Need help from everyone with t-tops
Old Apr 24, 2002 | 12:50 PM
jawzforlife1's Avatar
So heres what I'm trying to do:
Can everyone with t-tops list what year their car is, that kind of tops (acrylic or glass) and what kind of pins (latch, small, or wrapped in plastic) It seems that no one has a deffinant anwser to the questions that come up about t-tops and fitting into other cars. This way we can try to peice together what will fit on what.
Old Apr 24, 2002 | 12:55 PM
Snowdog 91 Formula's Avatar
Okay went out and took a quick look.
1991 Firebird
I suppose it fits the category "wrapped in plastic".
There is a plastic bushing around the metal pin. It snugs in, and the pin goes into the channel.
Old Apr 24, 2002 | 01:01 PM
what i mean by "wrapped in plastic", the metal pin has plstic around it to make it larger.
Do you glass or acrylic tops?
Old Apr 24, 2002 | 01:03 PM
Okay I think I might get it now, The plastic that is around the pin dosent go into the hole, I get pushed back into the t-top???
Old Apr 24, 2002 | 01:12 PM
Yes. Exactly. The plastic is around the pin.
They are Lexans.
It is used more like a guide I believe to line it up better with the holes.
Old Apr 24, 2002 | 01:30 PM
Camaro1984ME's Avatar
I have a 1984 Camaro and it has GLASS t-tops with wrapped in plastic around it. The camaro is a sport coupe.
Old Apr 24, 2002 | 03:29 PM
CamaroRyan2002's Avatar
I have a 91 RS and i have T-tops. My Tops are both different. The Drivers Side is acrylic and pass. is Glass. I have problems with the Pass. side leaking in the rain so i think it could be because of that. I JUST bought a set of glass tops for 20 bucks. Perfect condition and fit but they dont seal very well. I am thinking of changing the seals or maybe selling them. Hope that helps.
86IROCZ's Avatar
The one's that came with my car: glass, metal pin (I'm not sure what small means, I wish I had a digital camera!!) and they have locks.
oh yea, the year is 86 incase you couldn't tell
Old Apr 24, 2002 | 06:40 PM
labrat's Avatar
Car: 87 IROC-Z
Transmission: automatic
I've got an 87 Iroc, with glass t-tops and metal pins. Haven't had any problems with them, they're great
Old Apr 24, 2002 | 11:28 PM
Trent257's Avatar
i have a 89 bird and a 90 iroc, bloth glass, both metal pin
Old Apr 24, 2002 | 11:43 PM
HrdRockA4305's Avatar
88, Glass tops, metal pins.
Old Apr 24, 2002 | 11:52 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I've got 3 sets, all from 86 Birds, Glass with metal pins.
Old Apr 25, 2002 | 12:30 AM
jeffs82z28's Avatar
My 1982 Z-28 has the hook style glass tops.
I believe 82-83 ( possibly 84) factory T's had the hook style.
I know that my 85 RS had locking pin style glass tops.
A friend of mine has a 1983 Z-28 with the dealer installed T's and they are about 3 1/2" shorter (front to back).
I don't know what year they offered acrylic tops.
Old Apr 25, 2002 | 01:27 AM
91blkta's Avatar
Car: 1991 Pontiac ta 5.0l 2005 pontiac gxp 5.3l ls4 dod 2003 GMC Envoy 4.2l
91 ta
glass tops
metal pin and metal handles with plastic trim on locking edge
locks
also have original inserts to block the sun that match the int of veh
Old Apr 25, 2002 | 01:42 AM
RODS92Z's Avatar
My 92 came with the lexon tops with plastic pins, I replaced them with 88 or 89 glass tops with metal pins. They work but I had to adjust the mounts lower to hold the tops down tighter. My lexon tops didnt leak at all, the glass tops leak under alot of water pressure.
Does the mounting hardware for the metal pins and the plastic coated pins mount the same on the camaros? If they do I need the mounting hardware for the metal pins. Anybody got some?
