Removing the vents?
Old Nov 4, 2002 | 04:47 PM
Maximus's Avatar
Car: 1992 Camaro Z28
Transmission: 5spd.
Removing the vents?
I have to take the dash vents out to clean them really good> How do they come out? I took a look at them, it seem as if there are clips on the sides? Can anyone help? Thanx.....
Old Nov 4, 2002 | 06:11 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Never looked at it that closely, but are you trying to clean these with the dash pad still in the car? It might be safer to take the whole dash pad out of the car (all phillips' head screws underneath the dash lip, and 4 phillips' head screws between the defroster vents-don't drop 'em in!) instead of just taking the vents out. They're old and brittle by now, and you don't want to risk cracking them, OR the clips that hold them in!
Old Nov 4, 2002 | 07:43 PM
Maximus's Avatar
Transmission: 5spd.
I've taken the dash off before, I don't think you can get to them that way, I may be wrong? I'm talking about the center vents above the radio and the ones on the sides. Just windering if they pop out to clean them as best as possible/ thanx for the reply...:hail:
Old Nov 4, 2002 | 07:56 PM
'89 IROC Vert's Avatar
The ends of the vents have two little "posts" that come from the center and stick into a hole in the vent housing. The posts have are spring-loaded. Use a screwdriver to activate the posts and they'll come out. Doesn't take much pressure at all.
Old Nov 4, 2002 | 09:49 PM
DISTURBthePEACE's Avatar
Car: 89 Camaro RS
Engine: 2.8L V-6
They're all easy to get out except the bottom vertical ones on either side, those were a pain in my azz to get out for some reason. Dont forget to pop out the ones on the dash and the ones on either side of the stereo! I also did the velcro trick so they stay where I put move them to, they used to alwayz fall down when I tried to level them out.
Old Nov 5, 2002 | 07:53 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Just don't pry too hard. GM plastic is among the cheapest plastic in the known universe, and when it gets old, it has a tendancy to break if you give it dirty looks.
Old Nov 5, 2002 | 09:12 AM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
on firebirds on the outside vents, I remember them actually having to come out by removal of the dash, there were some 7mm screws back there... Of course I am talking about the assembly part of them housing and all... (Not sure if I could get to them by lookin straight down or from bottom up...)
John
Old Nov 5, 2002 | 07:11 PM
Maximus's Avatar
Transmission: 5spd.
Hey thanx guys! "Disturbthe peace" I was going to do the same thing but instead of velcro, using double sided tape! I love that stuff, it works so good in most situations!!!Thanx again guys....:hail:
Old Nov 7, 2002 | 08:52 AM
9-FIREBIRD-2's Avatar
Re: Removing the vents?
What kinda car? I just did my 92 bird and it was a cake walk.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
HP52TA
Feb 3, 2018 10:51 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Stroopwafel
Sep 11, 2015 06:38 AM
TBRays98
Sep 6, 2015 05:05 PM
