Valve Cover Paint
Car: 1989 GTA
Engine: 5.7 w/Paxton
Valve Cover Paint
I have an '89 GTA (L98) with a silver/gray like paint. Just wondering if anyone knows of a paint that matches closely? Thanks.
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: Valve Cover Paint
http://www.eastwood.com/ew-detail-gray-set.html.
http://www.eastwood.com/ew-detail-gr...sol-13-oz.html
I used one of these two,not sure witch one.The color was almost exact,maybe a shade off,can't really tell the change.
I used this one,http://www.eastwood.com/ew-detail-gray-set.html,just found the remainder of the the can.
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
why not buy the actual paint that matches your car? A lot of places can mix some for you and put it into an aerosol can if you don't have the ability to spray it through a gun.
Car: 1989 GTA
Thanks for the suggestions....probably just get a can mantaguy suggested from eastwood.
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Here's another idea.
Duplicolor Met Gray Metallic
Car: 89 IROC
It's called lousy paint. The C4 Corvette valve covers were painted silver, but tended to slowly fade to a nasty brown color. I'm guessing that the "gold" ones you saw were just starting to turn brown.
Seymour Paints makes a "Nickel" paint that is a very good match for the original silver paint used on the C4 valve covers. I've painted a few sets with it and it works very well.
Here's the set that I'm using on the 350 going into my GTA:
Car: 84 Trans Am, 84 Fiero, 86 944
Engine: 5.0, 2.5, 2.5
Transmission: 5spd
well yeah that'd probably explain it, i didn't know if they were painted differently or made out of a different material that looked more gold or what, engine looks good by the way, mine still looks like crap haha
NBrehm
Aug 25, 2015 11:49 PM
