r with tci master rebuild kit
4:10 rear gears and spool
340RWhp and 430RWftlbs @ 9 psi
Size:  200.2 KBName:  8-251B101.jpg
Old Sep 17, 2012 | 07:11 PM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
It's an honor to have been nominated! Thanks guys!
Most know about my car here, but I'll post some of my pix. My car is really not all that exotic, but as the pictures show, it gets used for it's intended purpose.
Old Sep 17, 2012 | 07:17 PM
BOTTLEDZ28's Avatar
Transmission: A4
Here are a couple pics of my car:
Specs: 383 stroker engine, Nitrous Express wet kit with 200hp jets, AFR heads, Hooker LTs with custom made 3" ypipe dumping into a hooker muffler, custom grind Comp cam, all forged internals, HSR intake and a complete March performance mid mount serpentine belt setup.
T56 transmission with Spec stage 3 clutch
full Spohn suspension and C5 Z06 brakes and Koni yellows
FAST engine management ECU.
fully dynamatted interior with a 600 watt sound system hidden in the rear seat backs.
Old Sep 17, 2012 | 07:24 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
what are you guys painting the bottom of your cars with? any real prep or just spray it down?
+1 for scuba steve
Old Sep 17, 2012 | 07:43 PM
1bad406's Avatar
Car: 1987 Camaro
Engine: 406
Transmission: Powerglide
Axle/Gears: Moser 31 spline / 4.86
Stock 400 block, Brodix track 1 heads, .582 .588 lift cam, victor intake, AED alcohol 750
Glide with pro brake, Moser 9", Spohn Pro series TA, off set LCA's, sway bar, wonder bar and SFC's. PA Racing K-member, Arms and front coil over conversion. Full Interior, 3200lbs
Best ET 6.49 @104 1.38 60'. Raced at least twice a month from March til November.
Attached Thumbnails October COTM **Voting**-254939_4057818456465_525402452_n.jpg   October COTM **Voting**-546654_4057836456915_1917216573_n.jpg
Old Sep 17, 2012 | 09:05 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
I dont know if I can vote on this one, there are way too many cars I like in this one, it wouldnt be fair haha. This may be the best month yet besides the first one. Great examples of thirdgen camaros here
Old Sep 18, 2012 | 12:14 AM
cal30_sniper's Avatar
Car: 88 GTA/86 C20 Burb/91 325i
Engine: L98/454/M20
Transmission: 700R4/NV4500/Getrag
Axle/Gears: 3.27 9-bolt/3.73 14 Bolt/3.73 IRS
I agree, there's some great cars this month. Definitely several works of art.
Old Sep 18, 2012 | 02:06 PM
BADNBLK's Avatar
COTM Editor
I pressure washed mine, then hit is all with a scotchbright pad in fine grit, and wiped with wax grease remover. I then used tin foil to wrap lines and stuff. Used the Eastwood Extreme Chassis black. I used the Eastwood detailing paints for the heat shields and fuel tank etc. Very easy to apply and has been durable enough for my limited driving.
Old Sep 18, 2012 | 03:18 PM
Lmancha96's Avatar
Car: 1992 Camaro (Z28 Clone)
Engine: LB9|TPI
Old Sep 18, 2012 | 03:51 PM
silentkillzr's Avatar
Car: 1984 Firebird (89 Formula Clone)
Engine: 357
Transmission: m29 T56
Axle/Gears: 3.27 9 bolt Borg Warner.
Wait a second how is the COTM editor able to have his own car in the voting. Seems a bit not fair lol.
Old Sep 18, 2012 | 04:07 PM
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Transmission: 700R4(blown)
Axle/Gears: 3:73
^ realy?
Did you read the rules?
Old Sep 18, 2012 | 04:22 PM
BADNBLK's Avatar
COTM Editor
As the COTM editor, I have no powers to change the voting anymore than any other member by posting great pics of their cars. Its all member based and I can't edit the votes. All the nominations are beautiful camaros, and I happen to have one too... it would be a bit not fair to be excluded because I take the time out of my day to set this up every month for OUR community, because I help.
Zach/90\irocZ's Avatar
Car: 88 Formula, 90 Iroc RIP, 92 RS Sold
Engine: 305 to 350
Axle/Gears: 10 Bolt
wow really sweet cars up there
Old Sep 18, 2012 | 06:15 PM
Lmancha96's Avatar
Engine: LB9|TPI
I agree, your car deserves to be up there just as much as all these other guys.
Old Sep 18, 2012 | 06:19 PM
Engine: 305 to 350
Axle/Gears: 10 Bolt
Old Sep 19, 2012 | 01:06 PM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
1meanZ is exactly the way I love cars to be built. Beautiful, OEM-like appearance, and competition prowess underneath.
I love the independent rear mod. I hope you win!
