Air/Fuel Gauge
Old Feb 8, 2002 | 11:03 PM
fiream's Avatar
Car: 1983 Pontiac Firebird
Engine: 400HP 350
Air/Fuel Gauge
Hi,
I was just wondering how many one you guy have an Air/Fuel Ratio Gauge, and where did you mount it. Oh yeah, is yours constantly on, or does it go on and off while your driving. While i'm driving it seems to go about half way up the dail, and then it goes all the way down to Lean, until I get back on the gas? Does this sound right?
Old Feb 8, 2002 | 11:19 PM
JPrevost's Avatar
Car: 91 Red Sled
Sounds out of adjustment. It should read half way on a stock engine and slightly rich under WOT. If you've done mods to your car and haven't adjusted fuel pressure or done a custom eprom then you're probably running lean. Either that or you've got something else wrong. This is why I built my own gauge.
Old Feb 9, 2002 | 05:10 AM
Jza's Avatar
Jza
I have one and it's installed on an a-pillar pod. I used to have the Autometer Phantom Series digital A/F gauge. They both go off the scale towards lean on cruise. On my car, this is because of highway mode, though (at first I thought something was wrong, too!). On your 83, I wouldn't know why it does that. On the other hand, don't forget that our O2 sensors are narrow-band sensors; meaning it only measures inside a narrow area between rich and lean, so it's gonna go off the scale pretty often (I guess depending on who made your gauge). While you're driving around, it should either stay in the middle like JPrevost said, or bounce around between rich and lean. The difference is only how fast the gauge "reads" and updates from the sensor. The faster gauges will appear to bounce around due to the computer constantly adjusting the A/F ratio to bring it to 14.7:1. The slower gauges just sort of "average" out and hang around the middle. I got rid of the Autometer for this reason: it read way too fast. I can appreciate accuracy, and the Autometer gauge had that :hail: , but it can only be as accurate as it's sensor, and face it: our sensors don't merit a gauge quite that good.
Old Feb 9, 2002 | 01:41 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
nordskog, makes a couple of a/f gauges, and you can buy a wideband O2 from them that works with it. that would solve the bouncy needle.
Old Feb 9, 2002 | 10:30 PM
fiream's Avatar
Engine: 400HP 350
Okay,
I just wanted to know if anyone else was having the same problem. I think it might just be my ECU trying to lean out my fuel mixture. I am no longer hooked up tp the ECU, because I have a non- Computer controled carb, and a vacuum advance distributor. I'll take some pictures tommorow of the gauge, I mounted it in my scoop.
Thanks,
Robert
Old Feb 9, 2002 | 11:30 PM
1982chevycamaroz28's Avatar
i got a question about the a/f gauges. do they all need to use the computer or is there any that u just hook up too where the O2 sensor is? becuz on my car i got the computer delelt package and well i just have the o2 sensor in there as a plug. so can anyone answer that.
Old Feb 10, 2002 | 12:48 PM
Dewey316's Avatar
Car: 1990 Camaro RS
that norscog one i mentioned, is a stand alone unit, you buy the gauge, and their wideband O2, sensor, and wiring harness for it and you don't need a computer.
Old Feb 10, 2002 | 01:26 PM
where could i find that one and is it hard to install? plus how much? i was lookin in jegs at the autometer a/f guage i didnt know if its for computer or not. does anyone know about that one too?
Old Feb 10, 2002 | 04:12 PM
Jza's Avatar
Jza
They all should be able to stand-alone. Most of them just splice into the ECM-side signal wire, which if you don't have an ECM, just goes to the o2 sensor.
RS Reaper
Oct 17, 2018 07:52 PM
apie2546
Oct 16, 2016 02:24 PM
Luigytico09
Oct 1, 2015 08:46 AM
Gordonr1973
Sep 29, 2015 11:59 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
