Louvers
Old Jan 22, 2023 | 02:39 PM
JimmyPalmer's Avatar
Engine: 2.8L v6
Transmission: 5 speed T5
Louvers
Hey Y'all!
just thought id make this post on how I mounted Chastain Shadow Louvers on my 83' Firebird.
They came with no mounting pieces so I made my own.
1. gotta take the rear window off, to do that take the trim off the inside then there 4 bolts to take out which are 13 mm.
2. after you lift the window out, which will take a strong back and weak mind, take the hinges out.
3. since mine came with no mounts at all I took a piece of body metal and make two mounts by tracking out the size I wanted and drilled the holes for the hinge bolts and the louver holes.
4. after mounting all that up I had to secure the side louvers to the middle main section, which I just used PL adhesive. could use other stuff but that's what I had.
5. once the side pieces were dry I took 1/2" wide pieces of the body metal and drilled a 3/16" hole in to rivet them to the window and bend around the metal trim to hold the side pieces down.
if anyone has questions just let me know, I'm happy to help since there's not a lot of info on how to do this!
Old Apr 9, 2026 | 01:12 PM
Fir4efly83's Avatar
Engine: 305 Carb
Re: Louvers
Thank You So Much!
I have identical louvers that did not include mounting brackets either!
Same year car too, its a black 83 with a 5 speed!
How good is it whenever you have to wash the back window?
Have you come across any issues since you installed them?
I know this is a dead old thread but I might as well ask.
Thank you again random internet guy!
tarouty
Jun 17, 2013 03:23 PM
GerryCat09
Aftermarket Product Review
Apr 8, 2009 10:18 PM
DAGKANA
Mar 16, 2009 02:36 PM
86IROC-z28
Dec 28, 2007 09:23 PM
jermdm
Apr 1, 2002 09:41 PM
