How can one fix the console?
Old Nov 6, 2002 | 09:59 AM
joshp14's Avatar
I'm sure that anyone that has a firebird of the 3rd generation is having the lips of the console peel down and/or curl away from the rest of the console. Does anyone have any ideas on how one can fix this? Has anyone ever done it before? Please fill me in on getting this very common problem fixed w/o spending over $250 for a new console.
Old Nov 6, 2002 | 01:42 PM
joshp14's Avatar
C'mon, someone has ad to have fixed their console before! Any ideas?????
Old Nov 6, 2002 | 02:03 PM
Kj Rockz's Avatar
From: Mililani, HI USofA Search Posts: 2848.............. Whore Posts: 47.................. Magical Whore Posts: 1
Car: 91 Camaro 77K
Engine: 3.1 Vslick
1. Epoxy, and a lot of time
2. 4th gen console...
It's laot easier, looks better, has cupholders...
Old Nov 6, 2002 | 02:08 PM
joshp14's Avatar
what kind of epoxy? and where can i get some?
Old Nov 6, 2002 | 05:26 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
#1) forget epoxy...
#2) this is how I did mine an it turned out 99% perfect, no one notices the little imperfection 'cept me.
1) Remove shifter ****
2) remove your shifter plate
3) remove center console from car... its just easier to work with...
4) there is a thin layer of foam stuff that is glued to the vinyl remove it where the lip is. (use your finger, scraper whatever it takes) You cannot glue to this stuff it just gives and you have the same situation you had before.
5) there is a lip where the vinyl attaches to the structure of the center console, and I used superglue to glue it to it... I did little sections and worked my way around, turned out great...
hope this helps...
BTW, I am glad you like my artwork for your Avitar ...
John
Old Nov 6, 2002 | 05:41 PM
joshp14's Avatar
Thanks, I will go ahead and give it a try this weekend.
BTW, yeah that's a pretty awesome bird, i had to use it for my avitar
Old Nov 6, 2002 | 06:13 PM
ohohblita's Avatar
i tried various glues but trust me go with SUPER GLUE!!!
it works great. dont fool with other crap.
Old Nov 6, 2002 | 06:16 PM
Kj Rockz's Avatar
Car: 91 Camaro 77K
Engine: 3.1 Vslick
Ware gloves, latex will work...
Old Nov 6, 2002 | 11:36 PM
89V6FBIRD's Avatar
Car: 1999 Pontiac Trans Am
Engine: LS1 - 346 ci
Or just buy the one I'm selling for a lot less than $250. See sig!
Old Nov 7, 2002 | 12:16 AM
joshp14's Avatar
thanks, but no thanks, i am a college student and dont have $$$ laying around to spend on a console when mine is fixible with time and superglue. Plus it isn't really necessary to fix, it will just look better, and also keep it from getting any worse.
Old Nov 7, 2002 | 02:21 AM
9OFirebirdV6's Avatar
The way i fixed mine was first i removed the console, then I took some of the 3M Super Adhesive Trim Spray (In the can obviosly). I then peeled back carefully the area that came apart, sprays some adhesive inside, then to keep it tight against the plastic upper console area, i used duct tape. I would take one end and stick it to the side where the adhesive was then stretch it tightly across the consol to the other side i did that all the way down the side that i sprayed so it would have a uneven line. Then just let it sit over night and it looks 100x better.
Old Nov 7, 2002 | 09:30 AM
MNformula350's Avatar
I used some 3m emblem and trim adhesive on mine.
I took out the shifter **** and handle,then used some thin pieces of wood and c clamps to hold it all together over night.
Still looks great 4 years later
Veaceonee
Sep 29, 2016 08:15 PM
chuck13
Interior Parts Wanted
Sep 22, 2015 11:19 AM
Fronzizzle
Sep 8, 2015 12:10 PM
Third_Gens_Rule
Sep 3, 2015 06:56 PM
Third_Gens_Rule
Sep 3, 2015 06:55 PM