Old Apr 25, 2002 | 02:00 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
90 RS, stock t-tops
glass tops, metal pin
Old Apr 25, 2002 | 03:12 AM
EvilCartman's Avatar
Car: '82 Z28
'82 Z28
glass tops
hook style
non locking
Old Apr 25, 2002 | 08:04 AM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
83 Trans AM - Glass Tops - Metal Hooks
87 Formula (both of them) - Glass tops - Metal Pins
91 Formula - Glass tops - Metal Pins
89 Formula (salvageyard) - Acrylic tops - Plastic Pin Sleves
John
Old Apr 25, 2002 | 08:24 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
89 rs T-tops , glass. It looks like a plastic pin. Its round with a beveled edge that goes into like a socket. Kind of like the tip of a IAC motor.
Old Apr 25, 2002 | 09:43 AM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
My 92 RS came with the Lexan tops with plastic sleeved pins.
The coating is totally cracked from twist/flexing.Looks like you're looking through spiderwebs.
Recently picked up a pair of earlier glass tops in great condition for $20 at swap meet.
Plan on swapping the hardware over to the glass ones soon.
-Rich-
Old Apr 25, 2002 | 09:53 PM
Jim's Avatar
Jim
Car: 85 Camaro
85 iroc camaro
glass tops
metal pins
Has anyone tried to adust their tops? I would like to find instructions for doing so.
Old Apr 26, 2002 | 12:09 AM
mattskn's Avatar
85 TA
Glass
metal pin
Old Apr 26, 2002 | 08:40 AM
okfoz's Avatar
jim adjusting is easy,
drop the trim pieces from around the hole in the body,
then take a 7mm nutdriver and adjust up & down accordingly. The adjusters are like a "dual cam" to best describe it...
once you look at it you will see the slots and figure it out...
John
Old Apr 26, 2002 | 10:30 AM
Jim Berry's Avatar
Car: '86 Trans Am
Engine: LG4
Axle/Gears: 3.70 Posi disc 9 bolt
'86 T/A, glass tops, metal pins, no leaks.
Old Apr 26, 2002 | 11:27 AM
86NiteRider's Avatar
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
I got the glass with the metal pins in my '86 SC with locks. No leaks, scratches or rattles, thank You ***!.
Old Apr 26, 2002 | 05:36 PM
CanadianCamaro's Avatar
Car: 1992 Camaro RS
Engine: 5.7 V8 TPI
Transmission: T-5 5-Speed Manual
Mine:
85 Berlinetta (parts car): Glass, Pin Style, Locking
87 SportCoupe : Same
92 RS: Lexan, Plastic Sleeved Pins, Locking
Old Apr 27, 2002 | 04:15 AM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
1991 RS Lexan
1987 Z28 Glass
i have since swapped those two over since the Z28 isnt on the road yet
last nite at the E-town swap meet i picked up a set of GLASS T-TOPS in PERFECT CONDITION in THE BAG for $20 :rockon:
so now BOTH of my camaro's can have glass t-tops instead of crappy *** lexan
Old Apr 27, 2002 | 05:23 AM
jeff85iroc's Avatar
85 iroc
glass with metal pins.
Old Apr 27, 2002 | 07:02 AM
86T/Anjsux's Avatar
86 T/A... Glass T-tops w/ Metal pins...No leaks here ! I like em' better than birthday cake!!!:lala:
Old Apr 27, 2002 | 08:12 AM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
1986 Sport Coupe
Lexan T-tops
Locking pins
No leaks at all
Old Apr 27, 2002 | 04:54 PM
Absalom's Avatar
Car: 83 Camaro Z28
83 Z28
Glass
Hook Style
They don't leak but they rattle so much they drive me insane. It's right at the hook on the driver's side and the handle on the pass. side. Any suggestions to make it shut up?
Old Apr 28, 2002 | 11:32 AM
heavy_chevy29's Avatar
Car: 84 camaro Z28
Engine: 434sbc
Transmission: powerglide
Axle/Gears: moser 9" with 411 posi
84 Z28
glass
im pretty sure they are metal pins.
