83 Z28 dash cluster 85mph with that kmh side
Old Jun 17, 2002 | 10:18 PM
Nephilim's Avatar
I just need to know if i can get a different speedometer than this damn double needle one? anyone know which are compable thank you
Old Jun 17, 2002 | 10:31 PM
dbarker02's Avatar
all of em...
as far as ive understood any one of the clusters between 82-89 are interchangable.. the 90-92 arent the same type & dont work... have fun w/ you new gauges...
Old Jun 18, 2002 | 09:22 AM
89Formula305's Avatar
this one right here, lol, its my freinds car hes looking for a diff one also.
Attached Thumbnails 83 Z28 dash cluster 85mph with that kmh side-mvc-882f.jpg
Old Jun 18, 2002 | 09:23 AM
This is the same car, does anyone else have this, its the first time ive seen it, his is an 84..
Attached Thumbnails 83 Z28 dash cluster 85mph with that kmh side-mvc-883f.jpg
Old Jun 18, 2002 | 10:28 AM
dbarker02's Avatar
clock
the clock was an option.there are a ton of consoles w/ clocks in the local parts yard. if its not used much, remove it & stick a cupholder there... great place to have at least one holder neway, rock on...
Old Jun 18, 2002 | 11:17 AM
Nephilim's Avatar
Ya i just wanted to know if a 85mph or a 110 or something could just take its place
Old Jun 18, 2002 | 11:21 AM
IROCmonkey's Avatar
Car: 85 IROC
Engine: LB9
Yep...all the guages on the camaro's between 82 and 89 are interchangable...I've replaced speedo, tach, volts, temp, gas...er the whole cluster. It's real easy, the guages just plug into the cluster. I am not sure however if you can get away with putting guages in place of the idiot lights without making other changes.
Old Jun 18, 2002 | 12:36 PM
heavy_chevy29's Avatar
Car: 84 camaro Z28
Engine: 434sbc
Transmission: powerglide
Axle/Gears: moser 9" with 411 posi
i agree with IROCmonkey. its very simple. i change the double needle speedo from my 84 with a 145 speedo from an 86. works great. i had to chang my speedo cable because the needle was shaken like crazy. deffinately change the speedo. i like the 145 so much better.
Old Jun 18, 2002 | 12:41 PM
Nephilim's Avatar
wow thats great news becuase my needle bounces around like a fish out of water also..........thank you all you have made my day
Old Jun 18, 2002 | 05:05 PM
Car: 84 camaro Z28
Engine: 434sbc
thereas a pic of how it turned out. my original gauge used to jump around like crazy. now after replace the cable its steady as a rock. good luck
Attached Thumbnails 83 Z28 dash cluster 85mph with that kmh side-gauge-cluster.jpg
Casey Meyers
Mar 2, 2016 10:46 AM
Street Lethal
Aug 14, 2015 08:25 PM
tnrednneck
Aug 13, 2015 08:57 AM
ChevyZ71
Aug 13, 2015 07:30 AM
