HID conversion done!!
Old Sep 27, 2012 | 09:58 AM
priest1981's Avatar
Car: 86 IROC-Z
Engine: LB9
Axle/Gears: limited slip disc
So I got this fairly inexpensive HID conversion kit from eBay http://www.ebay.com/itm/4pc-H4656-H4...item2574137923
They and my headlight buckets did require some modifications to fit, I will include them as well as pictures.
Old Sep 27, 2012 | 10:12 AM
priest1981's Avatar
Car: 86 IROC-Z
Engine: LB9
Re: HID conversion done!!
Before.
Old Sep 27, 2012 | 10:41 AM
priest1981's Avatar
Car: 86 IROC-Z
Engine: LB9
Gonna try this a little different. Before.
Old Sep 27, 2012 | 10:46 AM
priest1981's Avatar
Car: 86 IROC-Z
Engine: LB9
For these HID's to fit the headlight buckets...
You will need to remove the tabs shown in the pic above, I used an angle grinder with a cut off wheel and then a file to smooth out the edges. It should look something like ths when done.
Old Sep 27, 2012 | 11:01 AM
priest1981's Avatar
Car: 86 IROC-Z
Engine: LB9
There are also four tabs on the back of the new light housings that I needed to trim shorter for the outer bezel to mate up to the bucket properly. I used the side of the wheel on my bench grinder since the back of the housings are composite and not glass you shouldn't have to worry about breakng them, unless you drop them. Unfortunately in my haste I didn't get any pics of that. Also, if you get the same HALO kit that I got you will need to protect the HALO wires, I used heat shrink tube because it is thinner than split loom. Its also a good idea to extend them before you install the lights.
Old Sep 27, 2012 | 11:18 AM
priest1981's Avatar
Car: 86 IROC-Z
Engine: LB9
Side by side.
Old Sep 27, 2012 | 11:24 AM
priest1981's Avatar
Car: 86 IROC-Z
Engine: LB9
I connected my HALO's to my parking lights but you could connect them to a switch or whatever, the parking light harness runs right behind the headlights and is a brown wire. I used double sided tape and zip ties to mount the ballasts between the two openings in the body behind the head lights, DON'T TRUST ONLY DOUBLE SIDED TAPE!! My ballasts fell off and almost got ripped off. I wired both the high and low on the xenon bulbs to come on when the highs are on because the HID's are off in high. Last but not least the finished project, I also got the stock fog lights installed (maybe HID's for them soon).
Old Sep 27, 2012 | 11:50 AM
lizardkng's Avatar
Car: 91 Z28
Axle/Gears: Stock
I Like it, especially for just $129.
So there is a parking light mode, where theyre just dim and blue? I like that. Its not unlike the DRL's they use today.
Old Sep 27, 2012 | 11:51 AM
lizardkng's Avatar
Car: 91 Z28
Axle/Gears: Stock
That first thumbnail with the lights up against the garage door is a huge difference from the last picture taken the same way.
Old Sep 27, 2012 | 11:56 AM
priest1981's Avatar
Car: 86 IROC-Z
Engine: LB9
Thanks. I really like the clear lenses.
The dim blue is the HALO, they are rings of LED's around the outside of the light that are controlled by the red and white wires with the shrink tube.
Old Sep 27, 2012 | 12:14 PM
onthedownlow's Avatar
Car: 1984 Camaro Berlinetta
Engine: 355
Axle/Gears: Australian 9 bolt 3.27 posi
Wow those look really good. I like the halo ring when just the parking lights are on, that's sexxy. Great pictures and thanks for sharing.
Old Sep 27, 2012 | 03:31 PM
Ruckusz28's Avatar
Car: 1986 IROC-Z
Axle/Gears: 4:10
Cool conversion! I'm not a big fan of colored headlights, but that'll make night driving much better!
Old Sep 27, 2012 | 04:38 PM
priest1981's Avatar
Car: 86 IROC-Z
Engine: LB9
Thanks. Just think BMW, Mercedes, Lexus, ect. I'm pretty sure I can make them more white by changing the bulbs. I haven't really driven it that much at night yet but upping visibility was the main goal.
I'm thinking of converting the fog lights to HID's next. Does anyone make clear replacement lenses?
Old Sep 27, 2012 | 05:21 PM
gwarren007's Avatar
Car: 1992 RS
Engine: 305 (LO3)
Axle/Gears: 2.73?