Old Sep 19, 2012 | 02:19 PM
TPI TERR's Avatar
On Probation
Car: 87 IROC-Z
Engine: LsX
Transmission: MN12 6speed
Axle/Gears: 3:42
up against so many good looking cars!
my car went through a new make over year ago
new paint, new wheels, new tires, new rear air diffuser, one off true duals and custom tips.
my next dash goes well with my 4th gen trans am panels
Old Sep 19, 2012 | 02:34 PM
mw66nova's Avatar
Engine: 7.0L
^^corvette dash?
Old Sep 19, 2012 | 02:52 PM
Engine: 305 to 350
Axle/Gears: 10 Bolt
no thats a pontiac gto dash
Old Sep 19, 2012 | 03:26 PM
EjBaL's Avatar
Bottlefed, your car looks SO much better with that ss hood and painted headlight buckets!
Old Sep 19, 2012 | 06:32 PM
fasteddi's Avatar
Car: 1991 Camaro RS
Engine: Lq4 6.0 SBE s485 turbo E85
Transmission: Fsi th400 stage 4. TSI 5500 st
Axle/Gears: Strange S60 4:10s
Some truely beautiful cars on here. Great examples of thirdgens.
Props to you all
Old Sep 19, 2012 | 06:43 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Damm, SO MANY NICE ONES HERE. I almost don't want to vote cuz I like em all. This one is gonna take some thinking. Do I base it off looks. Performance. or do a point system and tally em all and come down to just one...
Ok Im off to rack my brain and vote for one. GOOD LUCK TO ALL OF YOU. ALL CARS SHOWN DESERVE IT THIS TIME.
Old Sep 19, 2012 | 08:06 PM
Phenom-1's Avatar
Car: 1992 Chevrolet Camaro Z28
Engine: 5.7 TPI
Transmission: 700R4 Overdrive Automatic
Axle/Gears: 3.23:1 Positraction
I'm Stuck between my 3 favorite Nominations.
BADNBLK
1MEANZ
BOTTLEDZ28
I CANT DECIDE ?!
Old Sep 19, 2012 | 08:10 PM
Phenom-1's Avatar
Engine: 5.7 TPI
This is One BADD Camaro too
LEEDAVIDALAN
Old Sep 19, 2012 | 09:42 PM
IrocRoadRacer's Avatar
Car: 1989 Camaro Iroc Z
Axle/Gears: 9 Bolt Borg Warner/ 2.77 gear
+1 for LEEDAVIDALAN
Old Sep 21, 2012 | 10:09 PM
camarosource's Avatar
Car: Custom 1992 Camaro Z28 25th Anniver
Engine: 5.7L V8 350 L98 TPI
My apologies, it appeared there were other cars being submitted, I've removed mine.
For me, I've always loved the way BADNBLK looked. It's SUCH a unique looking touch to have the turquoise highlights in the ground effects. :-)
Old Sep 22, 2012 | 06:00 AM
mw66nova's Avatar
Engine: 7.0L
^^this car is not in the vote, why is it posted in this thread?
Old Sep 22, 2012 | 06:40 AM
Lmancha96's Avatar
Engine: LB9|TPI
Old Sep 24, 2012 | 09:45 PM
sailtexas186548's Avatar
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
Originally Posted by 1bad406
I cannot believe this car does not have more votes! that is a bad *** camaro sir
Old Sep 28, 2012 | 11:57 AM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
edit
Old Sep 29, 2012 | 11:19 AM
Linson's Avatar
COTM Editor (Retired)
Car: 89 Formula 350, TTA
just curious. is it always either/or (Firebird or Camaro) or is there ever months when Firebirds and Camaros compete?
Old Oct 1, 2012 | 09:56 AM
BADNBLK's Avatar
COTM Editor
Yep there is "open" months were any thirdgen can be nominated. We had a bird month, then Camaro month, and now we will have a open month.
Gotta say I could not be happier getting win this. Thank you to all that voted for my car. Got a lot of respect for each of the cars this month. What a great group of cars!
Old Oct 1, 2012 | 10:29 AM
84ws689bird's Avatar
Car: 1988 IROC
Engine: 5.7
Axle/Gears: 2.77 posi
Congrats and well wishes!!! Oh, and good job winning COTM also, LOL
Old Oct 1, 2012 | 10:37 AM
BADNBLK's Avatar
COTM Editor
On the wedding? LOL Thanks buddy it was perfect. Should have some cool pics of the Camaro and my bride too!
Cell phone teaser
Old Oct 1, 2012 | 10:55 AM
CharcoalBird's Avatar
Car: 1991 Firebird
Engine: 3.1L V6
Cell phone teaser
I didn't take my car or get any pictures with it at my wedding in June. Congrats on the marriage and COTM.
Old Oct 1, 2012 | 11:01 AM
BADNBLK's Avatar
COTM Editor
THANK YOU! She surprised me last minute telling me she had arranged for the photographer to take pics of us with the car, so I had to bring it!
Linson
Oct 24, 2025 02:00 PM
sp8ty
South East Region
Sep 24, 2018 03:55 PM
Thirdgen89GTA
Nov 26, 2015 11:04 PM
sp8ty
Exterior Parts Wanted
Oct 23, 2015 08:35 AM
Linson
Oct 1, 2015 09:50 PM
