Switched my RS grille to Z28 Iroc style
Old Mar 11, 2017 | 08:12 AM
bigarmzz's Avatar
Car: 86 2wd
Axle/Gears: 2:73 open (for now)
Lovin the look much better. Was an easy swap, the fog lights bolted up, and the grill switched over with no problems whatsoever. I would love to actually get the OEM switch and harness though to make the fog lights function, any idea where I can get that at? Thanks
Before
After
Next, I want to lower it about an inch to an inch and a half
Old Mar 11, 2017 | 08:21 AM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
Re: Switched my RS grille to Z28 Iroc style
I don't know nothin'....except that THAT is a great looking Camaro!
Old Mar 11, 2017 | 09:30 AM
Drew's Avatar
The fog light harness after about 1988 is integrated into the headlight harness. The wiring for the switch and probably the relay should be in the dash, might be wrapped in self adhesive foam tape to keep from rattling. Just unwrap and plug in the relay and switch. For the the wiring under the hood, you can either get the terminals and make up a new harness for just the fog lights and plug into C100, or you need to get the entire headlight harness from a later Camaro with fog lights and swap harnesses.
Old Mar 11, 2017 | 10:54 AM
Anthony0128's Avatar
Did you purchase the z28 style alone ? I've been wanting to switch out mine as well
Old Mar 11, 2017 | 05:56 PM
Croz's Avatar
Cant believe what a difference that made. Nice looking car.
Old Mar 11, 2017 | 06:49 PM
KMK454's Avatar
Car: 1991 Camaro B4C
Looks nice! Did it bolt right up or did you need to drill new holes?
Old Mar 17, 2017 | 02:00 PM
maroman88's Avatar
Car: 88 Camaro Coupe - 99 Corvette
Engine: 305TPI - LS1
Transmission: A4 - A4
Axle/Gears: 3:73 - 3:15
i got a factory switch and used an aftermarket harness that came with the fogs.
Old Mar 17, 2017 | 03:43 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
I love that bow-tie grill.
I bought one for my car a few years back.
The red bow-tie looks really good on your car but I have also seen members here paint it to match the car and that also looks good.
Your paint is a little dark though, and it might not show up very well.
Beautiful car you have there.
Old Mar 17, 2017 | 04:01 PM
lizardkng's Avatar
Car: 91 Z28
Axle/Gears: Stock
Old Mar 18, 2017 | 06:58 PM
bigarmzz's Avatar
Car: 86 2wd
hey, thanks a lot for the comps guys!!!
tbh, I've been kinda getting bored of it lately, maybe that will fade when warm weather gets here and I can take it out and enjoy it