Just FYI, never drive around with just your parking lights on, you will get pulled over/ticketed.
Old Sep 27, 2012 | 05:27 PM
priest1981's Avatar
Car: 86 IROC-Z
Engine: LB9
I wondered about that so I made it easy to disconnect the HALO's. Thanks for the heads up.
Old Sep 27, 2012 | 11:24 PM
BlueZee28's Avatar
Engine: Cammed 6.0L LSX
I was hoping to see xenon projectors and not halogen
Old Sep 28, 2012 | 12:29 AM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
This is the perfect image of glare and light scatter. See all the stuff up the garage that looks like a lava lamp? That's bad.
Old Sep 28, 2012 | 12:57 AM
885speed's Avatar
Car: 1988 Camaro
Engine: LR4
Axle/Gears: 3.23posi/disc
Iansane, hey not trying to beat you up on it man but those cheap plastic ebay housings are junk. If your interested I installed good quality glass/meta autopall ones in mine and it looks awesome! I can post a pic after work tomorrow and give you a good link.
BTW whats up with the green color? haha
also, is the kit you bought single beam or hi/low combo?
Old Sep 28, 2012 | 07:38 AM
BlueZee28's Avatar
He knows, he's done real retrofit projector swaps in other vehicles.
Old Sep 28, 2012 | 07:57 AM
Twin_Turbo's Avatar
anyone have a source for projector 4x6 units? I want to upgrade to Xenon because th candle power on my 88 is terribl. I'd prefer smokd units to match the gray color of the car.
Old Sep 28, 2012 | 12:45 PM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
That's not my picture/swap. That's the thread starter's picture. The housings themselves don't really matter as long as they're glass lenses with no flutes.
Old Sep 28, 2012 | 12:49 PM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
Pre-made 4x6 projector housings with an HID base (D2S, D2R, etc) ? I think that's what everyone doesn't want to spent $500 a light on.
Old Sep 28, 2012 | 01:12 PM
Twin_Turbo's Avatar
Who has them? Doesn't have to be hid, h4 or h7 for high beams is fine. Can get retrofit sockets
Old Sep 28, 2012 | 01:54 PM
priest1981's Avatar
Car: 86 IROC-Z
Engine: LB9
These lenses are glass.
I think the color is because my garage door isn't white, going down the road they have a bluish hue.
The low is a single HID and the lights in the high beam housing (inner two) are xenon high and low beam.
I think the lava lamp look on the door is because they weren't aimed yet and it's down hill to my garage door from where the car was.
Old Sep 28, 2012 | 01:59 PM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
Follow the yellow brick road.
Seriously though, I have no idea. It seems like there is so much of a demand for something like that I don't understand why someone hasn't cashed in.
Old Sep 28, 2012 | 05:05 PM
BlueZee28's Avatar
Twin Turbo,
I am making a set of retro projectors for myself. If they turn out good I may be willing to crank out a few more sets for people for a reasonable fee.
Old Sep 29, 2012 | 05:44 AM
cdoyle's Avatar
I had mine done by one of the guys at the retrofit source, I didn't have the time to try and do it myself. The light pattern is pretty nice, no scattered light everywhere. They are bixenon too, when I turn on the high beams it's incredible.
Old Sep 29, 2012 | 10:58 AM
885speed's Avatar
Car: 1988 Camaro
Engine: LR4
And this ladies and gentlemen is why you don't post something at 2am half asleep haha. My bad.
BUT in all seriousness you do have quite a bit of light going to waste.
Take a look at these http://www.hidexpert.com/producthtml/h4_adapters.html
Had to do a little modification but what little glare i had before, was gone after this.
Old Oct 31, 2012 | 06:45 PM
sasdiggler's Avatar
Car: 03 z06 & 91 z28
Engine: 5.7 & 5.0
Transmission: 6speed & 5speed
Where do you get stuff like this done? I'm down here in florida and did a standard swap. Just like his my light looks even worse. I need those projectors.
Old Nov 1, 2012 | 05:14 PM
rudolphschenker's Avatar
Car: 1990 IROC Z, 1987 IROC Z, 1986 Fir
Nice work!!
Linson
Oct 24, 2025 02:00 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
loud91rs
Oct 5, 2015 10:05 PM
mfp189
Sep 27, 2015 09:25 AM