Old Apr 29, 2002 | 10:30 AM
okfoz's Avatar
Absolom,
I might suggest replacing them with the pin style from 84+, go to your favorite salvageyard, and see if they have any broken T's, it MIGHT be possible to replace the hardware. You will also obviously have to replace the hardware on the car too....
it might help...
I was pretty sure you could adjust the early "hook" style t's too.
John
Old Apr 29, 2002 | 12:00 PM
cfirebird86's Avatar
Car: 86 firebird
Engine: v6
Transmission: 7004r
86 bird t-tops
I know this stupid so bear with me. How do you know if it glass or acrylic? I am new to the car things...in fact looking for a book called automative for dummies..
it think it's glass.
I love my t-tops. I got myself the storage bags from my ex-bf. For free
:rockon:
Old Apr 29, 2002 | 12:59 PM
Glass are well...glass. And the acylic are a black platisc.
Old Apr 29, 2002 | 01:02 PM
Car: 86 firebird
Engine: v6
Transmission: 7004r
t-tops
oh..okay. then mine are glass with a plastic tub
Old Apr 29, 2002 | 01:03 PM
okfoz's Avatar
Chances are your tops are Glass, unless someone changed them to acrylic.
The quickest & easiest way to teoll is to look at your tops. When you pull your tops off if there is a metal strip on the front and back of the top then you have the acrylic.
Typically the acrylic tops also have a tendancy to look cracked with what looks like a spiderweb cracks. that is called crazing, and is common with acrylic with age.
hope that helps
John
Old Apr 29, 2002 | 06:40 PM
Absalom's Avatar
Car: 83 Camaro Z28
Anyone have a picture of the pin style vs. the hook style? I realize it should explain itself but I would like to see what the difference really is.
okfoz - I tried to fix the hook mechinisim this weekend only to find that I would need something to press the rivit-like pins that join the hook to the rest of the mechinism. Seems these get loose over time. Would a set of new T's with pins fit right if I were to just replace my T-tops? If I can just replace the latching portion, I have no idea how that separates from the glass.
Thanks for the help
Old Apr 30, 2002 | 07:51 AM
okfoz's Avatar
never done it, I have seen the earlier style T-tops with the later style glass but I really do not know....
If your wondering what I am talking about is on the early glass they painted only portions of the glass, whereas on the later models there was more paint. for example. On the later styles, like on my 87, the paint was on all the edges, on my 83, the paint was just on the outside (by the handle) it did not go all the way around...
John
Old Apr 30, 2002 | 08:54 AM
stuart69427's Avatar
Car: 94 Camaro
Engine: 3.4L
Transmission: 4l60e
'88 SC
I had the metal pins in before, but I (the dumba$$) forgot to lock the pass on day and well going 60 down the highway, you get the picture... I now have ones from an '88 IROC w/ the Plastic around the pins, It still bolts in, but now they leak They both were glass.
To the best of my knowledge, heres the facts: (correct me if I am wrong!)
82-84 Glass Tops, Hook Style Pin
85-90 Glass Tops, Metal Pins
91-92 Lexan (aka Ackrlic), Plastic Wrapped
I think all came w/ locks and as far as glass w/ plastic wrapped pins I dunno...
Old May 1, 2002 | 12:25 PM
indy82tx's Avatar
Car: 1982 Z28 Indy Pace Car
Engine: 305 LU5
Check out this web site. It has a table that list the evolution of the camaro/firebird T-tops.
http://www.sunroofdoctor.com/
Old May 2, 2002 | 10:00 PM
  #42
Supercharged84Z's Avatar
Car: 1984 Camaro Z28
Engine: 350 CID
Transmission: Beefed up 700R4
84 Z28 Glass & Hook
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
Thirdgen89GTA
Nov 26, 2015 11:04 PM
meeklay812
Oct 1, 2015 03:46 PM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
