4th gen door panels on a 90 irocz
be warned that a 4th gen dash is physically bigger than thirdgen dash. you'll loose a significant amount of interior space if you swap a 93+ dash into your thirdgen.
on 4th gens, back part of the engine is under front part of dashboard. also the dash has to accomodate a passenger's side airbag.
acutally i havent noticed any real loss in space, of interior room, but i have not did the exact measurements, but i just got a 95 z28 i will have to check on that, one think about putting a 4th gen dash in is that the dash top is cut so the 4th gen dash is acutally bolting up to the old dash holes, so if there is any lost space its not much,
about the airbags, im not sure what it is in other states, but here in va, airbags are considered a convience no matter what year car, thats why any new car is sold with a deactiavator swicth to turn them off if someone doesnt want to use them, there is no law saying that you have to have airbags, seatbelts yes, airbags, no, if you have airbags in any car and want to remove them in the state of virginia all you have to do is remove the light bulb for airbags in the gauge cluster and it should pass inspection, reason why i say all this is i just checked on it, with my 95z28 which has airbags, and i want to remove the driver sterring wheel and put on a grant,
Car: '87 Camaro LT
Engine: 355 L98
Jawz,
is that a custom roll bar? i like how the door bars are low so you can get in and out easier. i think buickGSX has one like that too
1992 Trans Am
May 10, 2023 07:19 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
ambainb
Apr 25, 2016 09:21 PM
