Illuminating tail light center section
Old Jan 16, 2014 | 01:34 AM
firechicken1992's Avatar
Car: 92 Firebird--02 Grand Prix GTP 2Dr
Engine: Poncho 400--3.8 Supercharged
Transmission: T56 6 Speed--4T65EHD
Axle/Gears: Open 10 bolt 3.42--Internal 2.93
With snow on the ground and no garage to work in, I can't work on my engine swap until its warmer. So I decided to take off my tail lights to give them a good cleaning inside and out. So out it all came and into my living room for the tear down. Now something I had always thought would look REALLY cool is if the orange Bird emblem and "PONTIAC" writing in the back lit up at night.
I had always assumed it had been molded black plastic with orange inserts, so I never bothered to pursue the idea. Well after taking off the lights and housings, I noticed that it was actually translucent and painted from the back.
That old idea struck instantly! So I busted out my thin exacto-knife and started etching away at the back of the shell. Only 3 letters in and I'm very pleased so far. Not looking forward to etching out the bird tho.
Old Jan 16, 2014 | 02:24 AM
Re: Illuminating tail light center section
Got the full word "PONTIAC" done. Very pleased with the results.
Old Jan 16, 2014 | 05:51 AM
KBD85's Avatar
Car: 1985 trans am
that is a really cool idea!!! i like it!!
Old Jan 16, 2014 | 08:05 AM
stealtht/a's Avatar
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
Cool idea but what does it look like with the light off?
Old Jan 16, 2014 | 08:18 AM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
I liked the idea until that.
Old Jan 16, 2014 | 08:41 AM
stealtht/a's Avatar
After the black is scraped off, should be pretty easy to spray a coat of VHT red on it from the back. That should look pretty good.
Old Jan 16, 2014 | 08:51 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Always wanted to try that
Old Jan 16, 2014 | 11:09 AM
Well right now the etch marks are visible, but I'm going to detail all of that out and get some orange film over it, so it'll look pretty decent while off I'm assuming. After I get out of class today I'm going to start etching at the bird emblem.
I'm going to buy some sheet plastic and try and form it to make bulb housings and paint them with reflective paint. I plan on running two bulbs behind the shell. The bulbs will illuminate with the running lights off of the brown power wires when the light switch is turned on.
Old Jan 16, 2014 | 12:40 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
Looks great so far! I always thought it should have been like that from the factory.
Instead of making your own bulb holders, I would maybe try and use 2 holders from the side marker lights. The ones that use the 194 bulbs. All you would have to do is drill the holes and use a knife or dremel to make the squared-off notches for the lock tabs. I just don't know if there is enough room behind or to the side of that plate for the tail end of the holders that would stick out though.
Just my
Old Jan 16, 2014 | 01:37 PM
oaklandfuelman's Avatar
Car: 85 iroc z
Engine: 355 tpi
Transmission: 7r4
might try somthing like this for the lighting comes in red too http://www.ebay.com/itm/2PCS-12V-LED-17cm-COB-Car-Auto-DRL-Driving-Daytime-Running-Lamp-Fog-Light-White-/141087306489?pt=Motors_Car_Truck_Parts_Accessories&hash=item20d97572f9&vxp=mtr#ht_6483wt_972
Old Jan 16, 2014 | 03:34 PM
Started etching the bird. Very tedious process.
Old Jan 24, 2014 | 06:40 PM
IROCU2's Avatar
Car: 1987 IROC-Z
Engine: 5.7 TPI
Transmission: 700-R4
Looking good.
Frozer!!!
Jan 19, 2024 04:55 PM
Jk_Under
Sep 2, 2015 10:59 PM
dibella989
Sep 1, 2015 04:12 PM
LittleFranks
Aug 20, 2015 03:55 PM
Fronzizzle
Aug 19, 2015 01:36 PM
