Metal rusting away under battery
Old May 20, 2002 | 08:08 PM
WaynesRS's Avatar
How do I take care of this guys ? I want to fix it before , it has to be welded . Although that might be to late ...I think part of it has a very small hole if Im not mistaken . I know the metal is getting pretty thin .I just remember last time I had the battery out and it didnt look good .Thanx
Old May 20, 2002 | 10:08 PM
Camrs89's Avatar
Car: 91 Formula, 79 Trans Am, 72 LeMans
Engine: 305 TPI, 6.6, 350 Pontiac
Transmission: T5, 3 speed, TH350
Mine has the same problem. I was just going to take sheet metal and rivit it on there. Shouldnt be too noticable.
Old May 20, 2002 | 10:30 PM
Snowdog 91 Formula's Avatar
You could also get a plastic tray at an auto parts place for a few bucks too. Might be worth it.
Old May 21, 2002 | 09:30 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Try Por-15.
JamesC
Old May 21, 2002 | 10:18 AM
Bluebird's Avatar
Car: 1991 Pontiac Firebird
Transmission: 700R
hey
If it isnt too bad, look up POR-15 and use that
otherwise.. get a new tray.. and still use POR-15
Mark
Old May 21, 2002 | 04:19 PM
WaynesRS's Avatar
Thanx guys for you help . What is por 15 though ? I have never heard of that
Old May 21, 2002 | 04:24 PM
SUPER CHEVY66's Avatar
Car: 92 camaro, 06 trailblazer ss
Engine: 5.0 tbi, 6.0 ls2
Go here and order a free catalog.
http://www.por-15.com/
Old May 21, 2002 | 10:00 PM
WaynesRS's Avatar
It looks pretty impressive !!! Looks like I will be ordering some ! ...Looks easy to use and looks like it works awesome !
Thanx again guys ! And thanx for the link Chevy !
Old May 21, 2002 | 10:25 PM
Camrs89's Avatar
If you can weld. Get a welder out and weld some new metal in. Another idea.
Old May 21, 2002 | 11:16 PM
Blue502's Avatar
Weld, then POR-15. Best of all worlds!
Old May 22, 2002 | 07:09 AM
Z28DJP1987's Avatar
The bad news, if its to far gone a battery tray or Por 15 will not
help. The original metal tray is part of inner fender support. I know, its happened to me.
Old May 22, 2002 | 10:03 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Yeah, the POR-15 will stop the rust, but, if the metal is weak enough that you can put your finger through, you might want to get it welded. A shop should probably only charge $10, it's so simple. Cut out the rusted metal yourself, that'll make the cost less for the weldor. I've put a few posts up on how to use POR-15 if you want to search for 'em. Hint: buy the $20 super starter kit!
Old May 22, 2002 | 09:31 PM
89Formula305's Avatar
i replaced my inner fenders and battery trays, i just cut everything out of a 91... i didnt replace the one on pass side cuz it was solid, but i have the batt tray for pass side laying around painted, but you can get one from classic indistries, you will have to drill out the spot welds on the old one...
Old May 22, 2002 | 11:26 PM
Bluebird's Avatar
Transmission: 700R
more on POR15
https://www.thirdgen.org/techbb2/sho...hreadid=108626
Old May 23, 2002 | 05:31 AM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
The orginal battery tray is available from the dealer for under $20. The old one will have to have the spot welds drilled out and weld or rivit the new one in, looks very professional that way.
Old May 25, 2002 | 02:04 PM
erictheviking's Avatar
Car: '92 RS Camaro
Engine: 406ci D1SC SBC
Transmission: TH400
Axle/Gears: 9" W/Truetrac
What about Corroless
Nobody seems to have mentioned Corroless from the Eastwood company.I have sprayed my interior,engine bay and underneath with this excellent product.Its used as a primer and works in a similar way to POR-15(also a very good product).Its a flatter finish than POR-15 and accepts most top coats(Ive personally sprayed the engine bay with 2-pack-mammoth job).Ive done some experiments with rusty metal covered with corroless and left them in the rain for months,no rust ever came back through.Just make sure you use adequate coats.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Twin_Turbo
Mar 14, 2016 10:10 PM
Denricci22
Sep 18, 2015 09:02 AM
gta892000
Sep 16, 2015 12:37 AM
mrdevontay
Sep 2, 2015 08:04 PM
