Can I store car products in freezing temps/ winter
Old Dec 10, 2013 | 08:45 PM
T/Atime's Avatar
Car: 91 GTA
Axle/Gears: 3:73
Does anyone clean out there garage for winter.... Clean out all paints waxes, polishes..... List goes on
Old Dec 10, 2013 | 10:02 PM
N_da_Mood's Avatar
Car: 1992 Z28 Heritage Edition
Re: Can I store car products in freezing temps/ winter
Personally I never have but I am not sure it stays cold here long enough to freeze everything..
Old Dec 11, 2013 | 06:38 AM
stealtht/a's Avatar
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
Most products are fine, the worst it will do is seperate a little.
Anything with epoxy must be brought back to room temp before use.
Paint can be ruined by freezing and also must be brought back to room temp before use.
Aerosols can often lose their charge as the shrinkage can allow air escape.
Old Dec 11, 2013 | 10:37 AM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Rubber and plastic don't like being frozen. Shouldn't affect metal but should be kept dry. Freezing garage is one thing that's not an issue in this part of the people's republic.
Old Dec 11, 2013 | 11:22 AM
stealtht/a's Avatar
Wow, do t spend much time in the cold do you?
Do you think the cars we drive here in vt don't have rubber and plastic in them?
Neither care about being frozen if left alone, some plastics get more brittle in extreme cold so you don't want to flex them, but most of the plastics and rubber in cars are designed for much less than zero.
I think the op was only talking about supplies anyway.
I love it how all the mild climate people on the forum are the first to respond when people ask about freezing temps or winter driving or snow tires.
Old Dec 11, 2013 | 02:13 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
I assume they don't get this kind of weather
This fell This Sunday!!!
Old Dec 11, 2013 | 04:59 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
I was born and raised in the cold which is why I don't spend any time in it unless I'm snowboarding! Of course rubber and plastic are used in the cold but they still don't like it and are more easily damaged if stored badly.
Old Dec 11, 2013 | 05:25 PM
lordmetalz28's Avatar
Car: 1987 Z28 with iroc-z Package no.3
Engine: 350TPI
Axle/Gears: 3.73 posi
NO! i live in upstate NY and haven't had a problem in the 20 years Ive been detailing up my cars.
Old Dec 11, 2013 | 06:14 PM
stealtht/a's Avatar
Your snowboard gear has rubber and plastic in it, seems to do ok in Your cold.
My point is your comment isn't very useful in its over generalization.
plastics and rubbers are sensitive to SOME degree of cold. The plastics used in cars will only exhibit different characteristics in REALLY cold weather, like -50 or so. Even then, if you don't try and flex it, no problem.
So what is your helpful advice to the OP, take all the plastic and rubber out of his garage and bring it inside? Wrap a blanket around it?
The problems sometimes seen in cracking dashes, etc, aren't from cold, they're from extreme temp changes in too short a time. Not really a problem in a garage.
To the OP, really everything will be ok, even paint isn't usually damaged by being stored cold, it's just cycling it through extreme temps or trying to use it cold that's the problem.
Old Dec 11, 2013 | 09:00 PM
T/Atime's Avatar
Car: 91 GTA
Axle/Gears: 3:73
I had to re read my original post. All I'm asking is for people that live in cold winters, (example -35) to share there experience with storing paint, waxes... Still in the can or bottle.
Plastic is ok, really! I don't mind if my plastic window trim on my garage door freezes.
Old Dec 12, 2013 | 11:46 AM
mantaguy's Avatar
Engine: 5.0 EFI
I don't store Paints,Glues or anything that says"Keep From Freezing" on the labels,it's there for a reason.
Old Dec 12, 2013 | 12:16 PM
88gunmetalgta's Avatar
As said before, bring in paints and aerosols. Also, batteries that don't have much of a charge shouldn't be left out in the cold.
I would say you don't have to bring your tires inside for the winter though
Valid point about plastic though. If you plan on working with it (electrical connectors and such), its gonna be brittle. I've even cracked wire insulation before due to extreme cold. Also once brought a ratchet into the warm garage to use and the head of the ratchet cracked, (I guess from thawing too quick + the load from tightening a bolt).
Old Dec 12, 2013 | 02:16 PM
6SIX6's Avatar
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
Oh i feel you pain in everyway when I see this when I wake up
Old Dec 12, 2013 | 10:46 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
In my opinion there are some things that are almost useless after freezing: body filler, spray wax, cheap grease. I have a wizards buffing compound that hasn't been worth a darn since it froze but I was new to that brand so it could have been a coincidence.
Old Jan 7, 2014 | 09:01 AM
oaklandfuelman's Avatar
Car: 85 iroc z
Engine: 355 tpi
Transmission: 7r4
i bring everything inside i left it in the garage the first year (never had a garage befour) & most of it was junk after that the liquid car wax seem to be the worst got clumps in it the armor all sperated & was useless also spray cans were dead no charge left even though they were still full of paint
Old Jan 8, 2014 | 04:08 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
I had a can of the "liquid glass" go bad when it froze... it seperated and I never got it back to normal... got a new can
customblackbird
Aug 15, 2021 10:16 PM
Reddeath210
Oct 6, 2015 08:20 AM
MY87LT
Aug 17, 2015 08:43 AM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
