Is hard top rare or T-Top rare ?
Car: Red 1988 Iroc-Z hard top
Engine: 305 ( LSX swap soon )
Transmission: 700r4 ( T-56 swap soon )
Axle/Gears: What ever gear that come in 88 iroc
I want to know if hard top rare or T top rare, if hard top rare I properly keep the way its, cause a buddy of mine that know how to turn hard top into T-Top for 400 dollar. Dont know if its worth to do it.
Car: 1990 Mazda B2600i Cab Plus L98 Swap
Engine: 5.7 TPI, LT1 cam, 24 lb. Inj.
Transmission: BowTie Overdrives Level 2 700R4
Axle/Gears: 3.909
Re: Is hard top rare or T-Top rare ?
Don't do it!
A proper conversion should cost a lot more than $400.
It'll probably ruin your car.
Car: 1987 camaro sc
Engine: lg4 305
the cost of a conversion should cost around 400 for parts that you would need. you would need the ttop roof frame, ttops, weather stripping, and some steel for temporary bracing while you cut the roof off
Car: 87 GTA Trans Am
Axle/Gears: 10 bolt posi 3.23
If he does good work that you have seen I say go for it if that's what you want.
I love my hard top and would not change it.
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
There are plenty of t top cars and hard top cars to choose from.
Don't go hacking one up.
Car: 1985 Trans Am
Engine: 385
Axle/Gears: 10 Bolt 4.10
I personally see about twice as many T-Tops as hard tops. But if you want a TTop just go and buy one, they aren't THAT hard to find.
Car: 1992 Camaro (Z28 Clone)
Engine: LB9|TPI
Keep the Hard top..
T-Tops leak, t tops make your car hotter, t-tops weaken the structual integrity, your much better off with the Hard top..
But if you must have one atleast buy one that came with it factory... lots of things could go wrong with a custom job..
Car: 1992 Camaro RS
Engine: L03 5.0L
Transmission: 700R4 Auto
I have to agree with everyone, don't do it. You'd just be hacking up an original hardtop car, which are much less common than T-Top cars (but still not rare). A custom job just might cause you endless leaking as well.
Transmission: World Class T-5
Axle/Gears: BW 3.45
There are more T-tops around than hardtops.
ambainb
Apr 25, 2016 09:21 PM
1Aauto
Sponsored Vendors
Aug 24, 2015 03:40 PM
