What kind of paint do I use for >>>
Old Jan 3, 2002 | 02:30 PM
92GTA's Avatar
What type of paint do I use for repainting all of my black trim like around the rear hatch and the windshield wipers? Was it originally flat or gloss or what? I need to make sure it looks 100% original. Does anyone here recommend a specific type of brand?
Thanks.
Old Jan 3, 2002 | 02:57 PM
Apone's Avatar
Car: 1991 GTA
I am almost 99% postive that it was a flat black color. I recently paintd the metal strip that runs around the edge of my hatch glass. The way I did it was to sand down the strip, seeing as I had some rust on there. Then I used one of those foam brushes and simply painted the strip. I just took my time and went very slow so that I didn't drip paint onto any other areas. The foam bruch also left NO brush strokes or streakes.
I think the wiper arms are also flat black as well.....but again I am not positive.
Old Jan 3, 2002 | 03:21 PM
92GTA's Avatar
Cool, that's what I thought. I figured I could just use some Testors model paint in flat black......
Old Jan 3, 2002 | 04:00 PM
Hg's Avatar
Hg
Car: '87 Z
Engine: 355 in the works
Let me know how it turns out, I need to redo the rear hatch and the trim on the TTops also.
Old Jan 3, 2002 | 04:34 PM
Drew's Avatar
My opinion, GM didn't use a flat black anywhere on any car. A satin black or semi-gloss black is probably much closer to accurate. It shouldn't be flat and it shouldn't be extremely glossy, it needs to be somewhere in between.
Old Jan 3, 2002 | 04:50 PM
92GTA's Avatar
Semi-gloss then huh? Maybe I'll do that. Now that you mention it it does make more sense that just flat black, I never thought of semi-gloss...........
Old Jan 5, 2002 | 05:21 PM
Blue502's Avatar
GM generally used a 30-40% gloss, which is most closely matched in rattle cans by Krylon's semi-flat black. I think SEM also makes this color, and because it is a professional product, it should have a higher solids content, and therefore last longer.
Old Jan 5, 2002 | 05:42 PM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Axle/Gears: 3.73 S60
Check yer local paint stores there is a color called GM Trim paint. When I repainted my t-tops I picked up a can at pep boys. It looked exactly like what came from GM
Kat
Old Jan 5, 2002 | 06:02 PM
92GTA's Avatar
Well I went to autozone and they had those small spray cans of the Dupli-Color brand paint and one of them was called "DS GM 381 Black MC" and it says its ideal on trim and is a perfect factory match. The color of the cap kinda looks like it has a little tiny bit of silver/gold flecks now that I look at it though, I think I got the wrong stuff The only choice they had was a GM flat black trim paint.......
Old Jan 5, 2002 | 06:05 PM
92GTA's Avatar
DAMN!!!!!!! It was the wrong one I think, I just sprayed it and it had little metal flakes in it
I think I'll just buy a regular old semi-gloss.....
Hotrodboba400
Dec 10, 2019 07:07 PM
TheExaminer
Sep 28, 2015 02:28 PM
Blue419
Sep 10, 2015 01:03 PM
TheExaminer
Sep 6, 2015 11:40 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
