4th gen console problems...
Old Aug 2, 2002 | 07:54 PM
383strkr84z's Avatar
I tried to look for a link on here, and I'm sure you guys have posted it a million times, but I bought my wife a 88 GTA, and I bought a 98+ console for it. it is an automatic. can someone break down there steps, and what, if any troubles were encountered? Thanks in advance!!
Jerry
Oh yeah, here is her new car:
Old Aug 2, 2002 | 11:30 PM
nosaint's Avatar
Car: 1986 Trans Am
The cover wont clear the shifter mechanisms. You needed to get a 6spd so that u could of just bolted it on. The shifter boot gives you more room.
Old Aug 2, 2002 | 11:41 PM
I have seen a pic on here tonight with someone who had it done, so I know it's possible. I just need to know what mods need to be done. Anyone???? please!!!
Old Aug 3, 2002 | 12:28 AM
CrazyHawaiian's Avatar
Car: too many ...
I think everyone uses a 6 speed 4th gen console because the auto console dosnt match up. Sorry.
Old Aug 3, 2002 | 06:49 AM
LT1maro's Avatar
let me tell, u, no, it wotn work. I have gone through 2 98 trans am consoles trying to get the auto to work, and it just wont. shifter asssembly is to high adn u need to cut the heck out of it to make it at least move. Dont do it, i have wasted alot of money on that and now i realized that i need to get a 6 speed shift plate for it to work
Old Aug 3, 2002 | 09:35 AM
I know it will work!!! Check this out:
Guess i'll pm him.
Old Aug 3, 2002 | 09:40 AM
Tonyrodz's Avatar
Transmission: auto
Just change the auto plate to a stick cover plate--and it slips right in--no mods at all.
Attached Thumbnails 4th gen console problems...-4th-gen-console-1
Tonyrodz's Avatar
Transmission: auto
another angle.
Attached Thumbnails 4th gen console problems...-4th-gen-console-2
Old Aug 3, 2002 | 09:43 AM
86_iroc-z28-350's Avatar
383strkr84z
Yes i believe it can be done also, but i think your must move the shifter either left or right a lil and it will fit,
Old Aug 3, 2002 | 10:49 AM
stuart69427's Avatar
Car: 94 Camaro
Engine: 3.4L
Transmission: 4l60e
If the guy wants to leave the auto plate for his wife, then don't try to pursaude him...
... It has been done, you just have to move the shifter, so i would assume you unbolt the shifter, play with it till you can install the Auto Plate on the console, then drill new holes, and bolt the shifter down...
Probabley harder than that...
Old Aug 3, 2002 | 07:25 PM
omnipotentgoku's Avatar
Car: 1987 IROC Z
Engine: 350 TPI L98 block
Has anyone tried the console swap with a B&M hammer shifter ?
Old Aug 3, 2002 | 10:27 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
Does anyone know if the shifter out of the 4th gen will work on the 700r4 in a thirdgen, if so it would solve some of the clearance issuses.
I had decided I am going to get a 6spd console for my car and I am going to make an led indicator and mount it in my cowl. Use one led bulb and one number led's and have it read out
*3
R
P
I can't find an LED I can make a N or D with, well I guess I could make it lower case
d
*d
R
P
Which one would make more sense?
Someone on here had done something similar with a series of LED's I just thought I would take one step further. You just have to make the shifter ground the connection in each position.
Old Aug 4, 2002 | 10:32 PM
tamatt27's Avatar
Car: Kitt
Engine: Classified
Axle/Gears: Moser/4:11
Just a quick ?. Do the power window switches just bolt right up to the existing 4th gen console not problems? Also, so any 93+ manual console would work??
Old Aug 5, 2002 | 12:03 AM
Tonyrodz's Avatar
Transmission: auto
No--you have to mod them in somehow. Most people just put them in the ashtray. I was thinking of putting mine on the sides of the center console somehow.
Any 93 up console will work fine. I think the 97 up version has 4 cup holders.
Old Aug 6, 2002 | 03:56 PM
Car: 94 Camaro
Engine: 3.4L
Transmission: 4l60e
*3
P
d
*d
P
Even if you got a 4th gen auto shifter, it still wouldn't line up so that you can bolt up the shifter plate
Old Feb 1, 2003 | 05:06 PM
joatrash's Avatar
Hiya
383strkr84z, did you ever find out how to do that auto-console swap? Did the guy move the shifter over?
I think I read something somewhere about the gear-indicators not lining up correctly....
Old Feb 1, 2003 | 06:52 PM
cg91ta's Avatar
Car: 1991 T/A - Sold (sniff) 1980 T/A Pa
It was my understanding that to make a 4th gen auto shift console work you need the shifter as well as the upper console. I have both and tried it, and here's what I found. The 3rd gen shifter sits on a mounting plate that suspends it above the tranny hump. IF you were to remove that plate (and NO I haven't done this, I'm too chicken) there appears to be enough room to mount the 4th gen shifter in the newly created depression. However, there are no mounting holes whatsoever. You would have to create them. This also does not take into account the length of the shifter cable and the lockout cable, the one that disables the ingition switch from going all the way to "off" without the tranny in park. For all intents and purposes it does appear that the electrical and cable connections to the 4th gen shifter are the same as the 3rd gens.
I too have seen the whole shooting match installed in a 3rd gen, but have never talked to the person directly that did the install to find out any more details.
GL HTH
Hawk312
Aug 22, 2017 08:55 PM
Casey Meyers
Mar 2, 2016 10:46 AM
cam-mike
Aug 24, 2015 07:23 AM
