4th gen overflow tank
Old Nov 27, 2013 | 10:17 AM
racerx520's Avatar
I am doing the 4th gen overflow tank but i had a question for those of you who have installed it already:
On my 87 t/a, the battery is on the driver's side, the overflow tank is on the passenger side. Should i move the battery to the passenger side or the overflow tank to the driver's side? I'm thnking move the battery. what do i need to do in order to move the battery? the way the car is packed into the garage for the winter, i wont have room to jack it up so hopefully nothing too difficult?
Old Nov 27, 2013 | 02:24 PM
6SIX6's Avatar
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
Re: 4th gen overflow tank
You could make your own battery cables as its pretty easy if you relocate the battery
Old Nov 27, 2013 | 04:25 PM
racerx520's Avatar
Thats all i need? just run a new battery cable to from the battery to the starter? nothing else really?
Old Nov 27, 2013 | 04:47 PM
Joe Tag's Avatar
There is a provision for the battery tie down on both sides, so yes, really just need a longer hot cable.
Old Nov 27, 2013 | 06:51 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
If he moves the battery from the drivers to passenger side (closer to the starter), he may not need a longer cable...
Modding 4thgen overflow to fit drivers side takes a bit of modding the neck....
https://www.thirdgen.org/forums/auto...en-washer.html
Old Nov 27, 2013 | 07:05 PM
Joe Tag's Avatar
My bad, birds have battery on the drivers side.
Old Nov 28, 2013 | 01:03 AM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Or mount the overflow under the tray, so the batt can stay on the dr side.
Old Nov 28, 2013 | 06:36 AM
racerx520's Avatar
would it be easier to mod the bottle or mess with the wires? you're right that the wire would be shorter to run to the starter from the passenger side, but what about the ground, anyone know wehre that goes to? also what about the wiring going to the computer? just extend those wires and run them over or do they originate from the passenger side too, therefore could be shortened?
Old Nov 28, 2013 | 11:08 AM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
If there's stuff on the pass side tray.You'll have to relocate that on top of moving the batt over.Think it be easier to mod the 4th gen piece, but thats just me.I prefer to leave the car as stock as possible & modify/adapt the part being installed.
Why do you want to move the batt over anyway? You dont have to use the battery tray (for the batt) on the 4th gen bottle.Mod the tray for something else or leave it as is.
Old Nov 28, 2013 | 11:41 AM
racerx520's Avatar
well i'm also going to try and do the 4h gen washer fluid swap and all the emissions stuff i'm going to remove like the charcoal canister thats there now. I wanted to use the battery tray on the 4th gen coolant bottle so that i wont see it really, this way its hidden from sight by the battery, and wehre the battery was will be just the painted sheetmetal, i was hoping that would make it look cleaner
Old Nov 28, 2013 | 11:54 AM
Jeffs82TA's Avatar
The 4th gen bottles suck anyways. I have replaced mine about 7 times, they either start leaking or the battery hold down stuff breaks off.
An aluminum version of it would be very nice to have, but the plastic ones are nothing but trouble. Mine is a 4th gen car so not the car or installation causing it
Old Nov 28, 2013 | 11:59 AM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Well both of these are reason to mount from under the OE tray.Did mine this way back in 05/06.Still going well.
Old Nov 29, 2013 | 08:50 AM
racerx520's Avatar
hmm...i'm thinking of maybe just putting the tank on the driver's side, and keeping the battery where it is. Just remembered that i'd then have to re-route my amp cable too. plus, i have a cool air kit which will be right over the overflow tank so that'll cover it up. maybe if theres a way to paint it so the paint wont come off, it'll blend in fine with the car (since i have to repaint the engine bay when i pull themotor)
Old May 31, 2025 | 09:25 AM
upstateRich's Avatar
Car: 1989 Firebird
Engine: 2001 5.7 LS1
Does anyone have the part numbers for the tank cap replacement the old# is 10188034 and I am also looking to the grommet and pipe for the hose
Old Jun 16, 2025 | 04:06 AM
Fasttrackaly's Avatar
Moving the battery isn’t too bad if you’ve got decent access up top, just need a good tray, longer cables, and solid grounds. But if the tank fits cleanly on the driver’s side, it might be the simpler route without messing with wiring.
1992 Trans Am
May 10, 2023 07:19 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Strick1
Aug 27, 2015 08:57 PM
AkDrifted
Aug 17, 2015 07:45 PM
