Cleaning the wheels with CLR
Old Jan 11, 2013 | 06:31 PM
Chuck84TA's Avatar
Car: 1984 Trans Am Recaro Edition
Engine: 355 L98 Vortec 226/234 custom cam
Transmission: TKO-600
Axle/Gears: On borrowed time...
Had my rear sway bar off the car, so I decided to tidy it up a bit... Used CLR with a metal scrub pad, the grime/rust/oil..etc.. came right off.. Looks great..
http://www.google.com/search?client=...UTF-8&oe=UTF-8
Them I got to thinking....(I get pretty dangerous when I do)
What if I used an old kiddy pool and poured some CLR with some water to slightly dilute it and dipped the turbo alloy wheels in to soak? Then rinsed and dried.
Am I crazy or is this a good idea?
Old Jan 16, 2013 | 07:26 PM
c10freak87's Avatar
Car: 88 IROC Camaro
Engine: 305 TBI
Re: Cleaning the wheels with CLR
id like to know i got a set of iroc rims i need to clean up like to see with pics how it turns out
Old Jan 16, 2013 | 07:32 PM
Chuck84TA's Avatar
I'll give it a try later this spring
Old Jan 16, 2013 | 07:33 PM
Phenom-1's Avatar
Car: 1992 Chevrolet Camaro Z28
Engine: 5.7 TPI
Transmission: 700R4 Overdrive Automatic
Axle/Gears: 3.23:1 Positraction
CLR is pretty strong stuff, you could take the paint right off the rims by accident.
Old Jan 16, 2013 | 09:28 PM
Chuck84TA's Avatar
Yeah, you're probably right... maybe its not such a good idea... How about OxyClean? That should be safe yet strong enough.
Old Jan 16, 2013 | 10:36 PM
dads old blue 9's Avatar
Car: 1990 z28
Engine: 5.0
Transmission: t-5 wc
Axle/Gears: 4th gen 3.42 posi
oxy clean blows chunks use simple green . just dont let it dry on there . there is also yollew stuff called awsome at the dollar stores . I know what your thinking but it really works on break dust thats yrs old ,its AWSOME.
Old Jan 16, 2013 | 11:16 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
That " Awesome " stuff is pretty good. We had our asphalt driveway sealed in the summer, and there were aLOT of tar // creasote spots along the bottom panels of our vinyl garage door. The guy told me about " Awesome " so I got some. Used it full strength with elbow grease & cleaned up nicely! Got a few tiny spots where it took off lil bit of color, but noticeable only if you know where to look!!
Old Jan 16, 2013 | 11:41 PM
Phenom-1's Avatar
Engine: 5.7 TPI
It's Called L.A'S TOTALLY AWESOME and who better to show it then the guy from L.A.
I Just took these pics 5 min ago, I use it to clean the stove, never thought to use it for wheels, It's 99c at most 99c stores.
Old Jan 16, 2013 | 11:51 PM
Phenom-1's Avatar
Engine: 5.7 TPI
Here's another photo, apparently as it says, you Can use it on Automobiles.
they will have it wherever the cleaning supplies aisle is and most supermarkets have it too.
Old Jan 17, 2013 | 02:11 AM
Phenom-1's Avatar
Engine: 5.7 TPI
Afterwards Clean ^
Dirt and Brake Dust ^
Before ^
Before ^
I would have suggested Simply hot water and a sponge or some kind of wheel cleaner or engine degreaser or brake clean, but L.A's Awesome would work I just used hot water a towel a sponge and elbow grease to clean out the Hubcaps on my fathers Dodge Grand Caravan, the front wheels always get more dirty than the rears, and the dirt had kinda set on it over several months so I got to cleaning them, they looked nice afterwards.
Old Jan 17, 2013 | 02:47 AM
FlyDoc's Avatar
Car: 92 RS
Engine: 94 LT1 383
Transmission: T56-6 Speed
Axle/Gears: posi, 3.26:1,
Greased Lighting, works wonders, I even use it to clean carpet.
Old Jan 17, 2013 | 11:30 PM
Challis0's Avatar
Car: CANADA
Guys if you ever need cleaning services than contact here back we have a cleaning company which provide excellent services if anyone interested than contact here back....?
Old Jan 18, 2013 | 03:47 AM
salfirebird92's Avatar
Car: 92 Firebird Formula
Engine: 5.0 V8
I use Awesome on the engine area to remove grease and oil it works and for $1 you can't go wrong well sometimes lol
Old Jan 23, 2013 | 05:37 PM
maroman88's Avatar
Car: 88 Camaro Coupe - 99 Corvette
Engine: 305TPI - LS1
Transmission: A4 - A4
Axle/Gears: 3:73 - 3:15
purple power...
deracer
Apr 11, 2016 12:04 AM
mdtoren
Aug 23, 2015 12:52 PM
Dialed_In
Aug 20, 2015 01:45 PM
mdtoren
Aug 16, 2015 05:45 PM
